nasty rear end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by peter warfield, Jan 2, 2012.
  1. Jan 2, 2012 at 9:29 AM
    peter warfield
    peter warfield [OP] Member
    mass.
    2012 tocoma DC trd sport
    Hello, this my first post, Well I think I blew my rear end. I was trying to free a frozen trailer from the mud. I tried in 2wd nothing, 4wd, nothing, 4 low was when it happened a very loud bang and truck lurched forward. Truck will not move in 2wd and nasty growling noise followed by loud clunking noise from rear end . I had to have it towed all the way back home . Drive shaft is intacted but not sure if it is spinning or not. Anybody have any thoughts?:mad: thanks Pete
  2. Jan 2, 2012 at 9:31 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Oh my. I'm not educated on this enough to help you but I just wanted to say I hope it's not too bad (although it sounds it may be) :(
    Welcome to TW by the way. They guys here know a lot and I'm sure someone with knowledge will chime in soon.
  3. Jan 2, 2012 at 9:33 AM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    with the truck in 2wd, and the front wheels chocked I would jack up the rear end and try spinning the rear tires. Sounds like you found the weakest link somewhere. Might have taken some teeth off the rear gears. 4-Lo is no joke on these trucks especially in 1st gear.
  4. Jan 2, 2012 at 9:33 AM
    acdronin
    acdronin Well-Known Member
    Will it move in 4wd?
  5. Jan 2, 2012 at 9:45 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    First; Put the rear up on jack stands, block the front wheels, and do a drain n fill on the diff fluid. While it's draining, check all the u-joints and center support bearing for any kind of damage. The u-joints should have ZERO play in them, while the center bearing has a little because it is surrounded by a bushing. After the diff is done draining, filler back up N tighten your plugs.
    Second; Check the old fluid for heavy metal particles. Also the drain plug has a magnet on it, clean the shavings off of it before putting it back on the diff. You can strain the old oil some how either with a paint strainer or a fine mesh strainer. Small dust like shavings are normal, but larger chucks present a problem.
    Third; While the rear is still on jacks and the truck is in 2wd and the tires are on securely, start your truck and put it in gear. Release the brake and listen for noises. Also, once it's safe, look underneath for any unusual vibrations and noises to pin point.
    Fourth; Report back with findings, good luck
  6. Jan 2, 2012 at 9:47 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    you have a locking rear? sounds like your ring and pinion might be shot
  7. Jan 2, 2012 at 10:12 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Contrary to above, check your gear oil for metal chunks before replacing with new. No sense in adding new gear oil if the diff needs to be replaced. I don't think you will need to strain anything. Sounds like you're going to have lots of chunkies in there...
  8. Jan 2, 2012 at 10:19 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    you blew your rear diff! i know first hand what it sounds and feels like since i have blown 4 in the last 2 years...
    best way to confirm is to safely raise the rear end off the ground, and while it's in 2wd put put it into L and let rear wheels turn under their own power at IDLE..no need to feather the gas peddle. letting it idle will be fine. if you hear noise from the rear pumkin area it's your ring and pinion gears!!....a common problem with our trucks
    check out my write up for removing the rear 3rd member from the axle housing
    http://www.tacomaworld.com/forum/2n...removal-installation-e-locker-3rd-member.html
  9. Jan 2, 2012 at 10:21 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    then give these guys a call, www.eastcoastgearsupply.com
  10. Jan 2, 2012 at 10:23 AM
    MonkeyProof
    SoCal- SGV
  11. Jan 2, 2012 at 11:26 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
  12. Jan 2, 2012 at 11:27 AM
    peter warfield
    mass.
    Thanks guys, yes ring and pinion is what it though, this truck will not move an inch in 2wd.
    Any guess on cost,,,a grand or less?
  13. Jan 2, 2012 at 11:29 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    ecgs may be open today, if not they definately are tomorrow, give them a buzz, i promise chase will give you an excellent product for the best price
  14. Jan 6, 2012 at 1:03 PM
    peter warfield
    mass.
    Well new diff is on the way thanks fireturk41 for the connection to east coast gears. You were right about Chase, great guy and taco should be up and running by end of next week. Thanks Pete
  15. Jan 6, 2012 at 4:30 PM
    MonkeyProof
    SoCal- SGV
