My Towing Mirrors
Discussion in 'Towing' started by 05silverTaco, Dec 28, 2008.
  1. Dec 16, 2013 at 6:53 PM
    #101
    XRTherapy
    XRTherapy Active Member
    SCOTT, LA.
    TACOMA DCLB TSS EDITION
    NONE
    Have mine on order! Christmas gift!! This may be a stupid question, but are the blind spot mirrors on these adjustable as well? These have been a lifesaver for me in the past! Thanks!
  2. Dec 22, 2013 at 7:12 AM
    #102
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    The blind spot mirrors don't move independently. Move the big mirror, the small one moves with it.
  3. Dec 23, 2013 at 8:44 AM
    #103
    Bently
    Bently Active Member
    Scott
    2011 black tacoma
    fog lights installed tri fold tonneau cover Folding towing mirrors
    they move with the mirror.
  4. Feb 13, 2014 at 8:19 PM
    #104
    junkguydave
    junkguydave Member
    Dave
    Vancouver, BC
    Tacoma TRD
  5. Feb 13, 2014 at 9:21 PM
    #105
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner & 2017 SR
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
  6. Mar 19, 2014 at 8:20 AM
    #106
    G42
    G42 Well-Known Member
    Andreas
    Bellingham, WA
    2012 DCLB SR5
    Are you referring to these?
    http://www.1aauto.com/1A/Mirrors/Toyota/Tacoma/1AMRP01106/688914/2012
    And now that you've had them for a while - how do you like them? How elaborate was the install - it looks like you can just pop off the little triangular panel, with no need to remove the door trim - is that correct? Are they reasonably vibration-free? Field of vision about the same as the stock mirrors? Smaller or larger blind spot? Do they work pretty seamlessly with the adjustment switch? How's the fit of the external piece, and does it seal effectively? Any gotchas on install or use?
    I'm looking at a pair of these for my truck (heated sounds nice, but I'm not sure I'm up for buying the switch and doing all the wiring, or paying someone else to do it for that matter). $240 seems like a pretty decent deal if they're good quality - but would be an expensive lesson learned if these had bad quality glass, a huge blind spot, or started leaking water or didn't work well with the stock controls.
    Thanks,
    -Andreas
  7. Mar 28, 2014 at 8:46 PM
    #107
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  8. Mar 29, 2014 at 5:53 AM
    #108
    XRTherapy
    SCOTT, LA.
    NONE
    Wish I could just buy the driver's side mirror! Some awesome person in a parking lot completely folded my mirror forward(wrong direction)! Now it's all jacked up. Closing my door now, causes it to fold in and I have to manually move it back out each time I get into my truck... I guess the only bright side is that the glass didn't break and the electronics still work fine. Just a shame that there are people like that in the world!
  9. Apr 7, 2014 at 3:54 PM
    #109
    G42
    Andreas
    Bellingham, WA
    2012 DCLB SR5
    Took the plunge and ordered them. $240 for a pair of electric (but unheated) mirrors seemed like a pretty decent deal.
    Install took about 20 minutes - and that includes the five minutes I spent finding a video on youtube on how to pop off the inside trim on the door (which is required to get the bottom two of the three nuts).
    Mirrors fit well, outside trim piece looks stock. They're big; most people won't notice the difference, but they're definitely full-size truck caliber, rather than what you'd expect on a Tacoma.
    Electric adjustment works great, and they're as vibration free as the OEM mirrors at freeway speeds. Great field of vision, including the blind spot mirrors. And when you pop them out into two mode (I almost don't need to with me rather small pop-up travel trailer, as they're already as far out as stock mirrors plus the chintzy add-ons I was using before), they really shine.
    Glad I got them.
    -Andreas
  10. Apr 9, 2014 at 7:31 AM
    #110
    Bently
    Scott
    2011 black tacoma
    XR Therapy,
    That has happened to mine too, I just moved it back and forth and it popped back into place. Try this and i hope that it works for you.
  11. Apr 24, 2014 at 1:11 PM
    #111
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
  12. Apr 25, 2014 at 6:11 AM
    #112
    XRTherapy
    SCOTT, LA.
    NONE
    Thanks! I'll give this a try!
  13. May 21, 2014 at 6:45 AM
    #113
    Movnup
    Movnup Member
    Bryan
    Boise, ID
    05 DCLB SR5
    3" lift and tires but more to come.
    So I've had the mirrors from 1aauto for a while now and I love them but I did have to return one after folding it in when I was parked in a cramped parking lot. After I folded it in there was a pop and after that it would not stay in the normal position. It really sucked because I had my trailer and as I was cruising down the freeway for 3.5hrs my mirror was just smashed up against my driver side window.
  14. May 21, 2014 at 6:50 AM
    #114
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    You must have had a set from the 1st release of these. There was a batch that this did happen to and the manufacture has made changes to fix that problem.
  15. May 21, 2014 at 6:52 AM
    #115
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  16. Jul 17, 2014 at 10:45 PM
    #116
    gb42
    gb42 Well-Known Member
    Geoff
    WA State
    2016 MGM TRD OR DCSB MT
    Looking to buy a BSP driver's side power mirror guys, let me know if you have one to sell.
  17. Jul 27, 2014 at 9:13 AM
    #117
    Orfish
    Orfish Member
    Oregon
    TRD off-road
    Mine were easy to install, although the 2014 Off-road is NOT plug and play for the turn signal. They vibrate a bit in the down position, and hate to say COMPLETELY unusable in the flipped up position. Vibrate like a rabbit set on high. Can't use them. Down, however, they are usable, bit still vibrate a bit.
  18. Aug 1, 2014 at 10:00 PM
    #118
    mindleak
    mindleak Active Member
    Devin
    San Antonio, TX
    2014 V6 DC 4x4 TRD Off Road
    Fog light mod!
    Well that's upsetting. I was really tempted to pull the trigger on a set with turn signals. (actually was looking to get OEM mirrors with turn signals before I saw these) Sad to hear they're not plug and play... and that they vibrate.
  19. Aug 2, 2014 at 5:34 AM
    #119
    AEmedic
    Boise, ID
    I had the same experience with the vibration but my truck had turn signals in the mirrors already and was plug and play.
    They are sending me another set, I hope the vibrations are a fluke...
  20. Dec 5, 2014 at 8:40 PM
    #120
    Shook07Taco
    Shook07Taco Georgia Breed!!!
    Georgia
    07 Taco TRD
    smoked out headlight & tail lights, taco folding tow mirrors, 2.5in lift, 285x75x16in mastercraft courser mxt, touchscreen radio.
    I ordered a set of the taco folding tow mirrors like 2 monygs ago and I love them. I dont use them for towing anything bc I have nothing that big to tow to havw to have them. I ridewith them up all the time. I havent had any trouble with the vibrations. I got them mainly for looks and I tell you what, I get alot of attention bc of them. Ppl love them and compliment them daily lol.
