Nazlax10's build
Discussion in '2nd Gen. Builds (2005-2015)' started by nazlax10, Jan 1, 2016.
  1. Jan 6, 2017 at 5:30 AM
    #261
    ChadsPride
    Sponsored by TacomaWorld.com
    Like below the screen? where you adjust the hot/cold and stuff?
  2. Jan 6, 2017 at 5:31 AM
    #262
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    ChadsPride[QUOTED] likes this.
  3. Jan 6, 2017 at 5:31 AM
    #263
    ChadsPride
    Cativelense[QUOTED] likes this.
  4. Jan 6, 2017 at 5:32 AM
    #264
    Cativelense
    Nuno
    CT
    No need to thank. We're all here to help each other spend $$$$$$$$$$ and help with stuff!
  5. Jan 6, 2017 at 5:32 AM
    #265
    ChadsPride
    Are yall disconnecting the battery when you do this??
  6. Jan 6, 2017 at 5:32 AM
    #266
    ChadsPride
    :bowdown::bowdown::bowdown::bowdown::bowdown:
    :headbang::headbang::headbang::headbang:
  7. Jan 6, 2017 at 5:33 AM
    #267
    Cativelense
    Nuno
    CT
    I didn't. Don't have to. Only "had" to when I changed my steering wheels controls, just in case, because of the air bag sensor.
  8. Jan 6, 2017 at 5:33 AM
    #268
    ChadsPride
    Right on, I went ahead and ordered the wheel controls too!
  9. Jan 6, 2017 at 5:36 AM
    #269
    Cativelense
    Nuno
    CT
    Atta boy!!!!!!! Those are easy to do as well. For that, disconnect the negative on the battery just in case because of the air bag sensor.
    When you go to do it, there are two caps on the steering column you have to pop out. One on each side. Pop those out, there is a screw on each side. The "tricky" part is to make sure you unscrew each bolt ALL THE WAY and pull it out. If you don't, it still catches the thread a bit and it won't let you pop off the center pc of the steering wheel. After that it's super easy as far as disconnecting the existing controls and connecting the new ones.
  10. Jan 6, 2017 at 5:38 AM
    #270
    ChadsPride
    You tha man!!!
  11. Jan 6, 2017 at 5:39 AM
    #271
    Cativelense
    Nuno
    CT
    Hell no. I only know all of this thanks to THE REAL MAN (@nazlax10) himself.
    BTW. Here ya go:
    Speedometer assembly/lower dash...
    https://www.tacomaworld.com/threads...t-interior-parts.449999/page-26#post-13229954
    Steering wheel...
    https://www.tacomaworld.com/threads/2014-steering-wheel-control-install.362309/
    Center console/stereo...
    https://www.tacomaworld.com/threads...ger-connection-port-in-a-factory-blank.57042/
    For the steering wheel controls, only thing is you don't obviously have to remove the steering wheel, but it should give you an idea of how to remove the controls to swap.
    Norton likes this.
  12. Jan 6, 2017 at 5:44 AM
    #272
    nazlax10
    nazlax10 [OP] Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    @Cativelense, thanks for answering all that while I was still sleeping haha. @ChadsPride, if you're trying to remove the vent panel around the radio you'll need to remove the cluster surround also. Those instructions can be found here. You can get away with kind of prying up on the edge covering the ac vent panel(you'll see what I mean when you take the radio out), but I prefer to take the extra time, as I'm sure you do too, to not pry at plastic pieces. Let me know if you need any other help man!
    ChadsPride and Cativelense like this.
  13. Jan 6, 2017 at 5:45 AM
    #273
    nazlax10
    David
    Woodstock, GA
    Beat me to it haha. Thanks man, I appreciate the kind words!
  14. Jan 6, 2017 at 5:45 AM
    #274
    ChadsPride
    Thank you very much sir!!
  15. Jan 6, 2017 at 5:46 AM
    #275
    Cativelense
    Nuno
    CT
    Good point. Completely forgot to mention that. Definitely better safe than sorry and remove the cluster surround to then remove the AC vent pc.
    ChadsPride likes this.
  16. Jan 6, 2017 at 5:46 AM
    #276
    ChadsPride
    So in order to change the AC vent covers I have to take out the Gage cluster???
  17. Jan 6, 2017 at 5:48 AM
    #277
    nazlax10
    David
    Woodstock, GA
    I wouldn't say have to, but it prevents you from prying it up enough to get the ac vent cover from under it. You'll see how it holds it in place once you take the radio out. It only takes about an extra 20 minutes but is definitely worth it.
  18. Jan 6, 2017 at 5:48 AM
    #278
    Cativelense
    Nuno
    CT
    Definitely easier to do that, to pop out the vent cover much easier.
    And while you're at it, you can paint the gauge cluster rings black as well like I did!
  19. Jan 6, 2017 at 5:50 AM
    #279
    ChadsPride
    Do the rings just pop off when you have the cluster off?
  20. Jan 6, 2017 at 5:51 AM
    #280
    Cativelense
    Nuno
    CT
    Pretty much. There are tabs behind them, that hold them in place, clipped to the pc that comes off. Just have to pry lightly so they don't break off.
