n0rth's Tacoma build
Discussion in '2nd Gen. Builds (2005-2015)' started by n0rth, Sep 20, 2010.
  1. Dec 28, 2014 at 12:09 PM
    #1221
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    looking good as always!
  2. Jan 18, 2015 at 8:45 PM
    #1222
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    want so many of those suspension parts, and them arbs
  3. Jan 18, 2015 at 9:09 PM
    #1223
    n0rth
    n0rth [OP] Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    I'll make you a deal on the ORI's, I would like to go back to an extended travel coil over. The ORI's are a little to trick for how little I drive the truck since I picked up a 2003 Rav4 for a commuter car.
  4. Jan 25, 2015 at 5:34 PM
    #1224
    n0rth
    J.W.
    New Mexico
    I went by a buddies house today to pick up the plasma cutter and some parts for the FJ40, we figured we would take the truck out for a joy ride and ended up running into a couple of built jeeps and a very built K5 blazer so what we thought was going to be a 1/2 hour cruise turned into a 4.5 hour snow wheeling trip. Phone and camera were both dead so only got a couple of photos we'll get more next time turns out the group we ran into goes out at least once a month and said they would get in touch the next time they go.
  5. Jan 25, 2015 at 7:09 PM
    #1225
    n0rth
    J.W.
    New Mexico
    CEL P0500 Vehicle Speed Sensor Malfunction
    My speedo went goofy a couple of times today needle was bouncing between 0 and 30 MPH then would stop working then start working again.
    At first I thought it was a stretched speed sensor wire, in 2009 I broke a speed sensor wire and lost my speedo altogether.
    Thinking about it now, we broke a lot of trail today with lots of skinny pedal+supercharger in sugary snow with crust on top and some good drifts in the canyon bottoms. Currently the traction control stays engaged on the truck in 4lo. I broke the 4lo sensor when installing the crawler. I picked a new one up but did not install it when I realized 4lo with traction control on the open diffs works really well. So I'm guessing that's what caused it.
    Anybody else ever had this code or got thoughts on it?
  6. Jan 25, 2015 at 8:20 PM
    #1226
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Looks like a fun trip. We are supposed to get a good 8" of snow here in NJ tomorrow so I'm looking forward to some snow wheeling. As for the error code I looked this up in the FSM.
    Manual Transaxle Models:
    The ECM assumes that the vehicle is being driven, when the indicated engine speed is more than 2,000
    rpm and the engine load calculated by the ECM is more than certain level. If there is no signal from the
    vehicle speed sensor, despite these conditions being met, the ECM interprets this as a malfunction in the​
    speed signal circuit. The ECM then illuminates the MIL and sets a DTC.
    I have had my traction control/ABS lights on for over a year now I think it's due to a bad speed sensor in the wheels or maybe a wire for the speed sensor and I've never gotten a P0500 from it. For the manual transmissions, I would almost think it would have to be the speed sensor in the t-case or the wiring in between, double check them. Maybe pull the sensor out and make sure the worm gear isn't worn and the extended wiring from the crawlbox install didn't get corroded or loose connection.
  7. Jan 25, 2015 at 8:36 PM
    #1227
    n0rth
    J.W.
    New Mexico
    Good call on checking the wires that were extended for the crawler swap I didn't think of that so I'll take a look. The truck was definitely being driven.....lets just say the rev limiter came into play a lot today and tachometer at 5-6k was the norm when we were breaking trail. So that's where I was thinking the traction control was the issue based on 5-6K and a very low wheel speed using the crawler in 4th gear at times when the CEL popped.
  8. Jan 26, 2015 at 5:16 AM
    #1228
    BradyT88
    BradyT88 Well-Known Member
    On my 05 auto, when the wires to one of my front wheel speed sensors were cut my VSC and ABS lights came on as well as my Ebrake light. When I fixed it the Ebrake light went away but I still get occassional blips of the VSC light coming on. I think I have a poor connection somewhere on one of the other wheel speed sensors. From my reading, that Ebrake light is the big indicator of losing a wheel speed sensor.
    I didn't have speedo issues though, but my understanding is that the autos read speed from the rear tires (and I lost a front wheel sensor). I know the manual reads it from the Tcase so I would start with the Tcase wires like Anthony suggested.
