My truck has a tapping noise.... Some say this is normal?
Discussion in 'Technical Chat' started by Nolazach, Sep 10, 2011.
  1. Sep 10, 2011 at 12:11 PM
    Nolazach
    Nolazach [OP] Well-Known Member
    New Orleans
    An ARE camper shell, a 1000w power inverter.
    From the beginning I thought my 4.0 L v6 was noisy.
    I chalked that up to being "a Toyota thing", as I remember a friends Camry also having a loud engine.
    But now there is a noticeable Diesel sound. Reading around on the net I have seen this problem be called normal, and have seen others say it was fixed with a spark plug and oil change/flush. I know I need an oil change as I just ordered filters from eBay (Toyota brand). But I guess I'll replace the plugs to see. I just hope and pray I'm not looking at needing a top overhaul. I mean at 106,000 miles a Tacoma is still like new.
  2. Sep 10, 2011 at 12:13 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Your not going to get rid of the Tacoma tick, some say you can reduce it, nothing really seems to help. You learn to tune it out after a while.
  3. Sep 10, 2011 at 12:22 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  4. Sep 10, 2011 at 12:43 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Mine only has 2500 miles & sounds like that....no worries.
  5. Sep 10, 2011 at 1:51 PM
    Nolazach
    New Orleans
    I went out just now to check it with the stethoscope and don't hear anything beyond the normal loud engine sound.
    Its strange. But if it was a mechanical problem, I would hear the noise constantly.
    The service records show a tune-up a little over 10,000 miles ago. Previous owner had them changed at 29,650, 61,380, and 90,750.. All work ever done on the truck was done at two Toyota dealerships. I have all the records. Cleanest vehicle I ever bought used. But I'm used to much quieter engines.
    Maybe I need hood insulation...
  6. Sep 10, 2011 at 1:53 PM
    Nolazach
    New Orleans
  7. Sep 10, 2011 at 6:05 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yes, there are things you can do to quiet it down.
    There is also an exhaust manifold update you can have done while under warranty. Looks like you are past that. If it were me I would drive it and be happy.
    This engine does not have hydraulic lifters and will always have some valve noise.
  8. Sep 10, 2011 at 8:47 PM
    Nolazach
    New Orleans
    what was wrong with the exhaust manifold in the first place?
    I need to look at an engine diagram, I have no idea whats inside the heads.
  9. Sep 11, 2011 at 9:13 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I think they replace the manifolds with ones made out of thicker metal. The sound is being transmitted through the thin exhaust manifolds.
  10. Sep 11, 2011 at 1:52 PM
    Nolazach
    New Orleans
    would aftermarket headers fix this or make it worse?
  11. Sep 11, 2011 at 2:02 PM
    joes06tacoma
    Joe
    Central Coast, CA
    No idea on the sound, the question I would be asking is how do you reinstall the two pre cats that are part of the manifolds. And would it pass smog if you pulled them out for good. I know it would set a check engine light.
  12. Sep 11, 2011 at 2:10 PM
    Nolazach
    New Orleans
    oh probably with a O2 emulator flash on the PCM. We don't have emissions testing..
    But I'd rather keep it stock, just wish there was a better fix for the ticking noise.
  13. Dec 26, 2014 at 9:33 AM
    09redtac
    09redtac Member
    4x4 off road trd
    Took care of the problems...took it in and traded for a new one. I can't stand the engine noise like "it's going to take a dump on you when you need it the most."
