My Suspension Questions (5100's and the rest OEM)...
Discussion in 'Suspension' started by OmegaQuest, Apr 3, 2013.
  1. Apr 3, 2013 at 5:20 AM
    OmegaQuest
    OmegaQuest [OP] Well-Known Member
    Maryland
    2013 Tacoma Limited Double Cab 4X4
    Oil Catch Can, Motorcycle Chock, WeatherTech Window Deflectors, Bilstein 5100, OEM 4 Leaf, Chrome Satoshi Grille, FX-R Stage III Retrofit, Color Match Head Light Mod, Front Hella 500 HID, Behind Grill Light Bar, Rear LED Bed Lights, Pop and Lock Tailgate, Chrome License Plate Covers, AFE Air Filter, Removed Secondary Air Filter, Paint engine cover (Red), ImMrYo Rear-View Mirror Lift Bracket, Center Console Organizer, ScanGauge 2, Firestone W217602407 Ride-Rite Kit, Firestone WR17602178 Air-Rite Dual Electric Air Command
    I have read quite a few of these suspension posts and I see everyone saying that in order to fit an 18" rim on their truck that you need to cut stuff and everything else.
    Well my new truck (2013 Limited Double Cab) came with 18" rims stock with 265/60/18 tires and there is no rubbing what’s so ever, am I missing something here?
    Here are the specs of my truck to help answer the questions below:
    • 2013 Limited 4x4 Double Cab with Tow Package
    • Stock Rim/Tire Size: 265/60/18
    • Current Height (from center of hub to bottom of fender):
      • Front Left (Driver Side): 20 1/2"
      • Front Right (Passenger Side): 20 1/2"
      • Rear Left: 22 1/4"
      • Rear Right: 22 1/4"
    • Less than 1,000 miles on the truck thus far
    • It came with 4 leafs already in the back
    • I don’t plan on going off roading, but I want to be able to if I need to get out of dodge incase the zombie apocalypse happens or the occasional off road camping trip... LOL
    • I carry a sportbike in the back of my truck to the race tracks which can be 500 miles away
    • I want the smoothest ride I can get on the highway, speed bumps.... without spending tons of money
    • I plan on doing all the installation myself
    Anywho, I just ordered a set of 5100's for all 4 corners but I have a few questions.
    1. Will I or will I not need a 1/4" top plate spacer for the (Driver side only)?
    2. If I keep everything else stock (springs and stuff), will my current wheels not fit on the truck without cutting (this part is confusing me because of all the other posts about people having to cut their fenders and stuff...)
    3. What setting should I set the front 5100's so I can level the truck out (.85, 1.75)?
    4. If I am only leveling the truck, would it make for a smoother ride if I got some LR UCA or just keep stock?
    5. Would adding aftermarket springs help the truck ride smoother while still having the capability to go off road and if so, which springs?
    6. Would adding a Icon progressive AAL with my 4 leaf make for a smoother ride on the highway and offroad?
    7. Will I need wheel spacers with my stock tires?
    8. Should I add some FireStone Ride-Rite 2407 to my current setup of 5100's and 4 leaf pack?
    9. Am I overlooking anything else?
  2. Apr 3, 2013 at 11:39 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    I can possibly help with at least one question.
    If you use your stock coils,and just put the 5100's on the front( at the same setting on both sides), the springs already have a built in compensation for the lean. They are side specific. If you change to an aftermarket coil is when you run into issues with the 1/4 top plate spacer being needed.
    As far as figuring what to set them at, you can measure the distance from the center of your hub,to the bottom of the fender flare,to determine the difference from front to back. I would say the 1.75 setting may be the correct one, and am sure others will speak up and let you know for sure.
  3. Apr 3, 2013 at 12:28 PM
    OmegaQuest
    Maryland
    Thanks for answering #1 and I will go out and measure the stock (Before I put the 5100s on) so I have something to start with
  4. Apr 3, 2013 at 12:38 PM
    2013BlueTRD
    2013BlueTRD Active Member
    Jose
    Augusta
    13 TRD Sport 4x4
    3" lift kit with Bilstein 5100 Height Adj. Coilovers aFe Cold Air Intakes Stage 2 Si OEM skid plate Philips CrystalVision headlights & fogs N-fab step bar WeatherTech window deflectors Borla Pro XS Muffler Removed emblems
    I went with the 5100s set at 1.75 with stock coil and have no issues with 265/70/17 tires. the rear is still all stock but put 5160s shocks. Did all of this at 400 miles on it. So the 5100s are great set at 1.75 and level the truck out perfect. The truck should be sold that way..
