My trucks measurements from ground to fenders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sfoxwoody, Jun 26, 2012.
  1. Jun 26, 2012 at 6:30 PM
    sfoxwoody
    sfoxwoody [OP] Well-Known Member
    Calhoun, Ga
    05 TRD Sport, 4x4, BSP, LB
    none yet
    Ok, so I just ordered a front set of 5100's from DSM, now I'm trying to figure out what size AAL for the rear to get so I went and measured my truck from the ground to the bottom of the fender flare in the front and then the back. This is what I have, front - 34 1/2" and back - 36 1/2", is this about right, it seems higher than normal in the back to me? Also it doesnt have TSB done and its a three leaf pack. If I set the 5100's at 1.75 and do nothing to the back it should sit about level, right? I was really wanting to put a 1.5" AAL for towing purposes but I dont want the back to sit too much higher than the front and I realy wanted to stay away from the 2.5 setting on the fronts because I'm using stock springs and the allignment issues I've read about. What should I do?
  2. Jun 26, 2012 at 6:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    if you get the AAL, the truck wont be any higher than the front, than it is now. If you want it level, no AAL. If you tow often, and dont want the nose in the air when towing, get the AAL.
  3. Jun 27, 2012 at 6:29 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    This should help you. I did this back when I installed my 5100s. Changes to the rear were the result of the Wheelers 1.5" AAL (with my 3-leaf pack).
  4. Jun 27, 2012 at 7:24 AM
    badger
    badger Well-Known Member
    07 SR5
    Just an FYI: A much better, comparable, and consistent measurement to take is from hub center to fender lip. When you measure from the ground you introduce all kinds of variables and inconsistencies.
  5. Jun 27, 2012 at 7:44 AM
    05Moose
    Jim
    Agreed, so long as you're interested in height. In my case, I just wanted to know the "difference" in height between stock and the various settings. Those variables (tire size and inflation) don't impact the "difference" measurements. Those differences can be applied regardless of tires.
