N/A Power Gains - Dynos w/Mods
Discussion in 'Performance and Tuning' started by Torspd, Jul 17, 2012.
  1. May 31, 2013 at 7:36 AM
    #81
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My recent pulls. Stock engine, Stock '05 headers, stock 4x4 y pipe, and no catback.
    SAE and STD corrections, so that the differences can be seen between the two.
    The first run was in 3rd gear. Second run was in 4th. If you look to the top right, you can see the overall calculated gearing.
    Let off in 4th gear due to wheel vibration. The right rear possibly needs to be balanced or recentered.
  2. May 31, 2013 at 10:17 AM
    #82
    Torspd
    Tor
    The Great America!
    Here is a new dyno from Gadget and URD. Very impressive gains.
    parel likes this.
  3. May 31, 2013 at 11:05 AM
    #83
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I want that bigger throttle body. :(
  4. May 31, 2013 at 11:15 AM
    #84
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Wow!
    Obviously, the power comes from the entire combo. I'm wondering how much the UCON adds to NA by itself? Very interesting.
  5. May 31, 2013 at 12:17 PM
    #85
    Torspd
    Tor
    The Great America!
    You would most likely break the 300 wtq mark. :cool:
  6. Jun 17, 2013 at 6:17 PM
    #86
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    thats awesome if i'm getting near those numbers with my 2.5" catback
  7. Jul 11, 2013 at 9:43 AM
    #87
    Torspd
    Tor
    The Great America!
    From the thread that Tooter started in the 4 cylinder forum.
  8. Aug 30, 2013 at 11:55 AM
    #88
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    OK i've gone trough 3 dyno session in the last 2 weeks and the results are:
    Sorry but i'll be back with the graph of the first 2 runs.
    Tacoma 2011 4x4 V6 AT DC LB.
    1st run :
    Stock with DTLT, O2 sim, TRD catback, TRD 1st gen CAI with a AFE ProDryS
    Results 216 RWHP and 251 lbs-pi.
    2nd run :
    Adding of TRD SC and ECU reflash. No other mods added.
    Results 281 RWHP and 295 lbs-pi.
    3rd run :
    URD 2.8 stealth pulley + OEM FPR mod + URD MAF controller and 2 days of tuning with sangage LM-1, Open tune OT-1, R4 software, logworks3.
    Results 298.2 RWHP 5500 rpm and 328.6 lbs-pi at 3700 rpm.
    Edit: Graphs of first and second runs added. Torque curve of first run is a bit strange, second is better and the third one is OK. It's difficult with an automatic transmission to avoid a downshift when going WOT. We get used to it trough the different sessions and it's why the torque curve is getting better.
    techbill likes this.
  9. Aug 30, 2013 at 1:12 PM
    #89
    MadToy
    Nick
    Huntersville, NC
    Great Dyno comparison info! Thanks...
  10. Aug 30, 2013 at 1:42 PM
    #90
    Torspd
    Tor
    The Great America!
    Great addition Vassily28. Thank you.
    Do you know what your elevation is roughly?
  11. Aug 30, 2013 at 4:15 PM
    #91
    Vassily28
    It's in quebec city so we probably talk between 0-100 ft max.
    I'll post soon the charts from the 2 first run. The dyno is an AWD Dynocom.
    There is still a bit of room in the AFR. Still have to fine tune the fuel map to get closer to 11.8 AFR and take a look at the transition in the 3000 rpm area. I mostly running in 11-11.5 afr now.
    :D
  12. Aug 31, 2013 at 3:59 AM
    #92
    MadToy
    Nick
    Huntersville, NC
    That dip at 3k is most likely your converter locking up.
  13. Aug 31, 2013 at 8:13 AM
    #93
    BradyT88
    BradyT88 Well-Known Member
    Maybe I'm wrong here, but I didn't think the torque converter would lock up while under heavy throttle. I thought it was just for cruising basically.
