Need advice ~ Drum Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07 sport 4x4, Oct 20, 2011.
  1. Oct 20, 2011 at 4:53 PM
    07 sport 4x4
    07 sport 4x4 [OP] Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I have been noticing a little more of a clunk when i let off the brakes to take off than i usually do, so i decided to have a look at the rear brakes, the drums look fine i think, but how much pad should they have remaining? I took off the passenger side drum and took some pics any help would be appreciated. Thanks!
    [​IMG][​IMG]
  2. Oct 20, 2011 at 4:55 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    can't see your pics it shows this:
    This content is currently unavailable
    The page you requested cannot be displayed right now. It may be temporarily unavailable, the link you clicked on may have expired, or you may not have permission to view this page.
  3. Oct 20, 2011 at 5:06 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    It's a Facebook link. We have to be your friend to see it. There's a Tacoma World on FB that you can post them to. Just like the page to get on there.
  4. Oct 20, 2011 at 5:09 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Rear drums should basically last forever. How many miles on your 07?
  5. Oct 20, 2011 at 5:18 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    roughly 42,000
  6. Oct 20, 2011 at 5:22 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Pics are up now
  7. Oct 20, 2011 at 5:23 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    right off the top Id say it looks like they need a good clean and adjust, Also add a dab of brake grease to the backing plate where the shoes ride.. Also possible your drums are warped.
  8. Oct 20, 2011 at 5:25 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    The drums look ok to me, and i tried to adjust them using some info i found on here, but couldn't get much adjustment.
  9. Oct 20, 2011 at 5:25 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    could use a cleaning, dont touch the shoe brake surface or the inside of the drums, brakes hate grease on friction points
  10. Oct 20, 2011 at 5:26 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    You still have almost half you pads left. There fine. Might just need adjusting?
  11. Oct 20, 2011 at 5:27 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    put everything back together, go into reverse and apply ebrake as you're rolling, that should adjust them
  12. Oct 20, 2011 at 5:30 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Will do, i'll let you know how it goes!
  13. Oct 20, 2011 at 5:31 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    Is that how you adjust them? Wow I didn't know that. I was tighting the thing on the back of the drum until they stopped freely spinning.
  14. Oct 20, 2011 at 5:34 PM
    jandrews
    '09 FourDubDee TRD OR
    Supposedly they're self adjusting. FWIW, I've never seen self-adjusting drum brakes that did as well self-adjusting as a manual adjustment did.
  15. Oct 20, 2011 at 5:37 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    Wouldn't hurt to bleed the brakes ether. I got a few bubbles out of mine from factory.
  16. Oct 20, 2011 at 5:39 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    Gonna try it in the morning before I go to work. Thankx for the info.
  17. Oct 20, 2011 at 5:43 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    what he said. I would also brush some neversieze(copper), or white lithium grease on the axle hub, between the studs, on the studs, and around the hub where the rust is. this will help you to able to get the drum off next time a little easier. I do it to the front hubs also. ever have to change a flat and the wheel is rusted on? it sucks.
  18. Oct 21, 2011 at 5:31 AM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    That clunk could mean you have to lube the propeller shaft. Could also be a u joint. :cool:
  19. Oct 22, 2011 at 10:57 AM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I checked the shaft before I posted and all u-joints seemed to be tight as a tick. I grease them at every oil change! Thanks for the tip though.
  20. Oct 22, 2011 at 11:13 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    My 96 made a noise like this. We couldn't ever figure it out. Then one day when I got a new muffler it went away. So mine was somewhere between the catalytic converter and my exhaust tip vibrating.
