my truck died again!!!!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04coma, Jan 12, 2010.
  1. Jan 12, 2010 at 2:15 PM
    04coma
    04coma [OP] Well-Known Member
    Justin
    Temple Texas
    04 trd offroad sr5 prerunner debadged
    air aid intake and throttle body spacer billet grill clear corner lights and 3rdbrake decal "coma" :)
    my truck died again. if i dontrun it on break (20 mins) or lunch(30mins) then the battery dies out. i listen to the radio during these times one guy atwork told me it was my day time running lights can these be disabled?
  2. Jan 12, 2010 at 2:18 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    how old is your battery
  3. Jan 12, 2010 at 2:20 PM
    04coma
    Justin
    Temple Texas
    im not sure bought the truck last feb. still looks good and new i kno that doesnt mean anything tho lol
  4. Jan 12, 2010 at 2:38 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    autozone/advance/pepboys should offer free battery testing. get that done and report back.
  5. Jan 12, 2010 at 2:43 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    x2
  6. Jan 12, 2010 at 3:18 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    check the battery,the charging system, and for a draw
  7. Jan 12, 2010 at 8:28 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    with the truck running unhook the negative battery terminal if it dies check the alternator. if not it sounds like you are drawing power from some where obviously. start checking in the fuse block with the key off and see if you have any power anywhere.
  8. Jan 12, 2010 at 9:44 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I had the same problem, thought it was my piggyback, turned out I had a crack in the bottom of my battery.. damnit! LOL
  9. Jan 12, 2010 at 9:52 PM
    ColdZeroBSP
    ColdZeroBSP Yo homie, that my briefcase?
    Geoff
    Tewksbury MA
    2012 TRD Sport DC
    console vault, viper remote start, weathertech front and rears
    Also make sure you don't have any cell phone chargers or FM transmitters plugged into any power ports. My old truck died after 2 days of sitting in the driveway b/c I had a charger plugged in. Seems dumb but it actually draws a lot of amps, especially if the charger is faulty.
  10. Jan 13, 2010 at 11:15 AM
    rkd1119
    rkd1119 Well-Known Member
    Robert
    L.A. (lower Alabama)
    ‘23 Trail Edition Ice Cap
    :confused:How would this happen?
    None of my ports have power when key is off.
  11. Jan 13, 2010 at 11:46 AM
    blackxpress
    blackxpress Well-Known Member
    Jeff
    Carlisle, OH
    98 SR5 2WD Xcab
    I've always been told that you should NEVER disconnect a battery cable while the engine is running. The resulting voltage surge can fry your ECU.
  12. Jan 13, 2010 at 11:47 AM
    ak47
    Anthony
    Washington
    stock 2nd owner
    ^^ never heard that. i'll have to look it up and find out if your right. ive done it in several cars and never had a problem tho
    Maybe some input from Chris4x4??
  13. Jan 13, 2010 at 12:34 PM
    ColdZeroBSP
    Geoff
    Tewksbury MA
    2012 TRD Sport DC
    I forgot that Toyota has intelligent engineers. My fault, my last truck was a GMC.
  14. Jan 13, 2010 at 12:41 PM
    mx04taco
    mx04taco Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    Dont do this!!!!! In newer age vehicles it will cause voltage spikes that will fry computer modules in the vehicle. You can really only use this technique with much older vehicles. I'm a technician by trade and this is something they pound into your heads whenever you are in tech school. If you start your truck and the truck runs fine once you get it started its not your charging system. Definitely get your battery tested, I am willing to be that your battery is toast.