  14. Aug 31, 2013 at 5:01 PM
    #94
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    This is a dyno chart of the N/A low end torque gains from my 2 inch thick intake manifold spacer. This is a 2TR FE 2.7 4 cylinder engine. The first run was done with the engine floored at 1,400 rpm in 4th gear, and second run started at with the engine floored in 4th gear at 1,250 rpm. Even under these extreme conditions the engine did not knock at all, (I would certainly would have heard it because the hood was up and I was right next to the front of the truck filming the run with my camera. So the knock sensor must be doing its job by immediately retarding the ignition timing.
    Both runs were done with just the bone stock ECU, no tuning, and regular 87 octane pump gas. Both runs were also done with an Injen intake, LCE header, and with the stock muffler and exhaust system.
    They're 4th gear runs so the speed limiter cut the engine off at 4,800 rpm. Didn't really matter as I'm only interested in accurately recording the low end torque.
    The spacer lowered the torque peak to 2,900 rpm and also fattened up the torque curve as compared to the stock intake without the spacer.
    We did do one third gear run just to get a top end horsepower reading. It was the last dyno run of a very hot engine on a really hot day, but at least it's an indication that the spacer didn't give up any top end horsepower to get more bottom end torque.
    Here's a video of the run...
    [yt]http://www.youtube.com/watch?v=H6ofUy8_-6Q[/yt]
  15. Aug 31, 2013 at 5:50 PM
    #95
    Torspd
    Tor
    The Great America!
    :thumbsup: Thank you.
  16. Sep 1, 2013 at 1:48 PM
    #96
    MadToy
    Nick
    Huntersville, NC
    I hope that AFR reading was wrong!
  17. Sep 1, 2013 at 3:27 PM
    #97
    Vassily28
    Another important data, i've finalized my boost gage installation. I've not done a run to the cut off but at first sight it seems thet i reach 7 ( correction in fact it's 7.5) psi of boost.
  18. Sep 1, 2013 at 5:40 PM
    #98
    tooter
    Greg
    Los Angeles
    The A/F also behaved exactly the same with the baseline runs. I purposefully didn't do anything to try to address the issue as I wanted the 2 inch thick intake manifold spacer to be the only change...
    a30b1740-bae9-47b2-b0c6-d069757891f7_zps_eb9b8f5d93f9e3ce9acaca73ead59c63123d402a.jpg
    This way I now know exactly what the gains are with the spacer alone, without clouding the results by making other concurrent changes.
    AZ_Charles likes this.
  19. Sep 3, 2013 at 1:38 PM
    #99
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Just curious how accurate the numbers are based on which type of dyno was used (Dynojet vs. Mustang). I know there are many factors that can affect the ending numbers, but I am mainly referring to differences / variables between the 2.
    I might be getting my Taco dyno'd soon, and will likely go with a shop using a Mustang MD-250. This shop was recommended to me, and for good reason http://www.bloodenterprises.com/
    I am also thinking about going here: http://www.turbotechnologyinc.com/site/?page_id=5. They use a Dynojet and have also been recommended.
    Here is some good info.:
    http://www.maximumperformance.biz/Dyno_Simple.htm
    http://honda-tech.com/showthread.php?t=1237732
    http://www.mustangdyne.com/mustangdyne/products/chassis-dynamometers/2wd/?prod=MD-250+Series
  20. Nov 26, 2013 at 7:12 PM
    #100
    Knuckles
    Knuckles Well-Known Member
    Jamie
    Alberta and beyond
    '14 TRD Sport
    TRD blower, ARB winch bumper, XRC8 winch, OME 886/Dakar, pure sine wave 1000W Inverter, hood w/NO scoop.
    Wow, this thread has been immensely helpful. I have the TRD exhaust (truck is just coming with it) and was planning on the DTST headers, y pipe, some sort of air intake modification, and a good programmer. My goal is to put down on the ground what Toyota says these 1GR's put out at the crank (about 270 lb. ft.. couldn't care less about peak HP)...and keep it all as low rpm as possible.
    Also good to know that all these mods will help if and when I pull the trigger on a s/c.
    Thanks guys!
