Need A Smaller Toolbox
Discussion in '1st Gen. Tacomas (1995-2004)' started by BoostingMS6, Nov 17, 2010.
  1. Nov 17, 2010 at 12:22 PM
    BoostingMS6
    BoostingMS6 [OP] Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    I just bought a camper shell for my Tacoma. I don't really like the way pickups look with camper shells, but I use my truck a lot in the winter for snowboarding, and need something to keep my extra gear in. It'll pretty much only be used in the winter weekends.
    That said, I've been looking at buying a toolbox for the truck. I don't want to take the toolbox out every time I put the camper shell on, though. Does anyone know of any toolboxes that don't stick out past the sides of the bed? It doesn't have to be a huge box, I just want it for a few items I carry on me.
    I've seen plenty of toolbox topics in the forums, but none about this specific topic. If I missed something on the search bar, let me know.
    Appreciate the help in advance :D.
  2. Nov 17, 2010 at 9:42 PM
    BoostingMS6
    Alex
    El Paso, TX
    No one ever responds to my questions :(
  3. Nov 17, 2010 at 10:59 PM
    Nitronick
    Nitronick Well-Known Member
    Nick
    Oregon City, OR
    98 tacoma sr5 v6 3.4
    ever think of the toolboxes that just go over the wheelwell?
  4. Nov 17, 2010 at 11:29 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I ended up finding a Jobox that fit perfectly for my needs. http://www.amazon.com/Delta-Jobox-Welders-Box-30/dp/B000OGT7V8
    Not really very water tight, but you can fix that up if need be. Just has a single pad lock in the front. Had to drill holes to secure it. And paint it, unless you like orange.
    Only sits 12" high, so should be well under the bed frame and still open up enough to work with your shell, as well as hold enough items. A 1 gal container of antifreeze will fit standing up, to give you an idea on the height I was looking for.
    The other option I was looking at was if I could find a similar sized ammo box, but I missed that opportunity as my local surplus shop is hit/miss for boxes. I found one that was about the right width and length, but was only 6" high. I tried, but ended up needing a bit more space and wasn't happy at all about the clamping method.
  5. Nov 17, 2010 at 11:36 PM
    BoostingMS6
    Alex
    El Paso, TX
    That Jobox is sort of what I'm looking for. If nothing else, I'll go that route.
    I thought about the ammo box too. Someone hear had trouble making it water-proof though.
  6. Nov 17, 2010 at 11:37 PM
    BoostingMS6
    Alex
    El Paso, TX
    Didn't read this post prior to my last response. I have, but I don't like them that much. It's always an option though.
