N/A Power Gains - Dynos w/Mods
Discussion in 'Performance and Tuning' started by Torspd, Jul 17, 2012.
  1. Jun 15, 2017 at 2:16 PM
    #141
    Guns 'n Tacos
    Guns 'n Tacos Well-Known Member
    Georgia
    Looks like my N/A build will consist of...
    -URD Headers
    -URD Y Pipe
    -URD MKIII Cat Back
    -URD TCAI
    -URD MAF Calibrator
    will post results once this is all ordered and installed!
    Rocketman24, JWL, Dalandser and 2 others like this.
  2. Jun 17, 2017 at 12:35 AM
    #142
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I know this thread is for the 1gr, but I'm building a 5vz and doing the cost vs. benefit comparison with components. I'd like to stay n/a since it's really a wheeling rig at heart and want to keep the amount of parts that can fail to a minimum. I emailed LCE today and they said to call them since there was too much to write back.
    I read that they made a 300 hp n/a 5vz and want to see if any of the parts they used will help me out. It was 12:1 compression which I think would make the engine less reliable and prone to head gasket failure...
    Also I was watching a video where the mechanic had these gauges - they seem reasonably priced. Any feedback on them?
    https://www.jbtoolsales.com/fowler-72-646-300-gauge-cyl-bore-2-6/#oid=1002_1
    https://www.jbtoolsales.com/fowler-72-224-103-0-3-digit-counter-micrometer-set/#oid=1002_1
    https://www.jbtoolsales.com/otc-4554-torque-angle-gauge-1-2-drive/#oid=1002_1
    Torspd[OP] likes this.
  3. Jun 17, 2017 at 10:36 AM
    #143
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Definitely post up with some videos and numbers when it comes to fruition!
    Dalandser likes this.
  4. Jun 17, 2017 at 5:25 PM
    #144
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Don't want to burst your bubble, but a N/A 300hp 5vzfe would only be good in the sand. Would have no low end torque. Supercharger all the way.
  5. Jun 17, 2017 at 5:41 PM
    #145
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    No worries - just reading up and watching videos on tuning. It seems like the trade off to making more power in this case is often moving the max power up in rpm's. If I can account for frictional losses in the drivetrain and end up with 190 rwhp I'll be happy - just enough to get a little oomph on hills and in headwinds on the freeway. I'll call up LCE on Monday - they seem like the kind of company that would be straight up with me. Thanks for the input! Any further info is welcome.
    Here's my engine build page:
    https://www.tacomaworld.com/threads/5vz-rebuild-first-timer-noobtastic-thread.492672/
    Saw you had a 5vz swap in an old 4runner - any info on mods besides the s/c? The link to the build page is broken :confused:
  6. Jun 17, 2017 at 9:03 PM
    #146
    CanadaToy
    Greg
    Toronto
    190rwhp should be do-able and fun for a N/A 5vz.
    I've been trying to bug the admin as the yearly lease expired on the site hosting, trying to get it paid.
    Yeah, quite a bit of mods, might do a build thread here but i would really like to copy/paste from the other page.
    Lets see:
    TRD S/C
    URD s/c pullies (all sizes)
    URD tensioner pulley
    URD crankshaft pulley
    URD 7th injector
    ported and polished lower intake manifold
    ColtCams Stage 2 262 cams
    Arias forged pistons (stock compression)
    balanced bottom end
    3-angle valve job
    MAPECU2
    downey headers to 2.5" y-pipe to 3" vibrant spun cat
    fully rebuilt engine with OEM gaskets/seals.
    Only things i didn't do were water injection (will probably do next year) oversized valves, P+P heads, cometic HG, ARP studs and forged rods (oh and i learned later, the forged 3vzfe crank bolts in... argh)
    I broke the engine in then took the truck off the road for restoration work... been working the past 2 months to hopefully have it back on the road this year.
    Dalandser[QUOTED] likes this.
  7. Jun 17, 2017 at 10:58 PM
    #147
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How much did you port the intake? I've been looking up info on porting heads, but again it seems that it could work against me by lowering compression.
    I'm thinking most of what I can do is work on airflow. Doug Thorley or TRD headers (gotta be CARB certified for CA), AFE drop in filter, and again maybe some porting and polishing of the intake and heads. Other than that I'm not sure what other mods will help me - I guess that's what I am going to ask LCE on Monday.
    I guess changing the compression ratio could be an option - not sure of all of the pros and cons yet though. Would a 3 angle valve job w/ larger or upgraded valves and better springs make a difference?
    I've read cams can mess with emissions at idle. Not worth it to me if I would risk not passing smog in CA which tests emissions at idle and at cruising speed.
