ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Sep 27, 2016 at 2:15 PM
    #661
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Yea makes sense I guess. I think I might have used electrical tape now that I think about it. I'll have to check to make sure.
  2. Oct 7, 2016 at 2:54 PM
    #662
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    Can anybody help out here, my 2011 has 4 blade fog fuse and 4 terminals where it plugs in, which one do I jump?
    470DAE1A-853C-4D81-A8DC-A688FA2C7BC8_zps_8e876827a1cb0eac9795999c2ea63e7ad1769190.jpg
  3. Oct 8, 2016 at 1:00 PM
    #663
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    What type/size connector did you guys use to slide under the AC relay? I broke a prong on the relay when I did mine :annoyed:
  4. Oct 13, 2016 at 7:54 PM
    #664
    little squirt
    808 ALLDAY!!
    any help on this??
  5. Nov 2, 2016 at 5:22 PM
    #665
    sawjai526
    sawjai526 Well-Known Member
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
  6. Nov 2, 2016 at 5:41 PM
    #666
    sawjai526
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
    Since you have a 2011, Look under the fuse box cover and locate the AC relay. then finally the 1st post.
  7. Dec 20, 2016 at 9:41 PM
    #667
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Still have some piggyback terminals if anyone needs them. Just ask that you send me a few bucks (2-3) to help cover shipping
    uf20wop and Norton like this.
  8. Dec 20, 2016 at 11:50 PM
    #668
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Piggy back terminals? What's the bebifits of them?
    Not really sure what it is
  9. Dec 21, 2016 at 8:10 AM
    #669
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    uf20wop and sawjai526[QUOTED] like this.
  10. Dec 21, 2016 at 9:43 AM
    #670
    GARSHA91
    Chicago
    It basically allows you to do this mod without bending or trying to cut a terminal.
  11. Dec 21, 2016 at 1:54 PM
    #671
    sawjai526
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
    that red/black wire is on a empty slot, it doesn't contact the relay. .. i didn't want to cut the wire, so i depin the connector and moved to a empty slot.
  12. Dec 21, 2016 at 2:01 PM
    #672
    Spencer97TJ
    Spencer97TJ Well-Known Member
    Spence
    CT
    stock
    These kinda things make your truck more personalized. Love it!
  13. Dec 21, 2016 at 2:48 PM
    #673
    nd4spdbh
    SoCal
    AHHH you are right. i didnt look close enough. All is good, the world will still spin now!
    sawjai526[QUOTED] likes this.
  14. Dec 26, 2016 at 12:37 PM
    #674
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Has anyone done this on a third gen?
  15. Jan 2, 2017 at 10:39 AM
    #675
    tgriff
    tgriff Well-Known Member
    Tim
    CT
    2014 TRD Sport 4x4 Black DCLB
    8.5" x 17" Fuel Hostage black wheels P265/65/R17 Toyo Open Country AT II tires Rigid Industries Dually LED pods on back bumper (Diffused pattern) Rigid Industries 10" SR2 amber LED light bar behind grille (Driving pattern) - Custom mount Magnaflow 18" performance muffler Magnaflow 4" resonator exhaust tip - Welded on 3M 35% tint on front windows Access Limited roll-up tonneau cover Uniden Bearcat 880 CB radio 4' Firestik Firefly CB antenna on Relentless Fab hood mount AVS vent visors Lamin-X amber fog light covers ND4's fog light anytime mod Ultragauge MX 1.3 mounted on dash - Custom mount Weathertech floor liners front & rear Access LED battery-powered bed light CravenSpeed stubby antenna OEM Bed Mat Bosch Icon windshield wipers Plasti-dipped front emblem Debadged TRD Sport bedside decals removed Mud flaps removed
    Can you please elaborate on this? I am about to do this mod but I think I would prefer to pull the power from a constant 12v source instead of messing with the inverter relay. Is there any other downside to using a constant 12V source other than the possibility of accidently leaving the fog light switch on? As long as the fog light switch is off there wouldnt be any battery drain correct?
  16. Jan 2, 2017 at 10:41 AM
    #676
    nd4spdbh
    SoCal
    correct. if you were to have it switched via a constant 12v source then you could turn the fogs on any time regardless of key position. You set yourself up for potentially leaving them on and draining your battery. So long as you have the switch in the cab turned off and the lights are off there is no extra draw.
    I personally wouldnt recommend doing it this way but you most certainly can.
  17. Jan 2, 2017 at 10:46 AM
    #677
    tgriff
    Tim
    CT
    thanks for the quick reply, I plan on only using the fog lights at night so I dont think I would accidentally leave them on. If that comes back to bite me I'll say i should have listened to you:rofl:
    How would I "Simply run two wires out of the middle relay pin socket as thats a constant 12v" as you previously told someone else? When I make the extension what would go to what?
  18. Jan 2, 2017 at 11:33 AM
    #678
    nd4spdbh
    SoCal
    so in my original post. the white wire instead of being a single male to single female as a standard extension. Do a single male to two female connector Y extension. Run one of the female plugs as a standard pin to pin extension to the foglight relay, then the other extra female plugs to where the brown wire goes to on the foglight relay.
    The center pin of the foglight relay is the constant 12v hot directly from the battery splitting it to the hot side of the actual relay switch will allow you to hit the dash switch at any time and fire the relay.
    Im 98% sure the center pin (white wire) is the constant hot, try that first, if it doesnt work move it to the yellow wire spot within the actual socket. (or use a volt meeter and do a quick probe to see which one is the always hot)
  19. Jan 2, 2017 at 12:09 PM
    #679
    tgriff
    Tim
    CT
    Ok thanks I think i got it. So I will have a single connection to the center pin with the white wire which then branches off into 2 white wires? One goes to the relay as shown in the original post and the other goes next to the green wire where the original post has a brown wire? I will have no brown wire. Does this sound right or am I confused? I appreciate all of the help
  20. Jan 2, 2017 at 5:46 PM
    #680
    nd4spdbh
    SoCal
    yup you got it!
    tgriff likes this.
