Need advice - 5100s
Discussion in 'Suspension' started by mray, May 30, 2018.
  1. May 30, 2018 at 12:49 PM
    mray
    mray [OP] Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    I have a 2011 Base Access Cab with a topper on the back. All stock suspension and rides like a buckboard. Rear is 1.75" higher than front.
    Just ordered a full set of 5100s and have a couple of questions. I am not interested in leveling front to rear, I like a little rake. Do not want to change springs, etc...just shocks.
    What setting will provide the best ride, stock or .85"?
    Does raising the front a little have any effect on the rear height?
    Thanks in advance...
  2. May 31, 2018 at 8:08 AM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    5100s set at zero will give the best ride.
    tcBob likes this.
  3. May 31, 2018 at 8:14 AM
    mray
    Colorado
    Thanks!
  4. Jun 1, 2018 at 4:35 AM
    Ricebox
    Ricebox Well-Known Member
    FL
    18' TRD Off-Road 4x4 Prem/Tech
    this
  5. Jun 2, 2018 at 9:53 AM
    Kidoh1
    Kidoh1 Well-Known Member
    CA
    2013 DCSB OR
    5100s all around. OME 887. HS AAL
    It should not.
  6. Jun 2, 2018 at 9:58 AM
    eon_blue
    eon_blue Most Improved Member
    If you want to lift the front you should do so via the coils, not the shocks...5100s are adjustable yes but they preload the stock coil to achieve lift and that kills your ride quality. Maybe not so bad at the first setting but ideally you want to keep them at zero and get new coils for lift.
