Need a little help with suspension mods on 2000 Tacoma 3.4L V6
Discussion in '1st Gen. Tacomas (1995-2004)' started by regkeg, Sep 2, 2012.
  1. Sep 19, 2012 at 9:24 AM
    regkeg
    regkeg [OP] Well-Known Member
    Dick
    Washington
    2000 Tacoma 4x4
    Cat back duals w/Magnaflo, Deck Plate mod, ScanGuage II, ARB bumper, Warn XD9000 winch, ToyTec OME-9504TAC suspension, Toyo Open Countries
    Got the diff drop kit installed this morning. Took all of 5 minutes since I already had the skid plates off. Looks like it's time to hit the hills. :)
  2. Sep 19, 2012 at 10:23 AM
    Madjik_Man
    Colorado Front Range
    Holy crap it doesn't look like that much lift.
    That stance is awesome IMO
    I run 31x10.5x15 and was always a bit hesitant to gain any lift because I didn't want my tires to look like rollerskate wheels.
  3. Sep 19, 2012 at 10:35 AM
    regkeg
    Dick
    Washington
    2000 Tacoma 4x4
    When I first looked at it after the lift I didn't think it was that much but that's what it measures. Getting in and out you can definitely tell the lift is there. :)
  4. Sep 19, 2012 at 11:46 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I'll bet you actually have less lift over oem then you think...
    I'm guessing the original suspension had settled some from it's original height.
    so you're not actually at 4" of lift.
    oh.. and diff drops are a waste of money.
    They do little but drop the forward end of the diff.
    leaving the rear at it's original postition...
    Probably changing the driveshaft's u-joint angle
    thus creating more wear issue for that U joint.
    The key is not to lift a tacoma any more then 2 3/4" over oem.
    If ya do... you'll just accelerate wear issues and create other problems.
    Modifying the wheel well(s) for obstruction...
    is the only correct way to install over sized tires that could impair
    wheel/tire travel.
    If one need lift taller then 2 3/4"...
    I would recommend removing the ifs and SAS'ing it.
    You could also do that with drop brackets... but they suck.
  5. Sep 19, 2012 at 12:18 PM
    Madjik_Man
    My truck's front and rear are sagging worse than a grandmother...
    ...so when you say 2 3/4" over OEM I assume you're talking about the specs the day Ol' Red rolled off the line?
    Because I guarantee if I replace my entire suspension with OEM parts, I'd gain more than 2 3/4" of "lift" so to speak.
    That said, do I need to worry about drive shaft angles, etc?
  6. Sep 19, 2012 at 12:30 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    yes
    no... not initially... unless you have vibes.
    but over time... it could escalate wear
    I have between 2 - 2.5" of suspension lift.
    I roll 295's (33.3 X 11.50)
    I still have all the original factory drive line parts from day one.
    My junk is 13 yrs. old... and has been used off road plenty.
    Of course... I don't beat on it like I stole it...
    so maybe that's why...
    But I will bet it has more to do with keeping the suspension geometry
    within the specifications that Toyota engineered.
    to each their own of course...
    I just don't like having repairs I can avoid. ;)
  7. Sep 19, 2012 at 12:34 PM
    Madjik_Man
    I don't have any vibes or issues whatsoever.
    And I'm a "stock" kind of guy. I just eventually want to rejuvenate the suspension and bring it back to OEM specs.... and run 31x10.5x15 tires.
  8. Sep 19, 2012 at 12:53 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    You should be able to run those sized tires with little to no lift,
    simply knock the pinchweld down some.
    Possibly the front mudflap could interfere and need removal.
    Maybe some minimal trimming... but should be real easy stuff.
    Upgrading/improving your tired suspension will offer better handling and control and will be a vast improvement
    I actually have near 3.5" total lift to fit my 295's
    but the only way to do that...
    is to either add a body lift... or clearance the wheel wells
    I chose to do the easy/cheap route by adding a 1" BL.
    Many peeps hate them... but I have never had issue...
    and it saved me cutting up/modifying the inner fenders.
    I wouldn't recommend a body lift for those whom think they own
    a WOT race truck... that hovers and slams back down to the earth.
    ^ but then... I don't recommend doing that ever on a stock truck
  9. Sep 19, 2012 at 12:56 PM
    Madjik_Man
    Okay maybe I'm not being clear enough.
    I've never had issues running 31x10.5s, it's what the truck came with.
    I'm not looking to lift my truck.
    The only "lift" I will get is when I replace my worn out suspension and get back to OEM specs.
  10. Sep 19, 2012 at 1:11 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    IMO
    "Lift" is a poor choice of words anyway...
    "Suspension upgrade" would be a better choice.
    In any case...
    some suspension lift will occur...
    as a by product of installing new aft. mrkt. suspension components.
    Many folk tend to exceed the geometry of the Tacoma by lifting too high...
    for no other reason then to install large tires.
    But then limit the suspension... or not take full advantage of it's travel.
    Lift is not what should determine clearance for larger tires... ever
    And no... my comments weren't directly meant for you...
    but for others reading.
    Tho'
    those 31's might look a little small in there...
    if the suspension components you eventually choose...
    might lift the suspension more then you expected.