  5. Apr 3, 2013 at 12:39 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    What happens when you put weight in the back and use it like a truck?
  6. Apr 3, 2013 at 12:43 PM
    2013BlueTRD
    Jose
    Augusta
    13 TRD Sport 4x4
    Then I would say add a leaf to make up for that wieght.
  7. Apr 3, 2013 at 3:33 PM
    Skunkman
    Syracuse - Tug Hill
    I went through that process,starting with a Toytec AAL,a light duty set of replacement leafs, and finally doing it right ( for my application anyway ) by going to All Pro Expo's. It all depends on what you use your truck for on a regular basis to what extreme you need to go. With the Expo's, I believe they would be overkill for most people,especially with an unloaded truck,but they are perfect for me. With 600-800 pounds in the back, I still get plenty of lift out of them.
  8. Apr 3, 2013 at 3:41 PM
    GP3
    California
    4X4 TRD Off Road
    I was just giving 2013BlueTRD a hard time for wanting Toyota to sell the truck level front to back, when most people buy a truck to haul stuff in the back.
  9. Apr 3, 2013 at 3:43 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Don't do it.
  10. Apr 3, 2013 at 3:48 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    For the most part the rim size isnt what is making peoples tires rub its the tires themselves and most people on here that run lifts have 33" tires which are 285's metric and most people have minor rubbing issues with that size but minor trimming will get rid of the rub.
    If you have the overload leaf in the rear I would set the 5100's at 1.75" and that should level out the truck. Yes you can always add aftermarket springs and leafs but it just depends on how much you want to spend.
  11. Apr 3, 2013 at 5:01 PM
    OmegaQuest
    Maryland
    Here are the current heights:
    So because I from time to time carry my 500 lbs motorcycle in the back of the bed, I should "Not" level the truck?
    Is there some sort of configuration that will level and keep the truck level even when the bike is in the back?
    I dont mind spending under $1,000 for the suspention (including the $300 I already spent on the 5100's for all the corners) so thats $700 more "If" I have to. I just dont want to waste money on something that I would not benifit from or wouldnt benifit enough to be worth the cost....
  12. Apr 3, 2013 at 7:48 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    The 5100's are good but if I knew you had more money to spend I would have pointed you to a different suspension lift. I added OME 885's with a 2" rear AAL to my 5100's so its 3"s of lift up front and 2" in the back to level it out. I like the way it rides and its been on my truck for a little over 4 years and still going strong!
  13. Apr 4, 2013 at 11:20 AM
    OmegaQuest
    Maryland
    Should I consider adding some FireStone Ride-Rite 2407 to my 5100's in the back and OEM 4 leaf setup already on my truck for when I do haul my bike?
    Or is this just throwing money away for something that I wont need with just the 5100 all around and 4 leaf pack?
  14. Apr 8, 2013 at 7:28 AM
    OmegaQuest
    Maryland
    My 5100's come in today! Anyone have ideas on my Ride-Rite question or should I just not worry about that and just set the 5100's to 0 in the front?
  15. Apr 10, 2013 at 6:04 PM
    OmegaQuest
    Maryland
    I just finished installing the 5100's all around and the I kept the front 5100's to 0 for now.
  16. Apr 10, 2013 at 9:01 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Wait so you have no lift?
  17. Apr 11, 2013 at 4:00 AM
    OmegaQuest
    Maryland
    Not right now. I was thinking of leveling the truck, but I carry my sportbike in the back of my truck to/from the racetrack and I hear if I level it, when I carry my bike I will be very high in the front and low in the back...
    Is this not true?
  18. Apr 11, 2013 at 6:24 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    If you level it then yes you will be a little nose high but I dont think it would be anything extreme. My truck is has a 3" lift and it sits level and I travel with my dirt bike all of the time. I know your sport bike weighs more but you get the idea. Here is a picture of all of us with 3" lifts and bikes in the back. You can see that wee arent sagging in the back much at all.
  19. Apr 11, 2013 at 6:43 AM
    OmegaQuest
    Maryland
    Do you have any experiance with Air lift / Ride-Rite?
  20. Apr 11, 2013 at 6:56 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Sorry I dont. :( Maybe ask around on other similar threads and I'm sure you can find some answers.