    Sounds like a beast of a 4runner!
  8. Jun 19, 2017 at 1:21 PM
    #148
    CanadaToy
    Greg
    Toronto
    It was ported by the PO - basically he ground the runners to match the gaskets and polished them smooth. nothing crazy. I ported the headers to match the exhaust gaskets as well since they were not the greatest.
    I'll eventually get the supercharger ported to match the lower intake. Supposed to add 10% more HP.
    Porting heads wont screw with compression ratio, unless you port the chambers. Talk to Gadget @ URD about porting the heads, he has some tips on what he did to gain some good power. I only learned of it after i put my motor together tho. 3-angle valve job done properly should give a flow increase.
    Compression ratio may screw with smog. might make it burn cleaner. But you definitely would need a standalone ECU like Haltech or Megasquirt to run it.
    the cams are pretty mild. no lope at idle. once i get it smogged i'll post the results but i'm expecting it to pass without issue.
    Torspd[OP] and Dalandser[QUOTED] like this.
  9. Jun 19, 2017 at 2:17 PM
    #149
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Thanks man. I appreciate your info.
    I talked to LCE and they said to leave the compression ratio where it's at (9.5?) since stepping up fuel octane would occur around 10:1 so I'd be paying a lot of money for upgraded cylinder heads for not much improvement.
    I asked them if they do porting and polishing on these heads, but he said they usually work on 4 cylinders (22r's I'm guessing is what they work on the most). They'll give me a call back about it. I'll ask URD about it then. Again appreciate the info!
    LCE said that upgrading the valve train would make a bigger difference than porting if I had to choose one or the other and this is the kit they have:
    http://www.lceperformance.com/High-Performance-Pro-Valve-Train-Kit-5VZ-p/1021501.htm
    We'll see about that - it's a lot of dough. Didn't reach URD in time before they close (darn time difference) so we'll see what they have to say tomorrow!
    boostedka likes this.
  10. Jul 1, 2017 at 1:18 AM
    #150
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    And some videos of how it sounds!! Very interested in this setup as well, minus the TCAI and calibrator. Interested to see what all of this stuff will do for you
  11. Jul 1, 2017 at 4:15 AM
    #151
    Guns 'n Tacos
    Georgia
    Don't forget though, the calibrator allows these bolt ons to live up to their full potential!
    Kyitty, JWL[QUOTED] and Dalandser like this.
  12. Jul 1, 2017 at 3:42 PM
    #152
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    That's true, can't wait to see what it does for you
  13. Jul 16, 2017 at 11:55 PM
    #153
    Rocketman24
    Rocketman24 Member
    Rodney
    Alabama
    2011 DC debadged 4x4 TRD
    level, goodyear duratrac, debadged, HID lights
    This is almost the same thing I just installed on my 2011 dc lb 4x4. Made custom 2.5 inch Y pipe and 2.5 inch exhaust with Magnaflow 2.5 inlet and two 2.5 outlet. Everything else is the same but I did install 70mm throttle body. Truck will light up 33 inch tires with no problem and runs great. Sorry no dyno numbers yet. Maybe some time next month.
    5thGearPinned likes this.
  14. Jul 17, 2017 at 9:19 PM
    #154
    Guns 'n Tacos
    Georgia
    Good to hear! I still haven't gotten around to ordering my stuff, waiting to sell my old house first.
  15. Jul 27, 2017 at 5:21 AM
    #155
    Torspd
    Tor
    The Great America!
    ***From @Kyitty ----
    This is what a reasonably stock Taco 4.0 V6 Auto looks like on a dyno (K&N CAI + Spintech Muffler)
    You don't get a very smooth curve on an Automatic though!
    Compared to after adding URD Headers. (This graph shows RWHP at the tires)
    Kyitty and boostedka like this.
  16. Aug 5, 2017 at 11:23 PM
    #156
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    You been able to sell the house?
  17. Feb 16, 2018 at 5:33 AM
    #157
    Torspd
    Tor
    The Great America!
    Latest edition, of a 2TR 2.7L. Compliments of @dillonk1602
    Quote, "i have the AFE dry pro with the DT hearder works great and magnaflow exhaust with a 4.0 regear
    ," End Quote.
  18. Feb 16, 2018 at 6:12 AM
    #158
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    InTaKe DoEs NoThInG bUt MaKe NoIsE, eXhAuSt DoNeSt MaKe PoWeR.
    inwood customs likes this.
  19. Feb 16, 2018 at 6:16 AM
    #159
    Torspd
    Tor
    The Great America!
    Like like like
  20. Feb 16, 2018 at 11:46 AM
    #160
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Curious to see the difference without the DT Hearder and regear.
