N/A 3.4 help
Discussion in 'Performance and Tuning' started by 4xtacoma, May 20, 2017.
  1. May 20, 2017 at 8:59 PM
    4xtacoma
    4xtacoma [OP] Well-Known Member
    Jake
    Grass Valley Ca
    00' sr5 trd 5 speed 4x4
    3 inch lift, 265 75 R16 mxt's
    what can I do cheaply to improve the power from my 3.4? I can't afford a turbo or s/c and it's my daily so I can't motor swap it or pull it out and rebuild it
  2. May 20, 2017 at 9:02 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC King Ranch Edition
    Nothing. Exhaust, headers won't do much without f/I.
  3. May 20, 2017 at 9:07 PM
    4xtacoma
    Jake
    Grass Valley Ca
    Really I can't swap cams and put in bigger injectors?
  4. May 20, 2017 at 9:15 PM
    TashcomerTexas
    People that swap to bigger injectors like the Supra injectors are typically looking to offset the need for more fuel deliverance in the case of say a supercharger. Putting them in a stock configuration will just run super rich. Only instance I've seen for swapping cams is from a Camry/IS300 and the gain is minimal.
  5. May 20, 2017 at 9:17 PM
    4xtacoma
    Jake
    Grass Valley Ca
    So would putting a blower on it hurt my reliability? My truck has 265K on it but the motor has 60K
  6. May 20, 2017 at 9:21 PM
    TashcomerTexas
    Nope! I recently installed a s/c I rebuilt myself at about 190k miles and now am around 205k.
    boostedka likes this.
  7. May 20, 2017 at 9:22 PM
    4xtacoma
    Jake
    Grass Valley Ca
    How big of a power gain did you get out of it?
  8. May 20, 2017 at 9:25 PM
    TashcomerTexas
    A good amount I'm easily seeing around 300 hp. That's with a smaller pulley and 7th injector kit. You can check my build to see what I've done.
  9. May 20, 2017 at 9:31 PM
    4xtacoma
    Jake
    Grass Valley Ca
    Any clutch or cooling issues?
  10. May 20, 2017 at 9:33 PM
    TashcomerTexas
    Not at all. You can always install a 160° TRD tstat for additional precaution especially for warmer climates and towing but is not necessary.
  11. May 22, 2017 at 2:31 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    If you have an automatic transmission, you should consider an additional transmission cooler to supplement the one in your radiator. A valve body upgrade or shift kit is also a good idea to save some wear and tear on the transmission.
  12. May 22, 2017 at 2:32 PM
    4xtacoma
    Jake
    Grass Valley Ca
    It's a 5 speed
  13. May 22, 2017 at 2:39 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Depends on how you drive it then. I know people have roasted through a clutch pretty quickly with the SC, but if you don't launch it at every stoplight you should be fine.
  14. May 22, 2017 at 5:52 PM
    4xtacoma
    Jake
    Grass Valley Ca
    I beat the hell out of it every time I drive, I'm in high school
  15. May 22, 2017 at 7:05 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    That's unfortunate. If you take care of it you'll have a nice truck for a long time.
  16. May 25, 2017 at 9:41 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    I've yet to see anything tangible regarding this, can you direct me to a link?
  17. May 25, 2017 at 9:50 AM
    TashcomerTexas
    It's buried in the forums here somewhere. I honestly don't have time to search for it sorry.
