N140S OME shock hardware
Discussion in 'Suspension' started by Alaskaflyer, Feb 8, 2009.
  1. Feb 8, 2009 at 12:16 PM
    Alaskaflyer
    Alaskaflyer [OP] My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    I ordered the front OME shocks for my lift and was wondering if they came with the top stud mounting hardware (washers, rubber bushing etc...)
    Thanks
    Gary
  2. Feb 8, 2009 at 1:03 PM
    Sandfire
    Sandfire Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    Alaska, I don't know the answer but I'm sure someone will shortly. In the meantime, are you ordering all your parts separately? If so where?
    I assume your doing OME 885's as well. I am really close to getting the same stuff just not sure if I should buy a full kit or get stuff individually.
    The basic stuff I want is, OME 885 coils, OME n140s shocks, and TC UCA's. Is this sort of what you are going with?
  3. Feb 8, 2009 at 1:11 PM
    Alaskaflyer
    Cape Cod, MA
    I went with the light racing upper control arms. Talk to Nuebs for the discount code for Toytec, and I found the TC UCA's at offroad warehouse in San Diego for 629.99 plus free shipping. I thought I'd try the Light Racing UCA's I hear they have all their problems worked out.
    Gary
  4. Feb 8, 2009 at 1:14 PM
    Sandfire
    southwest midwest
    Thanks
  5. Feb 8, 2009 at 1:22 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    That's what I did. I bought everything seperately. I went with the OME 885's, read AAL's, Billy 5100's all around and TC UCA's. And a bunch of other stuff here and there.;) But if I'm not mistaken, I think toytec has some pretty good priced sets.
  6. Feb 8, 2009 at 1:27 PM
    sonjay
    sonjay Well-Known Member
    You re-use the top plate from your current shocks. I'm pretty sure there is a new rubber bushing, washer and nut. Don't throw anything away from the old shocks before you get the new ones all back together!
  7. Feb 8, 2009 at 1:31 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    What he said.
  8. Feb 8, 2009 at 1:35 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Mike is that you again!!! Man, can't go anywhere on TW without you sticking your nose everywhere!!!;):ballchain: Haha!!! I'm just messin!!!
  9. Feb 8, 2009 at 1:44 PM
    Delmarva
    Tucson, AZ
    Hells ya... :laugh:
  10. Feb 8, 2009 at 1:47 PM
    Alaskaflyer
    Cape Cod, MA
    I have another set of top plates, I want to build them up and just swap them out with the stock ones. If I end up selling this truck in the next couple of years I want to return it to stock. I just needed to know if I needed the fat rubber bushing and washers and nut for the top. I have everything else, just not sure if what I need is coming with my new shocks.
  11. Feb 8, 2009 at 2:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You will need to order the Top Plate, and the rubber Spring Isolator. The New top plate will have the studs on them. The shocks will have everything else. :)
  12. Feb 8, 2009 at 2:44 PM
    Alaskaflyer
    Cape Cod, MA
    I have a set of top plates and spring isolators. didn't know what the rubber bushings in the shock hardware is called, drawin a blank for some reason today,(Hmm too much beer last night?) I have everything I need then cool!
    Thanks guys
    Gary
  13. Feb 8, 2009 at 2:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Edit, as I didnt read that you already had the top plates and isolators.
  14. Feb 8, 2009 at 10:03 PM
    ToyoRunner
    ToyoRunner another guy with a tacoma
    HI
    Longbed 2wd Prerunner (desert sand mica)
    OME Lift Kit, Light Racing UCA's
    I was also planning on getting a set of the Light Racing UCA's. Let us know how it works out for ya.
