my truck wont start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acryloman, May 6, 2008.
  1. May 6, 2008 at 4:20 PM
    acryloman
    acryloman [OP] Member
    Ive got a 2005 v6 that was running fine 2 hours ago. Now it wont start. It just turns over and over with no fire. Is there some kind of sensor or main fuse that would cause this. Any help would be greatly appreciated.
  2. May 6, 2008 at 4:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im guessing that its the battery. either use a volt meter or take it to autozone and get it checked.
    do you have the six speed manual, or the 5 speed auto?? the more i think about it, doesnt sound like the battery......sounds like you may not be getting fuel.
  3. May 6, 2008 at 4:35 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Battery.
  4. May 6, 2008 at 4:38 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    NOT battery if it's cranking. Did you flood it? Sit in the truck and hold the gas pedal to the floor for about 2 minutes THEN try starting while holding pedal HALF throttle.
  5. May 6, 2008 at 5:36 PM
    acryloman
    I think the fuel is the problem. I'm hoping its the fuel pump relay but it might be the pump itself. has anyone had any problem with the fuel pump relay?
  6. May 6, 2008 at 5:38 PM
    acryloman
    tacomaman06, how did you get the secondary air filter out. Did you just break it? Did you see any benefits? Mines filthy and needs to come out. It seems like breaking it is the only way.
  7. May 6, 2008 at 5:40 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Did you try my idea?
  8. May 6, 2008 at 5:43 PM
    Charli
    Charli Stealer of Souls
    Chuck?
    Ohio
    '06 Black Sand 4X4 SR5 TRD Sport V6 Access Ca
    Towing pkg with Mossberg hitch cover, Toyota tube steps, 3" Toytec lift and TSB, 1" diff drop, Tacoma World sticker, sockmonkey decals
    I don't know if this would be applicable to the 2nd gens, but at one point my old 2000 wouldn't start--turned out to be a blown fuse for the brake light. Since the brake light wouldn't come on, nothing worked. Or maybe that was it wouldn't get out of park; it's been awhile so I don't remember accurately, but I thought I'd throw it out there--lots of odd safety backups that could contribute to why it won't start in addition to the obvious stuff.
  9. May 6, 2008 at 5:44 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    check your fuse box.... go from smaller to bigger.....
  10. May 6, 2008 at 5:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i took my airbox off my truck, then i drilled out the plastic rivets holding the filter in, then i vacuumed the airbox out incase there was any plastic shavings. real easy to do. i didnt see any big changes, but truck seemed to idle better.
  11. May 7, 2008 at 5:46 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    My old 05 pre-runner used to do that once in awhile, there was a fix for mine they have to flash the ECU. Mine would start just not on the first stab, I would have to turn the key totally off and then try to start it and it would start.
  12. May 7, 2008 at 7:55 AM
    acryloman
    What does flash the ecu mean? Im really starting to think this is elecrical or computer related.
  13. May 7, 2008 at 8:04 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Flashing the ECU is basically reprogramming the computer. The dealer will need to do this.
  14. May 7, 2008 at 9:43 AM
    Burns
    17 DCSB Off-Road
    Sorry about that, thanks Isocoee for clearing that up. :thumbsup:
  15. May 8, 2008 at 11:39 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Could still be the battery even if it's cranking... I've had engines that would crank, but not fast enough to spin everything over to start. In fact, my truck did that twice when the battery was drained too low. Hook up a charger or some jumper cables, give it some more power, and then try starting it up again.
    So much of these trucks are electronic now that if all the computers don't get enough power, then things are bound to stop working.
    If it's a manual you could also pop start it, let it run for a few minutes, shut it off, and see if it starts back up.
  16. May 8, 2008 at 12:13 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You do know that you have to add gasoline to these things every now and then, right? ;)
    Along the lines of the battery thing, the way I used to test for a weak battery was to turn on the high beams and honk the horn simultaneously with the vehicle not running. Both draw a fair amount of current and if the battery is weak the lights will dim and/or the horn will sound pathetic. If the battery is good then things will work properly.
    It's a quick, easy test and might be worth a try.
  17. May 9, 2008 at 10:32 AM
    acryloman
    My problem lies in the fuel pump. And its an expensive part!
  18. May 9, 2008 at 12:54 PM
    Charli
    Chuck?
    Ohio
    Ugh. It's never the easy cheap thing is it? You're out of warranty by now I'd guess? Seems awfully soon for the fuel pump to crap out though.
  19. Oct 22, 2008 at 10:51 AM
    Kennyu
    Kennyu Member
    Texas
    07 pre-runner
    Dude,
    Mine did the same thing... twice.
    Take it in and they will re-flash the computer.
    There is an official Toyota service bulletin on this exact thing. They know about it.
  20. Oct 22, 2008 at 12:38 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    does it happend to my 09 tacoma??? Dont scare me man!!!
