My version of the Honda S2K Antenna mod...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EquinsuOcha, May 30, 2009.
  1. May 30, 2009 at 9:50 AM
    EquinsuOcha
    EquinsuOcha [OP] Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    05PreRunner recently brought it to my attention that a Honda S2000 antenna could be put on the Tacoma. And it fit in perfectly with my Amalgam theme.
    The original thread he showed me is here.
    But that seemed like too much work for me, so I came up with an easier way.
    You will need:
    A pair of pliers
    JB Weld
    Chopsticks from "Golden Chopsticks Chinese Food" (for mixing the JB Weld)
    Threaded Rod, Size SAE Fine #10-32 x 36" (or shorter if you can find it, you need about 4")
    Two nuts, 8mm, fine threads
    Hand saw with metal-cutting blade (or a Dremel with a cut-off wheel)
    Honda S2000 antenna.
    First, remove the Honda screw base. I just pulled out on it with a pair of pliers. It's the gold part in the picture:
    Here it is completely removed:
    Then I went and got two nuts that would fit in place of the Honda screw base. I mixed up some JB Weld and put a little inside the antenna where the original screw base came from, and then set the two nuts in:
    Next, take your threaded rod and cut off about 4" from the end:
    Here's what I ended up with:
    Then simply screw the piece of threaded rod into the nuts inside the antenna. The antenna is soft rubber, so the rod will thread itself into the antenna. Leave about 1" to 1 1/4" so the antenna will sit flush on the Tacoma's antenna base. I added a little dab of JB Weld where the nuts meet the threaded rod just to make sure nothing ever vibrates loose.
    Finally, just screw the antenna onto the truck!
    Thanks again, Noé, for the idea!
  2. May 30, 2009 at 10:19 AM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2008 double cab, 4X4, V-6, TRD. Super White.
    OME 885 coils & front shocks, with TT top plate, Total Chaos UCA, Rear OME extended shocks, Rear TSB, Rear Toytec AAL, trimmed the saber-tooth-tiger-long-ass mud flaps. 17" XD Revolver rims, 265/75/17 BFG AT KO's. Ripped out the crappy FM Modulator & installed a PA-15-toy interface. OEM bed matt.
    That is slick:D:D:D:D
  3. May 30, 2009 at 10:41 AM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    mine ended up coming off at a car wash:( .... i may be trying your write up sometime in the future...
  4. May 30, 2009 at 11:38 AM
    EquinsuOcha
    Casey
    Ft Worth, TX
    07 PreRunner
    Damn. Well, at least with throwing the JB Weld on there, you know it isn't going anywhere!
  5. May 30, 2009 at 12:24 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    How's the reception with the new antenna?
  6. May 30, 2009 at 12:26 PM
    EquinsuOcha
    Casey
    Ft Worth, TX
    07 PreRunner
    I have no idea. I don't ever listen to the radio...isn't that a shame? Something that's essentially free, and I turn it down...:rolleyes:
    Edit: I just got back from outside, and the reception is only slightly worse than with the stock antenna.
  7. May 30, 2009 at 5:51 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Pretty cool dude. I like it.
  8. May 30, 2009 at 10:46 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
  9. May 30, 2009 at 11:00 PM
    EquinsuOcha
    Casey
    Ft Worth, TX
    07 PreRunner
    Wow! That is TINY!
    (that's what she said)
  10. Jun 16, 2009 at 5:09 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Cool but I like mine hitting every ceiling beam in the parking garage @ work, lol.
  11. Apr 26, 2010 at 5:15 AM
    LaTeM
    LaTeM Everyday Trollin'
    MeTaL
    Jersey Shore, NJ!!!
    '10 4X4 Lifted 4Dr Pre-X-Runner
