My turbo tacoma project
Discussion in '2nd Gen. Builds (2005-2015)' started by KirkRio, May 14, 2016.
  1. Nov 30, 2016 at 9:35 AM
    #181
    KirkRio
    KirkRio [OP] taco taco burrito burrito
    Kirk
    Wesley Chapel, FL
    2005 Tacoma SR5 PreRunner
    ChadsPride likes this.
  2. Nov 30, 2016 at 9:43 AM
    #182
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    Aside from the cool factor, why is a turbo that much better than a supercharger? Is it more efficient? Similar power gain with better mpg? What is it about the turbo that offsets the drawbacks (lag, heat issues, complexity)? I'm not very knowledgable about FI, so I'm trying to understand why y'all seem to consider this so superior to a SC setup...
  3. Nov 30, 2016 at 9:46 AM
    #183
    KirkRio
    Kirk
    Wesley Chapel, FL
    Turbochargers are driven by wasted energy (exhaust gases) as it exits the engine. Superchargers are driven mechanically by means of a belt which is usually attached to the crank pulley. In short, they consume energy to make energy.
  4. Nov 30, 2016 at 9:46 AM
    #184
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    More efficient, and can make wayyyy more power than a supercharger. and turbo lag can be minimized or non existent with a properly sized turbo
    GDT[QUOTED] and ChadsPride like this.
  5. Nov 30, 2016 at 9:49 AM
    #185
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    yes ish. a SC can only spin as fast as a belt and that is where boost stops, a TC that is sized correctly can make about as much boost as a motor can handle, and its pretty easy to adjust the boost on it (by changing wastegate spring or adding a boost controller or both), there is also much less parasitic effect from a turbo and that is usually negated completely since what little back pressure a turbo add is usually taken out of the stock exhaust system since it is completely replaced.
  6. Nov 30, 2016 at 9:53 AM
    #186
    KirkRio
    Kirk
    Wesley Chapel, FL
    With a properly sized turbo on our trucks (1.5-2:1 BP) lag is not an issue. My truck sees 8psi before 2,000RPM
    GDT and ChadsPride like this.
  7. Nov 30, 2016 at 9:55 AM
    #187
    yota243
    E.J.
    north Alabama
    holy crap man what do you do on the interstate? woooooooooooooshhhhhhhhhhhhh psffft
  8. Nov 30, 2016 at 9:56 AM
    #188
    KirkRio
    Kirk
    Wesley Chapel, FL
    My turd sounds like a diesel chugging along the interstate. Obviously its dependent on throttle, but as soon as it sees any load the turbo is doing its thing.
    yota243 and ChadsPride like this.
  9. Nov 30, 2016 at 12:50 PM
    #189
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    BP?
  10. Nov 30, 2016 at 12:53 PM
    #190
    KirkRio
    Kirk
    Wesley Chapel, FL
    Back pressure
  11. Nov 30, 2016 at 12:59 PM
    #191
    MadTaco461
    CA
    Kinda stock
    Thanks. Got some reading to do now
    5 Lug Fury and ChadsPride like this.
  12. Dec 21, 2016 at 10:17 AM
    #192
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  13. Dec 21, 2016 at 10:51 AM
    #193
    KirkRio
    Kirk
    Wesley Chapel, FL
    Daily driving it, 5K miles and counting without a single major issue. I am going to put together a new wastegate actuator as the one on the truck now is kind of flaky. Been meaning to do that the last couple of weeks but I have very little time around this time of the year to tinker with my stuff
  14. Dec 21, 2016 at 10:53 AM
    #194
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah, I bet you guys are busy. Good to hear that all is running well. :thumbsup:
    Now about that dyno.... ;) :stirthepot:
  15. Dec 21, 2016 at 10:54 AM
    #195
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Can you get a video, I want to see this interstate driving...:bananadance:
  16. Dec 21, 2016 at 11:03 AM
    #196
    yota243
    E.J.
    north Alabama
  17. Jan 22, 2017 at 1:21 PM
    #197
    KirkRio
    Kirk
    Wesley Chapel, FL
    Been MIA but I didnt forget about the truck! I replaced the actuator with one of TiAL's MVI internal actuators so hopefully it will give me way better boost control than the last one. Haven't driven the truck in a while since I finished another project which I have been tinkering on for a while, but I will go back to daily driving the truck in a week to dial it in again
  18. Jan 22, 2017 at 2:16 PM
    #198
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Welcome back! Lol.
    I have looked any time soon, so that is a new device to me.
  19. Apr 12, 2017 at 8:37 AM
    #199
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any updates going on in here? Truck, or other?
  20. Apr 12, 2017 at 9:03 AM
    #200
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Im here for burnout videos with turbo sounds
    :anonymous:
    5 Lug Fury, yota243 and ChadsPride like this.
