Need advice for 285/75R/16 tires and rubbing
Discussion in 'Wheels & Tires' started by bethsnes007, Feb 19, 2015.
  1. Feb 19, 2015 at 8:14 PM
    bethsnes007
    bethsnes007 [OP] New Member
    Bethany
    2014 PreRunner SR5 Tacoma
    I have a 2014 PreRunner Double Cab 2wd Tacoma. I just bought 16 x 8 after-stock rims - 0mm. I currently have no lift but am planning to get a 3" lift so I can put BFG KO2 (285/75R/16) - these are 33" tires. I do not do much, if any, off-roading. I am mainly looking to give my truck an aggressive look. Could anyone recommend a descent and cost-friendly lift kit that make room so these tires do not rub? Also, would I need wheel spacers?
  2. Feb 19, 2015 at 8:18 PM
    iseeredandyellow
    iseeredandyellow I wanna go fast!
    Jeff
    San Diego
    10 DCSB 4wd OR Speedway Blue
    Man if only they had a thread on this already...
  3. Feb 19, 2015 at 8:19 PM
    iseeredandyellow
    Jeff
    San Diego
    Just kidding. Welcome to TW. There is a search tab at the top of the screen. Tons of threads on this!
  4. Feb 19, 2015 at 8:21 PM
    bethsnes007
    Bethany
    Ahhhh, thanks! Now if only I can find the answers.
  5. Feb 19, 2015 at 8:28 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yeah, so the previous post from iseeredandyellow is sort of correct but just about every thread has tons of variables. So, NO, there is no single package that someone can/will prescribe. They all get you in the ballpark and then you just have to do work from that point forward. More of a build not buy type approach.
    Everyone has opinions and I don't have a clue on spindle lifts, but 285 are wide. And with zero offset you are more than likely going to rub the fender wells and mudguards. Nothing extreme, but spacers may help along with minor trimming (nothing metal).
    Search Prerunner Lift Threads
  6. Feb 19, 2015 at 8:29 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Get some maxtrac spindles
  7. Feb 19, 2015 at 8:38 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    2013 Prerunner Silver
    4in MaxTrac Lift Spindles, 2in Pro Comp AAL, MB 352 16x8.5 Wheels, 285/75/r16 General Grabber AT2s, 2.7L I4
  8. Feb 21, 2015 at 9:20 AM
    bethsnes007
    Bethany
    Thanks, guys! I believe I will end up going with the MaxTracs. Now for the rear: I have done a good bit of researching. I think I am going to go with a 3" leaf pack. From what I understand, I will need brake lines with these, along with u-bolts and shocks. Could I run these new leafs with my stock shocks for a while? I plan to get the Bilstein 5100s, but would prefer to put them in later, ($$$)... What do you guys suggest?
