My tire carrier build [pic heavy]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, May 19, 2011.
  1. May 19, 2011 at 7:15 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Wanted something prerunner-ish but didn't want to give up too much bed space. I decided to build something that would be able to flip up in order to provide more bed space.
    This is my first fabrication project. Used a wire feed welder, chop saw, and grinder. The tubing is 1.5'' x .120 HREW. Between the tube, bushings, and tabs I think it came up to about $125.
    It can hold the tire in an up or down position. In the up position you can load the bed to the height of the bedsides without interference.
    Has two tabs for antennas (one for my CB, the other for my FM/AM radio [relocated due to fiberglass fenders]). The rear bed bar has two tabs for back up lights.
    First bed bar and initial "V" in place:
    Cross bar notched and welded in place:
    Tube notched for nut, rod threaded in for fit.
    Nut welded in place
    Rod cut, wings welded on to retaining nut:
    Carrier up
    Tire down:
    Tire up after maiden voyage. Filled up the bed of the truck with gear and went camping, offroading, hiking, and rock climbing in Colorado.
    So far so good, held up to the offroading just fine. I plan on putting some more tie down points in the bed and throwing a strap over it when it's in the down position.
  2. May 19, 2011 at 7:18 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Nice :thumbsup:
    I really need to find a good tire carrier!
  3. May 19, 2011 at 7:18 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    VERY NICE!
    I must admit I am a bit jelly
  4. May 19, 2011 at 7:32 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Couple more pics:
  5. May 19, 2011 at 11:26 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    wow :eek: your truck is sick
    that's my fav tire carrier so far!!!!!I'd like a tire carrier too, but when ever i'm offroad, i have my dirt bikes with me.. sooo i guess maybe Tire Gate? I'm not quite sure, maybe i'll fab up something of a bed extender but with the end of the extender acting as a swinging tire gate, that would get me to like a 7 foot bed about and then i'd have a gate there when a 250's back there
  6. May 19, 2011 at 11:59 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Looks good! I'm building one next weekend. Same kinda idea. Does it totally block the rear window when its up?
  7. May 20, 2011 at 12:07 AM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Looks really good, I like it.
  8. May 20, 2011 at 12:48 AM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    2016 4Runner
    Very nice!
  9. May 20, 2011 at 3:41 AM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    Pretty much. You can see a little, but not much.
    When it's down you can see pretty well.
  10. May 20, 2011 at 4:16 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    Nice set up.sweet truck
  11. May 20, 2011 at 6:34 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Great job!
  12. May 20, 2011 at 6:39 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    Are those three steel flaps not going to tear up the wheel when you tighten it down?
  13. May 20, 2011 at 8:40 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Looks good! I like how you made it modular
  14. May 20, 2011 at 9:55 AM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    I'm well past the caring about scratching up my wheel point. You'll notice the giant weld on the inside of that spare; that wheel cracked at one point and I had it repaired (and made it my spare).
  15. May 20, 2011 at 10:16 AM
    xJuice
    Josh
    North DFW
    07 DCSB Sport 2wd
    gotcha, just curious :)
  16. May 20, 2011 at 12:33 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    It does definitely grind as you crank down on it, but that wheel doesn't move at all. :D
  17. May 20, 2011 at 12:43 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Looks like mine nice!:)
  18. May 20, 2011 at 12:50 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    good job, i like that design
