My Suspension Questions (5100's and the rest OEM)...
Discussion in 'Suspension' started by OmegaQuest, Apr 3, 2013.
  1. Apr 11, 2013 at 2:56 PM
    OmegaQuest
    OmegaQuest [OP] Well-Known Member
    Maryland
    2013 Tacoma Limited Double Cab 4X4
    Oil Catch Can, Motorcycle Chock, WeatherTech Window Deflectors, Bilstein 5100, OEM 4 Leaf, Chrome Satoshi Grille, FX-R Stage III Retrofit, Color Match Head Light Mod, Front Hella 500 HID, Behind Grill Light Bar, Rear LED Bed Lights, Pop and Lock Tailgate, Chrome License Plate Covers, AFE Air Filter, Removed Secondary Air Filter, Paint engine cover (Red), ImMrYo Rear-View Mirror Lift Bracket, Center Console Organizer, ScanGauge 2, Firestone W217602407 Ride-Rite Kit, Firestone WR17602178 Air-Rite Dual Electric Air Command
    Another question. I just got my truck's alighment done after setting my 5100's to 0
    If I put them up to 1.75 in the front to level it, will I need to get another alignment?
    And same goes for it I get some ride rite in the back do I need to get another alignment?
  2. Apr 11, 2013 at 2:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yes you will most likely need to realign after lifting in the front just in case but lifting the rear you shouldnt have to realign again.
  3. Apr 11, 2013 at 3:03 PM
    OmegaQuest
    Maryland
    I wonder if I should lift it now to the 1.75 and take it back to the dealership (they did the alignment yesterday) and say something dosent feel right and to double check the alignment.
    I would hate to have to pay another $80....
  4. Apr 11, 2013 at 3:53 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I'm sure they would know that you lifted it up front I would guess. :eek:
  5. Apr 11, 2013 at 6:22 PM
    OmegaQuest
    Maryland
    I just set it to 1.75 in the front.
    But now the front is about 3/4" higher then the rear and I have a 4 Leaf pack in the rear... LOL
  6. Apr 11, 2013 at 6:30 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    So you had the rear tsb spring already installed?
  7. Apr 11, 2013 at 7:04 PM
    OmegaQuest
    Maryland
    Ya, on the 2013 it comes with 4 leafs by default.
  8. Apr 11, 2013 at 7:13 PM
    JPT
    JPT Avid Jeep Hater
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    Blacked-out emblems, Oem Roofrack, Uws Low-Pro, Color-Matched Front Grill, Custom Pinstripes
    The limited and sport comes with 4 leafs default and I believe the or comes with 3. If i were you I would bump them back down to .85 on the front billies of the bro lean bothers you as much as it does me.
  9. Apr 11, 2013 at 7:14 PM
    OmegaQuest
    Maryland
    I was going to get some air bags in the back soon.
    So would it be better to just air the back up until its level and ride it like that (will it be a harsh ride)
    or should I get an additional AAL and just keep the air bags to 5psi and let the AAL level it?
    or lower the front to .85 and keep the air bags to 5psi?
    Either way I now plan on getting a rear air bag system (either ride-rite or air lieft).
  10. Apr 11, 2013 at 7:30 PM
    JPT
    JPT Avid Jeep Hater
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    hmmm, do you think tightening your u-bolts tighter than stock could have brought your rear down? Did you mess with anything else while installing also?
  11. Apr 11, 2013 at 7:33 PM
    OmegaQuest
    Maryland
    I dont think it lowered it any by tightening the U-bolts.
    Nothing else was messed with. Do you think the front just needs to settle in? I did ride it around the block a few times and did some sharp circles each direction to see if I could hear any issues.
    I'm going to go remeasure real quick and post the new numbers.