  9. Jan 26, 2015 at 6:36 AM
    #1229
    n0rth
    J.W.
    New Mexico
    Brady, you bring up a good point about the VSC, ABS and parking brake lights, they did not get tripped only the CEL.
    I may have looked up the wrong code as I didn't write it down so it could possibly be this code instead.
    P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1) VS.
    I will check the UG and see if I have any pending codes, I may have moved a zero? Might just have to wait and see if I produce the code again. I don't think its an issue just trying to track down why it came up.
  10. Jan 26, 2015 at 6:40 AM
    #1230
    BradyT88
    I didn't think about this on my last post, but with all of my wheel speed sensor issues I have never had them trip the CEL. But they may have added something to the ECU on the 09+:notsure: I always get all the traction control/ABS lights and that 1 time the Ebrake light.
    You did say your speedo was acting funny though so you may not have slipped a zero. Maybe if I pull one of my rear wheel sensors and lose my speedo I'll get a CEL with it:notsure:
  11. Jan 26, 2015 at 8:02 AM
    #1231
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I've been getting a CEL light and that code P0500 randomly over the last year or so. First time it happened, I unplugged all the wheel sensors and replugged them back in then cleared the code with my ultragauge and it went away. Next time it came back, I unplugged and replugged in the senser on the tcase, cleared the code and it went away. Third time I just cleared the code and it went away. Everything since then I just clear it and it goes away until the next unknown random occurrence. I haven't had my speedo freak out like that at all but I'd say probably 1/4 of the times I crank my truck and start driving, my speedo doesn't work at all. While I'm driving I just shut the engine off then back on and it starts working again. I was thinking maybe this had something to do with the speedo calibrator because the two problems have never happened at the same time but Idk, they may be related
  12. Jan 27, 2015 at 10:48 AM
    #1232
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Subd.... Idk if i Subd it already but I am doin it again lol
  13. Jan 27, 2015 at 6:48 PM
    #1233
    n0rth
    J.W.
    New Mexico
    Thanks for the info, I'll keep an eye on my speedo to see if it starts acting up and next time it pops a code I'll write it down.
  14. Feb 8, 2015 at 4:54 PM
    #1234
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    Great looking truck dude.... subbed for crawler and gearing
  15. Feb 22, 2015 at 8:49 AM
    #1235
    n0rth
    J.W.
    New Mexico
    Thanks, gears are a must the crawler is a bonus all together they make the truck just about perfect.
    I did discover a fuel leak after the last time we went wheeling think its pretty minor (inline fuel filter) just need to get it in the garage to take a look and make sure.
  16. Feb 22, 2015 at 12:56 PM
    #1236
    n0rth
    J.W.
    New Mexico
    Fuel leak is fixed, loose hose clamp on the inline fuel filter. Guessing it got pushed back from all the snow that was packed under the truck when wheeling it a few weeks ago.
  17. Mar 6, 2015 at 8:43 AM
    #1237
    sledr13
    sledr13 Member
    Nate
    Vernal, UT
    '14 TRD OR
    Awesome build! My favorite on TW. Are you still trying to get rid of your ORI's?
  18. Mar 6, 2015 at 1:38 PM
    #1238
    n0rth
    J.W.
    New Mexico
    Not sure, part of me wants to go back to a coilover just because. I do worry about a failure with the ORI's but they have been bullet proof to this point and the ride is awesome with them. The last time I charged them was spring of 2014 and they are still at ride height so I think they are way tougher than I give them credit for.
  19. Mar 6, 2015 at 3:34 PM
    #1239
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    My dad had his less then a year. After they went flat 4 times in a row on a basic trail romping...he was done.
    We think his rig was too heavy for them though. Sold them to a buddy with a reg cab 4banger and he is doing great.
    They did ride awesome.
  20. Mar 6, 2015 at 7:20 PM
    #1240
    n0rth
    J.W.
    New Mexico
    I followed that when sconnie ?picked those up and tracked it back to the issues your dad was having. I've had no issues with mine but the thing I always think about and that bugs me is the zero tolerance for failure with the ORI's. Plus I haven't done anything to the truck lately so maybe I should get the plasma out and start hacking best reason I can think of to change stuff....I would probably end up with ORI's again and a 3 link.
