Mystery coolant leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5000fingers, Aug 10, 2016.
  1. Aug 10, 2016 at 10:52 PM
    5000fingers
    5000fingers [OP] Well-Known Member
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    i have a coolant leak somewhere that I can't see. I have to top off every few weeks, and no, there is no evidence of a head gasket problem. I do smell coolant when I turn on the AC, it goes away. But no sign of a coolant leak in the cabin. Ideas?
  2. Aug 10, 2016 at 10:59 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Water pumps are pretty common on these, check the lower side for any dried coolant. If you're not blowing white smoke/the exhaust doesn't smell "sweet" I'd head into a mechanic for a pressure test or go to Harbor Freight and grab one of their kits and see if you can pin point where it's coming from. Smelling coolant upon energizing the A/C says heater core to me. Might just be a slow leak right now so you're not getting a ton of coolant leaking out.
  3. Aug 10, 2016 at 11:21 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I second the recommendation for the HF pressure test kit, I've used mine on other vehicles.
  4. Aug 10, 2016 at 11:33 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    First question, do you see it while the truck is running or no? If not, could be a coolant bypass pipe. Feel at the back of the engine where the hoses come out that go to the heater core at the firewall. There's a foam gasket that lets leaking coolant out that collects between the valley between the heads. The coolant bypass pipe runs between the heads below the intake manifold, it's rtv'd to the engine block in the front of the valley.
    Another symptom that can help diagnose it is after the engine has ran for a while, like driving around for a half hour or more, turn the truck off, let it sit and as the engine cools look for coolant dripping from the back of the engine. The reason it leaks so slow is as the engine gets hot, the metal expands (thermal expansion) and makes a seal, so no leak while the engine is running at normal operating temp. As the metal cools it shrinks but the coolant is still hot and under pressure. Once the coolant cools, the leak stops again, so you have to look in that specific window.
    The link I posted has a good list you'll need for parts with factory part numbers including the Toyota hi temp coolant rtv.
    Another possibility is freeze plugs, but they leak when the truck is running
    Steven G likes this.
  5. Aug 10, 2016 at 11:52 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    I second this possibility. As I currently have this exact issue. Used one of those long mirrors and found the source at that plate you mentiined, as well as drippage down the tranny underneath. My question is, since I've been putting off the repair and haven't fully researched it yet since I discovered it, what could happen if I let it go too long? Or will it just keep leaking and thats that?
  6. Aug 11, 2016 at 12:01 AM
    Laxtoy
    Maltby, WA
    It's pressing imo only in the fact the leak will get worse and eventually not reseal.
    Overheating these trucks equals death.
    Aluminum heads warp or crack when overheated, and you can blow a head gasket easily. My recommendation is pay a shop the grand to fix it or do it yourself for $300.
    Also, in that same cavity are your knock sensors. They aren't a complicated part, only a hunk of metal that measures resonance, but if they fail your truck will throw a code.
    A must while you're in there is to replace the wire harness for the knock sensors. Relatively cheap.
    https://www.amazon.com/gp/aw/d/B00KQ3HT2S/ref=ox_sc_saved_image_34?ie=UTF8&psc=1&smid=A2QEJ1BGOVPAGN
    I still have yet to see this problem arise, but at near 290,000 miles I anticipate it happening so I've been collecting/bookmarking parts.
    Nirvana likes this.
  7. Aug 11, 2016 at 12:46 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Concur with @Laxtoy fix it before you're fixing something exponentially more expensive. Not to mention it's better for the environment if you're not leaking coolant everywhere you go.
  8. Aug 11, 2016 at 9:11 PM
    NightProwler
    Harlan
    Maricopa, Az
    Yeah ivebeen aware of my leak for some time now. Just been putting it off. Kinda anxious about doing it myself but should be able to. Kinda limited in time and funds. But I also was trying to look up what else I could do while I was in there. Like replace any other gaskets, cam seals (as I already have those from the timing and water pump kit that I didn't install with it at the time), and maybe the injectors. I did review that ttora post back when it had pictures so I got a fairly good idea what to expect.
