ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Feb 27, 2019 at 6:40 PM
    #821
    Rocksteady1
    Rocksteady1 "This is the way"
    PNW
    2015 Tacoma TRD Sport. DCSB 6 spd MT. 4x4
    Unifilter mod, CAI, Stereo System.
    Have to say this looks the best of all the ways done. Thank you for the contribution!!!! This is the way for me.
    nd4spdbh[QUOTED][OP] likes this.
  2. Feb 28, 2019 at 7:00 PM
    #822
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    Anyone have a link to a step by step or even a video.
  3. Feb 28, 2019 at 10:44 PM
    #823
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    sure... click here -> 1
  4. Mar 1, 2019 at 8:27 PM
    #824
    Bigpat_ca
    Sacramento, CA
    Not quite a step by step. Thanks though
    SAR Taco likes this.
  5. Mar 25, 2019 at 10:14 PM
    #825
    llama
    llama New Member
    2015 Tacoma Off-Road
    Does anyone know the part number for the ACDC relay? I was a little too aggressive putting it back in and ruined it.
  6. Mar 25, 2019 at 11:05 PM
    #826
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Can’t help with p/n, but I trimmed the blade connector then bent it alittle and placed it beside the female receptor of the inverter relay. Hope that makes sense.
  7. Mar 26, 2019 at 6:01 AM
    #827
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
  8. Mar 26, 2019 at 11:54 AM
    #828
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Part# 90080-87024
    should be printed on side of relay, double check.
  9. Mar 26, 2019 at 6:35 PM
    #829
    llama
    llama New Member
    Thanks for the help guys. For anyone searching in the future, on my 2015 TRD Off Road it is indeed part number 90080-87024.
    Muddinfun likes this.
  10. May 12, 2019 at 11:39 AM
    #830
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    I did this on my 2012. I swapped wires for the Air Pump HTR for power when key is on. Well last camping trip, fog lights turned themselves on with truck off and keys in my pocket:eek:. Does this circuit randomly energize on its own for emissions or some other purpose? Anybody else experience this?
  11. May 12, 2019 at 1:34 PM
    #831
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    quite possible. You have a TRD OR, why not use the AC/DC relay switched power considering we know its switched on and off 100% of the time with the key.
  12. May 12, 2019 at 1:47 PM
    #832
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    Thanks. I've gotten good at remembering to turn them off now. But the AC/DC source will give me piece of mind. I'll go this route now. Makes me wonder how many time this happened after I parked in garage. Only noticed this time because it lit up campsite. They turned on roughly 10-15 minutes after I parked truck.
  13. May 12, 2019 at 3:47 PM
    #833
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    When I did the mod on my 05 it did this
    Tacos run the emissions even when the truck is off is what I am told
    One night it did this when my neighbor was walking her dog
    Scared the s##t out of her
    On my 14 I ran it to the AC relay
  14. Jul 19, 2019 at 9:14 PM
    #834
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    will this mod allow me to use the factory fog switch ONLY when the ignition is turned on? i don’t want to have to remember to turn the lights off every time i shut off the truck.
  15. Jul 19, 2019 at 9:20 PM
    #835
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Yes
    Rick_Taco and cromag27[QUOTED] like this.
  16. Jul 22, 2019 at 6:25 PM
    #836
    Skymaster
    Skymaster Well-Known Member
    Atwater CA
    TRD OR, White DCSB
    Does this work for the 3rd gens as well. I have not read the 42 pages
  17. Jul 22, 2019 at 8:37 PM
    #837
    nd4spdbh
    SoCal
    No.... in typical 3rd gen fashion they have over-complicated everything.... What used to be a simple switched ground on the dash with a 12v line based off of a low beam light.... is now a ground switched Fog relay by the ECU which determines if its OK or not to ground out the relay regardless of the switch position on the stalk. There is a 3rd gen fog light anytime mod, but you are gonna be cutting the harness.
  18. Aug 15, 2019 at 9:53 AM
    #838
    labrador01
    labrador01 Well-Known Member
    Kyle
    Northern IL
    2015 Tacoma
    I did this mod last night. Had to be able to test my KC fogs without my headlights!
    Rick_Taco and nd4spdbh[OP] like this.
  19. Sep 28, 2019 at 11:35 AM
    #839
    BuildbyBarz
    BuildbyBarz Well-Known Member
    Johnny
    SrQ 941
    14 MGM DCSB
    Friends don’t let friends drive stock
    Would 14 awg wire work? Or what awg wire I should use ?
  20. Sep 28, 2019 at 12:03 PM
    #840
    gotblika
    Maui
    2015 DCLB Sport 4X4
    14 is more than enough.
