Need a Detailed Explanation of How the TRD radiator cap effects the cooling system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, Jul 4, 2012.
  1. Jul 4, 2012 at 11:16 PM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    would it be possible for anyone to please explain why installing a higher pressure radiator cap over the stock, such as the TRD radiator cap P/N: PTR04-00000-03 that id like to purchase soon, helps with the engine cooling system performance and just how it actually operates in general?? and if installing it will have any adverse effects on any of the engines parts or components?? thank you so much, this has been a puzzling question ive been asking myself for quite some time now and i just can't seem to fully grasp the science, knowledge and thinking behind it and put two and two together, any info is appreciated, thank you :)
  2. Jul 4, 2012 at 11:24 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Serious...? Isn't it just for looks...
  3. Jul 4, 2012 at 11:25 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    It's just for looks dude.
  4. Jul 4, 2012 at 11:27 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    [insert not sure if serious meme pic here]
  5. Jul 4, 2012 at 11:27 PM
    JeremyGrey
    JeremyGrey Well-Known Member
    Ahwatukee, AZ
    2012 DCSB TX Pro Prerunner
    The TRD radiator cap is USELESS without the TRD shifter knob........
    :crapstorm:
    diabetiktaco and MatBat206 like this.
  6. Jul 4, 2012 at 11:29 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    It's got high performance muffler bearings that creates a smooth operating left handed smoke shifter. Lol
  7. Jul 4, 2012 at 11:34 PM
    YoaterBoater
    YoaterBoater Well-Known Member
    Running tubes, Toolbox
    It reduces friction heat on your tires, gives you the fuel economy of a Volkswagon diesel, and lowers your insurance.
    MatBat206 likes this.
  8. Jul 5, 2012 at 12:21 AM
    kyleTRDtaco12
    Kyle
    New Jersey
    hey common, im honestly being serious here.. im not joking around.. im sure the effect isnt profound but id just like to know for knowledge sake :/ and no, its not just for looks, it raises the boiling point of the coolant , and id like to know exactly what that means and what are the positives and negatives are about that... no need for the sarcasm :(
  9. Jul 5, 2012 at 12:27 AM
    RacerAV
    RacerAV Well-Known Member
    OC, CA
    '09 DCSB4x4 (sold)
    not sure about the TRD cap but
    there ARE caps that hold higher pressure before letting out fluid to the over flow tank... I've used them in my 240s before... along with better electric fans, and lower temp thermostats. my engine ran cooler, safer, etc...
    Adamo
  10. Jul 5, 2012 at 12:28 AM
    RacerAV
    OC, CA
    '09 DCSB4x4 (sold)
    forgot...
    with that being said, I've ALSO bought caps that are just billet with a sweet sticker, just like oil caps of the same "performance" value... of ZERO...
  11. Jul 5, 2012 at 12:38 AM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
  12. Jul 5, 2012 at 12:57 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Ahhh, the radiator cap. The most overlooked cooling system component. Pretty neat little things.
    - Rcaps have a PSI rating usually between 13 - 16 PSI. For each Lb of pressure, it will raise the boiling point of the coolant by 3 degrees. A 13 PSI cap will help raise the boiling point of the coolant by almost 40 degrees. It helps improve performance.
    - 2 valves on a Rcap as well. 1 for when the engine is hot, one for when it's cold. One valve will open and allow excess coolant/pressure to bleed off (like into the overflow tank). The other valve is a vacuum valve. When/as the engine cools, a small vacuum is created in the cooling system sucking coolant out of the tank and back into the system.
    So, the TRD cap, a higher pressure cap, will help increase the boiling point of your coolant just a little bit more. Idea being it will help improve C.S. performance.
    Other than that, it's a nice shiny object.
    (Coolant freezing points...The point of the ethelyne glycol (or whatever it's made of) in coolant is to really help the water it's cut with. The coolant in this regard, lowers the freezing point of the water so it dosen't freeze in your shit during a cold night. A typical mix is 50/50. Half coolant concentrate, half water. This gives about a -32 degree rating, VERY TYPICAL. If you get -32 in NJ, you got other problems. People in Alaska may run a 60/40 portion. 60% coolant to 40% water. The freeze protection will go even lower)
    drizzoh and bsp_taco like this.
  13. Jul 5, 2012 at 1:13 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    It's ALL useless w/o a TRD sticker and hood skewp!!!
    All those things combined give ya 75 extra HP!!!
  14. Jul 5, 2012 at 1:14 AM
    kyleTRDtaco12
    Kyle
    New Jersey
    that was some pretty good info, and thanks, but my other question now is, after the one person said "the cap puts extra stress on the cooling system", would toyota and TRD actually design a part that would actually jeopardize the integrity of the vehicles cooling system??.. and my thinking there is probably not because its an actual toyota part... but what is your opinion on that now?? cause im sure there had to be a fair amount of r&d put into the cap.. idk.. thats why im here asking :/
  15. Jul 5, 2012 at 1:14 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    And this...Duh!
  16. Jul 5, 2012 at 1:18 AM
    kyleTRDtaco12
    Kyle
    New Jersey
    Thank you for all the info chris, very informative, any yes you're right, it is the most overlooked item in the cooling system lol
  17. Jul 5, 2012 at 1:25 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    GL w/ your purchase! Enjoy the truck!
  18. Jul 5, 2012 at 1:27 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Jst get a new cap at ADAP for 15 bucks with a higher lbs. rating if you want. I am not sure why you want to go higher, usually you go lower when the radiator gets real old and weak.
  19. Jul 5, 2012 at 8:42 AM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    read post above.
  20. Jul 5, 2012 at 8:43 AM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    agree. its up to you.
