My Wallet's Black Hole
Discussion in '3rd Gen. Builds (2016+)' started by Colorado Crawler, May 6, 2018.
  1. May 6, 2018 at 6:32 PM
    Colorado Crawler
    Colorado Crawler [OP] Well-Known Member
    2017 Black Tacoma TRD Off-Road
    2017 Black Toyota Tacoma DCSB TRD Off-road Auto
    Most Recent Photo - April 2019
    First Trail Photo - September 2017
    ELECTRICAL & ACCESSORIES
    -sPOD Bantam
    -ARB OBA Compressor (CKMA12)
    -PowerTray (sPOD & ARB Compressor Mount)
    -Car Solutions front and rear anytime camera kit with NATIKA front Camera
    LIGHTING ACCESSORIES
    -MESO Customs Side Mirror Turn Signals
    -IMPORTequipment Dark Gray Backup Light Overlay
    -Morimoto H11 HID Elite Low Beams
    -Morimoto Fog Lights
    -Rigid Ignite (additional reverse/rear facing lights)
    -Extreme LED Rock Lights (8 lights) (Swapped out the ColorMorphs)
    -Extreme LED Extreme 40” Single Row LED Light Bar (Combo Spot and Flood)
    -Rigid Scene Light x 2
    EXTERIOR
    -TRD Pro (eBay) Grill
    -Diamondback SE Tonneau Cover
    -Diamondback 8” Cross Bin
    -Prinsu CabRack
    SUSPENSION, WHEELS & TIRES
    -ToyTec BOSS Suspension System
    -SPC Adjustable Upper Control Arms
    -Cooper STT Pro 285/70/17 x 5
    -FN Wheels FX Pro x 5
    -IMPORTequipment Center Cap "TRD" stickers
    -Firestone "Ride-Rite" Air Bag Helper Springs
    -Daystar KU09140BK Helper Spring Cradle
    -Air Lift WirelessONE Manifold - 2nd Generation
    MISC
    -HondoGarage Mount (iPhone)
    -Tacoma OEM Bedmat
    -Husky Xact-Contour Floor Liners Front and Rear
    -Pop-n-lock Tailgate Lock
    -MESO Customs Extended Height Fuse Box Cover
    Doogle, Rat_Bastard and felix1776 like this.
  2. Jul 20, 2018 at 2:26 PM
    Colorado Crawler
    sPod Bantam and ARB single CKMA12 Installed. Added a Blue Sea 285-Series Circuit Breaker 100 Amp for extra protection and an easy way to disconnect all accessories tied to the Bantam
    The goods
    First Iteration. Ordered a blank PowerTray to mount the ARB compressor and Bantam. I think it came out clean.
    PowerTray blank template after drilling holes
    Screen mounted inside using Ram mounts
    Looking into the cubby
    Backside of the cubby. Bolts are for the base of the Ram ball mount.
    Added some rubber grommets and added the rear lights and puddle lights
    Blue Sea circuit breaker mounted under the PowerTray
    Rear facing/reverse lights are triggered automatically when put in reverse. Also switch controlled with the Bantam.
    Puddle lights are triggered from the dome light to go on when unlocked, locked vehicle is approached with key fob, etc... Also switch controlled with the Bantam. This was pretty tricky due to the way the Tacoma dome light wiring is setup. Did have to use a relay to reverse polarity for the reverse trigger and had to use a diode on the dome trigger to prevent my dome lights from then going on when put in reverse. John at sPod was super helpful working with me to figure it out.
    Also added an ignition trigger to allow the compressor to run only when the accessory system is on/ideally when the truck is running...
    Will add more pictures of the puddle lights and reverse light installs soon.
  3. Jul 20, 2018 at 2:35 PM
    Colorado Crawler
    Lift, wheels and tires. Details are in the first post.
    Dustin at FN Wheels. Great customer service.
  4. Jul 20, 2018 at 2:37 PM
    Colorado Crawler
    IMPORTequipment stickers
    Before
    After
  5. Jul 20, 2018 at 2:39 PM
    Colorado Crawler
    Cool pano in an aspen grove during the last camping trip
    Loaded up and headed home. Tried on a little quicksand paint;) Super dry out here this year.
    Apexgigi likes this.
  6. Jul 21, 2018 at 8:16 AM
    Colorado Crawler
    Problem solved. Thanks @mesojdm.
    Like a glove
    MESO likes this.
  7. Jul 22, 2018 at 2:14 PM
    Colorado Crawler
    Reverse/rear facing lights installed. Rigid Ignite diffused. Lights are wired into the sPOD Bantam. The Bantam uses a trigger wire from the stock reverse lights to control and automatically turn on lights when shifted into reverse and they can also be switched through the sPOD. Lights are really bright and nice for backing up at night with the tinted windows. Also provides tons of light for setting up in the dark or those night rides.
    Super tight behind the bumper. Only two possible spots to mount unless you really cut into the support in the bumper.
  8. Jul 22, 2018 at 2:25 PM
    Colorado Crawler
    Puddle/rock lights, whatever you want to call them. Wired into the Bantam and switched automatically through the dome light. Can be manually switched or will come on when door is opened, unlocked or locked vehicle is approached with key. Pretty cool in dark parking lots or out in the middle of nowhere camping. Will probably switch out for all white kit instead of RGB. Red is pretty cool at night but that’s about it. I never use the color changing stuff.
    Front driver side mounting
    Under driver door. Made some mounting brackets out of scrap. I like this better than drilling into the frame right here and it keeps it up pretty high.
    Under driver side rear door
    Rear light up under behind the rear bumper.
    Drilled into frame support.
    Light output in the garage
    Edit: swapped out the kit for the Extreme LED kit. Much happier with the all white.
    Rat_Bastard likes this.
  9. Jul 23, 2018 at 9:27 AM
    wingnut25xp
    wingnut25xp Member
    Dustin
    Awesome looking truck! I’m thinking about going with a similar suspension/tire set up as you. How does the boss kit ride on road compared to stock? Thanks!
    Colorado Crawler [OP] likes this.
  10. Jul 23, 2018 at 12:51 PM
    Colorado Crawler
    Thanks! I like the kit overall. I definitely should have considered an add-a-leaf or maybe some heavy duty leaf replacement because the last camping trip I was practically riding on the bump stops when completely loaded up. On road the ride is a bit stiffer than stock and the additional height contributes to additional body roll but other than the issue when hauling around a bunch of extra weight, I am pretty happy with it.
  11. Mar 9, 2019 at 8:09 PM
    Colorado Crawler
    Installed front/rear anytime camera.
  12. Apr 3, 2019 at 8:16 AM
    Colorado Crawler
    Installed the AirRide manifold to work with my ARB OBA Compressor and the Firestone Ride-Rite airbags with the Daystar cradles. Took the better part of a day but happy about the results.
  13. Apr 6, 2019 at 6:02 PM
    Colorado Crawler
    Put the Prinsu Cab Rack on with an Extreme LED light bar and the Rigid Scene Lights. Wiring is fun. Turned out pretty clean.
  14. Dec 19, 2020 at 6:38 PM
    kherron
    kherron Well-Known Member
    Kevin
    Folsom, CA
    2020 Tacoma TRD Pro
    Do you mind explaining to me the purpose of the Blue Sea circuit breaker? Is it just so you can switch off power to the Bantam / all accessories easily?
