ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Oct 4, 2019 at 5:44 PM
    #841
    20stormtrooper15
    20stormtrooper15 Member
    SWVA
    Maybe I’m doing something wrong but in my 15 TRD OR I have things wired as they should be but the fogs aren’t coming on at all. It worked initially when I did the wiring now I get no power at all.
  2. Oct 4, 2019 at 5:48 PM
    #842
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Sum Ting Wong
    Norton likes this.
  3. Oct 4, 2019 at 6:21 PM
    #843
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    If it did work, but now it doesn't then you probably popped the fuse.
  4. Oct 4, 2019 at 8:30 PM
    #844
    20stormtrooper15
    SWVA
    Yeah I didn’t think about that.
  5. Oct 11, 2019 at 5:28 AM
    #845
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    ok i know this is gonna probably be a stupid question but do the wires need to be different colors, or is it just for ease of connecting for installer
  6. Oct 11, 2019 at 7:19 AM
    #846
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    wires can be any color you want to long as they go the appropriate place.
    Only reason i have 4 different color wires in my original post is i had a section of trailer wiring harness left over... that just so happens to use 4 wires!
    asudevil likes this.
  7. Oct 11, 2019 at 7:20 AM
    #847
    12taco12
    rochester NY
    2012 TX Pro
    and what gauge would be good
  8. Oct 11, 2019 at 7:22 AM
    #848
    nd4spdbh
    SoCal
    I wouldnt use anything less in size than 14awg. 12awg would be better, 10awg would be overkill.
  9. Oct 11, 2019 at 7:22 AM
    #849
    12taco12
    rochester NY
    2012 TX Pro
    10-4 thanks brother
    nd4spdbh[OP] likes this.
  10. Oct 13, 2019 at 10:08 AM
    #850
    12taco12
    rochester NY
    2012 TX Pro
    just did it super fast and nicer than splicing, now to install the BD in the bumper
  11. Oct 13, 2019 at 12:04 PM
    #851
    Finkous
    Finkous Member
    I looked into doing this mod, but i have heated seats and the relay is beside the fog light relay making it very difficult to get all the wires inside the fuse box. There was a topic about using a tiny wire to connect two terminals on the relay making the fog lights come on with highbeam only, not on all the time. but it was pre 2012 and the relays are different on the 2014’s. All i want is an easy way to make the fog lights stay on when the headlights are on, high and low beam.
  12. Oct 13, 2019 at 12:58 PM
    #852
    HawkShot99
    Kingston, NY
    Stock heated seats or aftermarket? If aftermarket, why can't you move the relay to a different spot?
    As far as doing this mod, if I pop the cover on that fuse panel, I can barely tell that it's been messed with.
  13. Oct 13, 2019 at 1:02 PM
    #853
    Finkous
    Finkous Member
    stock heated seats
  14. Oct 13, 2019 at 2:51 PM
    #854
    nd4spdbh
    SoCal
    If im not mistaken, somewhere buried in this here thread a member made it a stealth mod. Soldered a wire on the 12v switched hot (same pin the brown wire in OP goes to) underneath, then replaced the pin on the fog light spot so the fog relay stays in the same spot.
  15. Oct 13, 2019 at 4:49 PM
    #855
    HawkShot99
    Kingston, NY
    Didnt realize any 2nd gens got them.
  16. Oct 13, 2019 at 5:59 PM
    #856
    gotblika
    Maui
    2015 DCLB Sport 4X4
    I did the single wire method with bending the terminal on the relay, should work for you. No need the inline fuse, it’s worthless. https://www.tacomaworld.com/threads/2013-fog-light-anytime-w-fuse-step-by-step.279537/
  17. Oct 13, 2019 at 9:16 PM
    #857
    caribe makaira
    Caribbean, Puerto Rico
    OEM in there is 18 and 20 awg...
    gotblika likes this.
  18. Oct 13, 2019 at 9:33 PM
    #858
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    61903B12-D441-489B-A637-C143DCAE11C9.jpg Mine fit in there, I didn’t even notice the heated seat relay being a problem. Hell I didn’t realize it was in there till this post.
  19. Oct 13, 2019 at 9:41 PM
    #859
    caribe makaira
    You should run the heat shrink up to cover the terminals...
  20. Oct 13, 2019 at 10:00 PM
    #860
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I eventually did. I only had a short chunk left big enough to cover the middle one at the time of the pic.
