need 2012 trd offroad wheel backspace and offset numbers
Discussion in 'Wheels & Tires' started by the glen, Mar 7, 2013.
  1. Mar 7, 2013 at 10:37 PM
    the glen
    the glen [OP] Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
    Tryin to buy some wheels, the icon lift I want recomends a 16x8 with a 5inch backspace. I talked to sonny at Downsouth Motorsports and was told to try and get that size with a offset the same as factory wheel. Any help would be appreciated. Thanks.
  2. Mar 8, 2013 at 11:13 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Basically any wheel with 5.0" of backspacing or less with clear the setup. Pick a wheel that you like and go from there.
