My turbo tacoma project
Discussion in '2nd Gen. Builds (2005-2015)' started by KirkRio, May 14, 2016.
  1. Jul 3, 2016 at 4:45 PM
    #61
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    #61
    MadTaco461 likes this.
  2. Jul 3, 2016 at 4:57 PM
    #62
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Awesome build :thumbsup::thumbsup:
  3. Jul 3, 2016 at 5:55 PM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's funny abiut the emoji.
  4. Jul 4, 2016 at 8:46 AM
    #64
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    EBay emojis give you 20hp on top of the turbo.
    #64
    Torspd likes this.
  5. Jul 4, 2016 at 8:53 AM
    #65
    weldo
    Pittsburgh, pa
    lol, how about that product tho? A small electric blower to make a phony blow off valve noise?! I guess people buy that stuff or it wouldn't be manufactured...
  6. Jul 5, 2016 at 8:51 PM
    #66
    thebstell
    thebstell Brandon
    Brandon
    Oceanside/Redlands,ca
    2007 single cab
    Camburg fron LT kit, Giant SUA kit on bypasses.
    following
  7. Jul 8, 2016 at 6:05 PM
    #67
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    subbed for turbo 2.7 tacoma
  8. Jul 11, 2016 at 12:16 AM
    #68
    FPpanchhh
    FPpanchhh Well-Known Member
    Francisco
    Los baños CA
    2005 Tacoma RC
    King coilovers, all pro leafs, bilstein 5160
    Any updates?
  9. Jul 12, 2016 at 7:08 AM
    #69
    KirkRio
    KirkRio [OP] taco taco burrito burrito
    Kirk
    Wesley Chapel, FL
    2005 Tacoma SR5 PreRunner
    Well nothing exciting here as I have been swamped with work, but I've been daily driving the truck with the MAP ECU3 and the tune is on point. No check engine lights, no hiccups, no smells, nada. It drives like stock with a little bit more pep (Only running 4.3psi). Once I get some free time I will begin cutting and making the intercooler piping so I can turn the boost up and let it party a little more!
  10. Jul 12, 2016 at 7:47 AM
    #70
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Means you've done good tuning then. :thumbsup:
    I just wish the Map-Ecu 3 could control the throttle, which would eliminate the speed limiter throttle close.
  11. Jul 12, 2016 at 7:50 AM
    #71
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which size injectors are you currently running, and plan on running?
  12. Jul 12, 2016 at 4:06 PM
    #72
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Kirk I gotta know as I am interested in same kit. This kit was just bolt up and go? No mods to ecm and NO detonation? 4-5 boost is all I want!
  13. Jul 12, 2016 at 4:14 PM
    #73
    KirkRio
    Kirk
    Wesley Chapel, FL
    The kit was as far to bolt on as any kit could go. I do not recommend it, its basically a box of cheap chinese parts in a box with a semi decent manifold.
    Torspd likes this.
  14. Jul 12, 2016 at 7:06 PM
    #74
    sawed off
    Randy
    Idaho
    So if I bought the manifold only, then good quality other parts I could run 5 pounds of boost with NO issues?
  15. Jul 30, 2016 at 6:49 PM
    #75
    KirkRio
    Kirk
    Wesley Chapel, FL
    So... I will post more details tomorrow since I'm at dinner, but I got permission from my better half to go to the shop and finish my piping. Here's a shitty shot for now.
  16. Jul 30, 2016 at 9:34 PM
    #76
    weldo
    Pittsburgh, pa
    So rad!
  17. Jul 31, 2016 at 4:59 AM
    #77
    KirkRio
    Kirk
    Wesley Chapel, FL
    Okay, so the boss lady had plans yesterday so she gave me the blessing to go work on the truck since I've been putting it off for a few weeks. I started by cutting and making the room needed for the intercooler piping. From there I realized I needed to clock the turbo housing to properly route the cold side. While doing that I found that the wastegate arm has been binding up in the housing the entire time (typical china junk). Needless to say, each time I work on the truck I end up replacing more and more of that "kit".
    wastegate in closed position
    Binding up while opening
    So instead of wasting any time on trying to fix this chinese junk, I ended up scrapping it used a real OE Garrett GT28 housing that I had laying around.
    MUCH BETTER
    And as always, one things leads to another, the China T28 does not have the same bearing housing register as a GT28, so I ended up building myself a ball bearing GT2867R CHRA using the compressor wheel that came in the china turbo but everything else is real Garrett OE.
    This is now scrap metal
    My new GT2871R CHRA for the truck came together nicely:
    Awwww yisssssss!
    NOW I was able to get to the fun part. Welding.
    Finished cold pipe with TiAL BOV flange
    Finished MAF pipe
    Finished product
    I was able to drive the truck home last night, but the factory ECU does not like the BOV venting to atmosphere. I might either try to move the MAF to the intercooler piping to run as a blow-through setup after the BOV, or just use a recirculating TiAL BOV instead and plumb back to the intake.
    Next would be turning the boost up and adjusting my fuel injector size as necessary, have not figured out which ones to go with yet.
    In short, don't bother buying that POS chinese kit unless you want to redo everything and have an understanding of how it all works. Majority of the parts have ended up in the trash can.
    bsp_taco, RedLantern and Torspd like this.
  18. Jul 31, 2016 at 5:03 AM
    #78
    weldo
    Pittsburgh, pa
    I just have one question... Who took this picture?!
    lol, great work dude! It's a bummer that the only turbo kit out there for this motor is so crappy.
  19. Jul 31, 2016 at 5:05 AM
    #79
    KirkRio
    Kirk
    Wesley Chapel, FL
    I use a selfie stick............. hahaha. My girl came by to feed me after she got her nails done. It ended up turning into an all-day affair after I found the issues with the turbo
  20. Jul 31, 2016 at 8:30 AM
    #80
    weldo
    Pittsburgh, pa
    lol, that's a good woman you got there, stoppin' by to feed you! Cool project, too!
    Does it have significantly more power, like especially on the highway pulling up a long gradual hill?
