Nav's "It takes a village" off-road trailer build
Discussion in 'Other Builds' started by Naveronski, Nov 20, 2020.
  1. Dec 31, 2020 at 4:20 PM
    #121
    Naveronski
    Naveronski [OP] Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Had extra people in the truck, means I got extra photos.
    trekker, MarX, Slashaar and 5 others like this.
  2. Jan 5, 2021 at 2:37 PM
    #122
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I second this. Lowering the profile will help immensely for Aero. Then you just have a small deflector on the lower portion to wrap air around the trailer. Shouldn't be too hard. Just chop the top off halfway along the posts and then cut the rest off the trailer and weld up new arms at the ID size of the previous tubes and it oughta slide right in. then get it to camp height, small hole saw for a pin, and at drive height. Then weld on some bolts and throw some struts on them. I can picture it in my head at least...
  3. Jan 5, 2021 at 2:43 PM
    #123
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It always works great in your head...
    Believe me, one problem solved, often 2 more pop up.
    MarX, Nopro, Drainbung and 2 others like this.
  4. Jan 5, 2021 at 2:44 PM
    #124
    Bigdaddy4760
    Maner
    Poolville Texas
    Exactly troof
    MarX, Nopro, Drainbung and 1 other person like this.
  5. Jan 5, 2021 at 2:44 PM
    #125
    Slashaar
    Josh
    Kansas City, MO
    True. Finding some struts long enough that lift enough to be useful would be an issue I'd bet.
    EDIT: looking again I can see the spare would become an issue.
  6. Jan 5, 2021 at 2:49 PM
    #126
    koditten
    Kirk
    Central Michigan
    My 1st thought was to find a way for it to hing backwards. Winch it forward to the existing height with a cheap, hand boat winch.
    Again, this was my 1st though.
  7. Jan 5, 2021 at 2:49 PM
    #127
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    These guys are really good to deal with. A friend went to them with a fab problem and they really came through.
    https://www.liftsupportsdepot.com/our-company/
  8. Jan 5, 2021 at 4:01 PM
    #128
    Slashaar
    Josh
    Kansas City, MO
    Hmm might have to look at this for my truck box. Currently using my old tow hook from the front of the truck to prop the lid open :rofl:
  9. Jan 5, 2021 at 5:52 PM
    #129
    Naveronski
    Fort Worth
    My plan so far:
    Tent comes off.
    Side/long racks will stay where they are.
    Center section will need to be removed, but not discarded.
    Two possible approaches:
    Tent platform raises/lowers vertically using 12v linear actuators.
    https://expeditionportal.com/forum/...eded-a-new-project.131919/page-9#post-1996873
    Not sure I need heim joints, but not sure I don't, either.
    Tent platform raises/lowers at an angle using parallel arms and actuators.
    https://expeditionportal.com/forum/threads/toby-the-turtleback-trailer-build-thread.187861/
    Similar concept, but with 4 arms, longer than his.
    MarX, Vmax88, SuperBad and 2 others like this.
  10. Jan 5, 2021 at 6:12 PM
    #130
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    MarX, Vmax88, Slashaar and 1 other person like this.
  11. Jan 6, 2021 at 4:03 PM
    #131
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    So true
    Slashaar, Drainbung and Bigdaddy4760 like this.
  12. Jan 6, 2021 at 4:06 PM
    #132
    MarX
    Mark
    NE Kansas
    An idea for if you hit parks with electric. Get an electric blanket to plug in.
    Slashaar, Drainbung and Nopro like this.
  13. Jun 28, 2021 at 8:29 PM
    #133
    Naveronski
    Fort Worth
    We’re back in the shop.
    Removed the tent, cut out the center section.
    It’ll be attached to some linear actuators and raise for camping/lower to stay out of the wind.
    Slashaar, Drainbung, koditten and 3 others like this.
  14. Jun 29, 2021 at 12:43 PM
    #134
    Slashaar
    Josh
    Kansas City, MO
    Sweet, gonna be pretty cool when it's done! Tell Maner I said hi!
  15. Jun 29, 2021 at 2:19 PM
    #135
    Naveronski
    Fort Worth
    Thanks!
    Will do.
    Slashaar[QUOTED] and Drainbung like this.
  16. Jun 30, 2021 at 10:03 PM
    #136
    Naveronski
    Fort Worth
    Uprights are welded in, rack and moving uprights are set in place.
    More grinding and welding tomorrow.
  17. Jul 2, 2021 at 7:19 AM
    #137
    Naveronski
    Fort Worth
    Mounts on, welds ground to look pretty, little paint.
    Actuators and tent back on. Need to wire today, leave for the trip tomorrow.
    trekker, Drainbung, Slashaar and 2 others like this.
  18. Jul 2, 2021 at 7:30 AM
    #138
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Cool build! Curious as to how stable the tent is when the "tower" is elevated.
    Have a fun camping adventure.
    Naveronski[OP] likes this.
  19. Jul 2, 2021 at 3:36 PM
    #139
    Slashaar
    Josh
    Kansas City, MO
    Looks good, what kind of actuator setup you using? Electric jack or just some gas struts to assist with lifting?
    EDIT: Just looked closer, nvm! :facepalm:
  20. Jul 2, 2021 at 4:45 PM
    #140
    Naveronski
    Fort Worth
    It’s alive!
    Floor of the tent is 69” above the trailer deck, and 8’ above the ground.