  12. Apr 11, 2013 at 7:45 PM
    OmegaQuest
    Maryland
    Current Height (from center of hub to bottom of fender):
    • Front Left (Driver Side): 22 1/2"
    • Front Right (Passenger Side): 23 1/8"
    • Rear Left: 21 7/8"
    • Rear Right: 22 1/4"
    Current Height (from ground to bottom of fender):
    • Front Left (Driver Side): 36 1/2"
    • Front Right (Passenger Side): 37"
    • Rear Left: 36 1/4"
    • Rear Right: 36 5/8"
    Nothing is loaded in the truck and nothing additional that adds weight has been added.
  13. Apr 11, 2013 at 8:04 PM
    JPT
    JPT Avid Jeep Hater
    JP
    West Georgia
    2013 MGM Trd OR 4x4
    Just drop it to .85 and it will look very close to level i guess. You do have the slight taco lean now ha. That is kind of weird also. I guess all trucks are different.
  14. Apr 11, 2013 at 8:18 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    You can get an AAL that works with the TSB but that will lift you about another 1.5"s in the rear if thats okay with you.
  15. Apr 12, 2013 at 3:59 AM
    #35
    OmegaQuest
    Maryland
    I prefer not to lift the rear any more than it is now. I dont want my motorcycle ramps to be any steeper them they are now LOL
  16. Apr 12, 2013 at 4:58 AM
    #36
    OldGeezer42
    OldGeezer42 Well-Known Member
    Adam
    Louisiana
    07 DCLB Silver Base
    Husky mats,30% tint all around, DTRL,OEM Bed mat,UWS Tool box,OEM fog lights,5100's,Wheelers 3leaf HD springs.OEM cruise control,OEM wipers,,Avid light bar,Flyzeye Leds,4x4 illuminated switch.Matt123 skids,bed lights,Ome 884s
    Sounds like .85 would work for you in the front,and it should keep you level, I didn't have the 4 leafs in rear ,I added the HD 3 leaf and set my front at 1.75, just air your bags up when you haul, and deflate when you don't. Remember when you measure is your tank full of gas? I don't know if that would make a huge difference.
  17. Apr 12, 2013 at 6:39 AM
    #37
    OmegaQuest
    Maryland
    I think it is about 3/4 full of gas. I'm going to measure it again today after I ride around a little to see if that changes the height any/settle.
    I just ordered the Firestone W217602407 Ride-Rite Kit for Toyota Tacoma 4WD!
    I will be getting a compressor soon (most likly the: Firestone WR17602178 Air-Rite Dual Electric Air Command Accessory Kit)
  18. Apr 12, 2013 at 12:31 PM
    #38
    OmegaQuest
    Maryland
    New numbers after I rode it around today (front is still set to 1.75):
    • Front Left (Driver Side): 22 1/4"
    • Front Right (Passenger Side): 22 3/4"
    • Rear Left: 22"
    • Front Left (Driver Side): 36 1/4"
    • Front Right (Passenger Side): 36 5/8"
    Nothing is loaded in the truck and nothing additional that adds weight has been added. This is with about 1/2 tank of gas.
    * I did notice that after I set the front to 1.75 and I took it out for its first spin I heard 1 clunk spound when I was backing up from my garage to take it out for the spin. I drove it around the block a couple times but I didnt hear it again so I thought maybe it was the spring getting put in place or something like that.
    Today I drove it around for a while and no sounds, that is until I pulled into my garage, then I put it in reverse because I was a little to far forward and I heard the loud clunk sound again. I tried to put it in forward and then reverse several times nut could not reproduce the sound.
    Any ideas what that sound is?
    * I have read that some people hear a clunk sound because the stabilizer bolts were loose, well I dont think this is the case because when I installed my shocks, I didnt have to touch the stabilizer (AKA losen it up or remove it or anything).
    Thanks
  19. Apr 12, 2013 at 1:13 PM
    #39
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    So looks like it dropped down about 1/4" of an inch.
  20. Apr 13, 2013 at 8:59 AM
    #40
    OmegaQuest
    Maryland
    I just got the Firestone Lifetime Alignment because I'm sure I will be tweeking the suspension for a little while.
    Here is the Alignment that was done today with 5100's and the front set to 1.75 and a 4 leaf pack.
    Does it look good or should I go back and have them do some changes?
