need advice ??? allpro leaf pack with 5100 ???
Discussion in 'Suspension' started by myfirst06taco, Aug 16, 2011.
  1. Aug 16, 2011 at 5:38 PM
    myfirst06taco
    myfirst06taco [OP] Well-Known Member
    Clarke county ,VA
    06 SR5 4X4
    5100's eibach coils , Allpro leaf pack , roll up tonneau cover with led bed lights, hids, homertaco grill
    I just ordered a allpro leaf pack , witch says 2-3/4" lift . Can i use 5100 or get a custom size 5125 , if i need a 5125 does anyone have this setup and can tell me the size i will need to order . I just want to order all the parts i need so my truck isn't sitting in pieces for for a week. btw it's for my 06 dclb 4x4. thanks for any help :)
  2. Aug 16, 2011 at 5:39 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You will definitely need the 5125s. Call downsouthmotorsports and they will tell you what size you need.
  3. Aug 16, 2011 at 5:44 PM
    rcfreak201
    rcfreak201 Well-Known Member
    i just got the alll pro pack as well! i called DSM because my 5100s are too short, i found out they make a 0-1" lift 5100 and 3-4" lift 5100, we need the 3-4", i also called all pro and they said if we wanted nicer shocks the exact length we need is 9", most shocks also need a stem to eye conversion which provides about an inch so in that case you need an 8" shock. bolt on= 9". stem to eye conversion= 8" shocks, hope that helps!
