my truck seems sluggish :(
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacos89, Sep 16, 2010.
  1. Sep 16, 2010 at 9:33 PM
    tacos89
    tacos89 [OP] Well-Known Member
    Mout Holly NC
    2007 TRd Sport
    Intake
    okay i have been driving aroud and my truck has been seeming sluggish. like it doesnt have the power that it used to.....
    okay i just went to go eat at in n out and my check engine light just went on :(
    sweet!
    does anyone have a clue on whats wrong with my baby? haha
  2. Sep 16, 2010 at 9:35 PM
    tacoma92
    tacoma92 Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    have u changed out ur timing belt? O2 sensors?
  3. Sep 16, 2010 at 9:38 PM
    tacos89
    Mout Holly NC
    2007 TRd Sport
    Intake
    no not since like last year haha
    maybe thats the problem
  4. Sep 16, 2010 at 9:47 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Timing belt is not going to cause your truck to be sluggish. It's sluggish cause your check engine light is on, there's a fault & your ECU is in limp mode. Get your truck scanned, find out what code it is. Have it reset to see if it trips the check engine light again. If it does, fix whatever is causing that code.
  5. Sep 16, 2010 at 9:53 PM
    tacoma92
    Forrest
    Yea if it's only been year it wouldn't be a problem. Jus get it checked out. Ur check engine light won't come on for no reason. Plus some toyotas have minor transmission issues too.
  6. Sep 16, 2010 at 10:02 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    OK, I had my timing belt on a civic slip 3 teeth. Engine started to run sluggish and finally a day later the light came on. Had codes for all sort of things. clear the light and then a day later it came back on. This time it was a code for something else......
    ended up removing the head and found the belt had slipped.
  7. Sep 16, 2010 at 10:09 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    With valve timing thrown off like that, yes. Your lucky only a few teeth depending on what motor you have. I used to be a Honda mechanic. What caused your timing belt to slip like that? Those instances just don't commonly happen unless it was recently touched or the belt was long overdue for replacement.
    OP stated he got his belt done only a year ago so the chances of his belt skipping some teeth is not very likley unless it wasn't put on correctly or a bad tensioner was not replaced at the time.
    But I guess anything could happen. Best thing to do is to find out what code it is.
  8. Sep 17, 2010 at 2:47 AM
    tacos89
    Mout Holly NC
    2007 TRd Sport
    Intake
    yeah thanks too all. im going to go get it scanned tomorrow.
    also i think i might have put to much oil in my mortor :( maybe thats the problem too? ahh oh well ill see what the deal is tomorrow. hopefully its not super expensive :eek:
  9. Sep 17, 2010 at 6:08 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Seafoam the crap out of it. Maybe your butt dyno will feel better.
  10. Sep 17, 2010 at 6:09 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  11. Sep 17, 2010 at 7:49 AM
    brelandt
    Terry
    Dublin, CA
    I had replaced the belt. Drove it for a month or so. Don't know how many miles had gone by but I think it was the tensioner that failed. aftermarket parts. I was getting codes for all sorts of things,,, EGR,,,misfaire in only one bank at a time,,, misfire on all banks,,,different sensor failures,,,it's amazing all the things that show up when your timing is off! LOL
  12. Sep 17, 2010 at 7:55 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    On an 01 Taco I owned I had a sluggish problem. I would press the gas and the truck didn't want to go. Thought it could be the clutch, but that wasn't it. Turned out to be my cat was clogged up. Fixed that and the truck ran great. Don't know if your having the same problem but you could check the cats and see. Good Luck!
    TacoMan89 likes this.
  13. Sep 17, 2010 at 10:26 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    OP, did you change both O2 sensors at the same time?
  14. Sep 17, 2010 at 11:33 AM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    kinda sounds like my problem, but i hear a flowing rattle in the exhaust, its gotta be the cats or muffler right?
  15. Sep 17, 2010 at 11:47 AM
    Toyotacrawler
    Cusseta/Opelika AL
    I would think it would be the cat. Definitely worth checking it to find out.
  16. Sep 17, 2010 at 11:50 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    How would one check this out aside from completely removing? Is or isn't welded in?
  17. Sep 17, 2010 at 11:56 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Well to be honest the muffler guy I took it to just tapped on it and could tell. Maybe it was a lucky guess for him but he was right about it in the end. If I remember correctly on the 01 there was a flange just after the cat and the exhaust could be removed so that you could look at the inside of the cat.
  18. Sep 17, 2010 at 2:24 PM
    tacoma92
    Forrest
    Thts the sound my timing belt was making before I got it replaced.the water pump was messed up and I kept hearing tht rattle noise bc the belt was messed up on it
  19. Sep 17, 2010 at 3:32 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I'm putting my bets on either clogged cats...dirty injectors...or fuel filter...
  20. Sep 17, 2010 at 4:03 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Since everyone is just pulling diagnosis out of thin air, I'm going to go for the banana in the tailpipe. Either that, or the modial interaction of magnetoreluctance and capacitive directance isn't generating power for his turbo encabulator.
