My spark plugs with 95k miles on them.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Feb 21, 2010.
  1. Feb 21, 2010 at 6:17 PM
    bruce1271
    bruce1271 [OP] Well-Known Member
    Got around to changing my plugs today. Guess I shouldnt have waited so long from the looks of it, but I cant tell any difference in running performance between the old and newly installed ones. NGK's looked a little worse than the denso's and the Cylinder closest to the cab was the worst as far as dark build-up on each side of the 6.
    NGK
    DENSO
  2. Feb 21, 2010 at 6:23 PM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    I should probably get around to changing mine sometime...
  3. Feb 23, 2010 at 7:47 PM
    bruce1271
    I change my mind. My truck is running stronger and is starting faster. I am finding myself holding the key on the starter too long out of habit. A good 2 1/2 Mississippi was required to start my truck. Now only 1 1/2 with new plugs.
  4. Feb 23, 2010 at 7:50 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah guys, they should be changed about every 25,000-30,000 miles.
  5. Feb 23, 2010 at 7:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    WHOLEY SHIT! Those gaps are HUGE!
  6. Feb 23, 2010 at 8:28 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Poor little sparks were probably saying the same thing :laugh:
  7. Feb 23, 2010 at 8:49 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Did you measure those gaps? What did you replace them with?
  8. Feb 23, 2010 at 8:51 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    what kind of spark plugs you guys using??
  9. Feb 23, 2010 at 9:17 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    regular plat plugs should be .040 and iridiums should be .044....per vato zone's computers yesterday. changing mine out tomorrow at a tad over 30k
  10. Feb 23, 2010 at 9:21 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Whaddya think? A dime, maybe even a nickel, could fit in those? Gap measurements and pocket change shouldn't go together in the same sentence... :laugh:
  11. Feb 23, 2010 at 9:34 PM
    nuckinfuts
    Pacific NW
    '06 AC TRD Off-Road
    Factory spec is .039 - .043 in. I'm just curious to know how ridiculously far off these were.
  12. Feb 23, 2010 at 9:39 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Thats what she said :cool:
  13. Feb 24, 2010 at 9:10 AM
    bruce1271
    Those used plugs have a 0.060 gap! and i bought the densos from the dealer and they came pre-gapped to 0.041. Not sure if autozones are pre-gapped.
  14. Feb 24, 2010 at 9:53 AM
    The_Hodge
    SC
    auto zone plugs are usually pregapped. the ones i bought were
  15. Feb 24, 2010 at 9:58 AM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    I checked mine about 5,000 miles ago on my 4 cyl, and the gaps were still good. they still looked ok too. I have no clue when they were last changed since i have only owned the truck for 16,000 miles.
  16. Feb 24, 2010 at 10:31 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Any possibility you can do Close up of those two sparkplags with sharper image?
  17. Feb 24, 2010 at 10:39 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    bruce if you retake your photos, turn on the "macro" feature in your camera. It's usually the flower icon. It's for closeups.
  18. Feb 24, 2010 at 11:00 AM
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
    That was the first thing I noticed also, haha.
  19. Feb 24, 2010 at 11:14 AM
    toytaco970
    toytaco970 Well-Known Member
    avon/vail, co
    05 trd offroad 4x4
    Front: Icon IVD coated extended travel coilovers Rear: 5125's with AAL and 1" block. Front sway bar removed. Brute Force Fab bumpers AllPro stuff: UCAs , front skid plate, sliders, rear u-bolt flip kit, e-locker guard Kenwood/Garmin single DIN DVD-NAV system, amp and sub. V1 radar, Foglight anytime mod,
    wow
    I have changed mine twice now, both after 30k each time. The gap had grown to .048 and I could definitely tell a difference at startup and idle smoothness.
  20. Feb 24, 2010 at 11:27 AM
    BlueT
    NorthEast
    So is consensus that they need to be changed at 30K on v6 ? Seems low but I guess better change them more often.
