my oil change spill lil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauairandall, Jan 8, 2011.
  1. Jan 8, 2011 at 6:48 PM
    kauairandall
    kauairandall [OP] Senior member
    randall
    hawaii
    2006 TRD toyota tacoma v6 4x4
    6" fabtech suspension lift 3" body lift 3"gap guards K&n intake MBRP exhaust billet grille stubby antenna maglight mod Debadged No mudflaps 30% tint Interior: Alpine CDA-105 deck Alpine MDA- sectrum analyzer Alpine amp 12" kicker sub Wet okole seat covers
    stupid disposable oil box did'nt absorb the oil the way it should've.. lol epic pwnge.
  2. Jan 8, 2011 at 7:03 PM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    :laughing:
    haha, is that a trash bag in the box? You're idea might have worked if you had a bigger box and one of those heavy mil black trash bags. Hope the concrete didn't stain too bad.
  3. Jan 8, 2011 at 7:15 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Spread it out so it doesn't stain too badly. :D
  4. Jan 8, 2011 at 7:43 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    hahha... kitty litter will soak it all up.
  5. Jan 8, 2011 at 11:31 PM
    kauairandall
    randall
    hawaii
    lol.. no they sell those disposable type oil absorbing boxes at checkers, etc.. and the cotton type lint material inside didn't quite work right resulting in overflow.. lol fuck that box, i don't recommend it.
  6. Jan 9, 2011 at 12:40 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    lol, that sucks dude
  7. Jan 9, 2011 at 12:53 AM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    05 AC Prerunner 6-speed
    k&n air filter, weathertech digital fit, TRD 6-speed gray knob, undercover bed cover, flowmaster american thunder dual exhaust, URD short shifter, 5100's set at .85, Grillcraft, black surround grille(with SJ stripe)
    that's why i use a thing called an........ OIL PAN:p
  8. Jan 9, 2011 at 3:15 AM
    Potomac30
    Potomac30 Member
    SC
    2011 PreRunner
    My oil shot out when I pulled the drain plug. I had 8 quart round pan under it and it still splashed oil out of the pan because of the force that it came out of the truck. I use large pieces of cardboard under the vehicles when I change the oil. It cuts way down on the mess and when you're done you can slide the cardboard out and your tools, rags, oil etc are a lot easier to pick up.
  9. Jan 9, 2011 at 4:19 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Ouch, that sucks. Get your self some powder laundry detergent and spread it all over the spill. If its outside just let the rain wash it away, if inside let it sit for a few days and wash it away with the hose. Will be the cleanest spot on the ground!
  10. Jan 9, 2011 at 4:27 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Next time buy a real oil pan and then recyle the used oil. It does not take a lot of time and it is the right thing to do.
  11. Jan 9, 2011 at 4:37 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    12 DCSB TRD Off-Rd 4x4, Roof Rack, Tube Steps
    K&N drop-in air-filter, extra D-rings, Custom Console lock-box, Leather heated seats, Studly Driver
    X2
    I'll admit that I have actually used a packing box with a heavy duty garbage bag in it before when I had not other options but would not recommend it. You are basically just containing the technical majority of the oil but there's plenty left on the ground when you're done.
    Also, those epoxy garage floor treatments are AWESOME at making these types of spills very temporary. One time I forgot to open the air vent on my oil pan and had at least a quart overflow. All it took to have the floor looking like new was a few rags (old t-shirts/towels/etc that are past their useful life) and a quick wipe with some windex at the end.
  12. Jan 9, 2011 at 8:24 AM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    I had something similar happen on my first oil change WITH a correct drain pan. I couldn't believe how fast it came out and splashed everywhere. Installed a Fumoto drain valve ( http://www.fumotousa.com/ ) and couldn't be happier with it. Third vehicle I've had one on with never a problem.
  13. Jan 9, 2011 at 8:38 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Wow, that sucks.
    Just curious for everyone that has the oil shoot out excessively, do you remove your oil filter before/after pulling the plug? Just curious if this would cause greater force down.
  14. Jan 9, 2011 at 8:52 AM
    KellyJoe
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    That's what I did along with removing the oil cap. I think it's vented too much and causes it to come out too fast for pans that are too shallow like I used.
  15. Jan 9, 2011 at 9:15 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    I have a big box of those commercial oil diapers from work, for catching small drips.
    F the kitty litter!!, get a bag of dog bedding/cedar shavings from a feed store, soak up the oil with the shavings, scoop up the shavings and toss them back in the bag. Much better absorbent than cat litter and infinite absorbability.
    Money well spent on a black deep drain pan from the auto parts store.
  16. Jan 9, 2011 at 9:19 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Weird... I normally just drain my oil straight into the storm drain. :der::bananadead:
  17. Jan 9, 2011 at 9:48 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I don't think I would like that plug simply because anyone can drain your oil without tools in a matter of seconds. It may never happen, but I would be paranoid about it.
  18. Jan 9, 2011 at 10:01 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    i just stay with an oil drain pan. much easier
  19. Jan 9, 2011 at 10:35 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I use an oil drain pan and recycle my oil. Autozone takes 5gal per customer per week which is more than enough. I usually have shop towels, cardboard, brake cleaner,or gloves when i do my oil change
  20. Jan 9, 2011 at 10:39 AM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2011 Tacoma Double Cab 4x4 T|X PRO
    Every time I change my own oil, regardless of the vehicle, I get a little visit from Captain Hazelwood......
    (I could say BP or the Deepwater Horizon, but that event actually involved human fatalities at the time of the disaster.....)
