Need advice on body mount bushings.
Discussion in '1st Gen. Tacomas (1995-2004)' started by james, Jun 17, 2011.
  1. Jun 17, 2011 at 4:32 PM
    james
    james [OP] In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    Hey.
    I need some advice: my body mount bushings are worn out and in need of replacement: I'd like the comfy ride of the stock rubber, but I know they're going to wear out again.
    Polyurethane don't do that. But is there a polyurethane option that won't transmit road vibration? Anyone know of a "soft" polyurethane bushing option and who might sell it?
    Thanks in advance.
  2. Jun 18, 2011 at 9:38 AM
    james
    '98 Tacoma V6
    bump.
  3. Jun 18, 2011 at 11:40 AM
    newskooler
    newskooler Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
  4. Oct 6, 2011 at 1:18 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    Navigation, 10" sub, ome881 on billies 3" all-pro leaf springs with billies, taneau cover, k&n intake,axle swap with a E locker. 31" BFG A/T on premium wheels, hoola girl air freshener and a broadie knob!
    Bump
    Does the energy suspension kit come with all the ones you nee for the whole truck? Cab and bed?
  5. Oct 6, 2011 at 1:55 PM
    mdub
    mdub Active Member
    Missouri
    01 Tacoma Ext Cab
    3" Body Lift 15" Wheels, Over sized Tires
    Do you have to get new body mount bushings when you take off the lift? I'm close to pulling the trigger of taking off my body lift, I was hopeing it would be almost as simple as loosening bolts, raising the bed, pulling out the puck and then tightening bolts again.... are shorter bolts necesary?
  6. Oct 6, 2011 at 2:47 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    No you don't have to replace them from what I hear. I'm not too sure though but it's recommended to change them anyway for a quieter cab when you drive.
    I don't know, but if the body lift didn't require certain parts of the stock bushings you may not have all the parts to put it back to stock.
    I'm in the process of taking mine off too, seems to be alot of that going around lately. My previous owner had the one on my truck put on so I've been doing alot of fixing his ghetto set ups the more I Learn about these trucks of what's good and whats bad
  7. Oct 6, 2011 at 4:24 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I put on the energy suspension bushing kit when I got rid of the bodylift, it had all the parts necessary for the cab and rad cradle except the nuts and bolts, but you will need shorter bolts for the bed but the bed is a straight bolt on unless you want to put a bit of a rubber gasket but I think it would just get squeezed out.
  8. Oct 7, 2011 at 6:59 AM
    mdub
    mdub Active Member
    Missouri
    01 Tacoma Ext Cab
    I searched TW and googled it.... but I'm not having luck on finding what the Stock Bolt Length/size/etc is for the 1st Gen Tacoma's for the body mount... anyone have that info so I can go to Ace and buy the proper bolts?
    Thanks!
  9. Oct 7, 2011 at 7:10 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    How was that body lift removal? I hear it's not too difficult but rather tedious? How did you lift/lower your cab? I'm thinking 2 floor jacks elevated on wood blocks on either side. I worry about the smoothness of the drop that I would get from floor jacks, I don't want to pinch or jam anything.
    By the way what's the rad cradle?
  10. Oct 7, 2011 at 2:02 PM
    newskooler
    Nick
    Lake Shastina,ca
    if you have a couple of buddies come around and help lift the cab isnt too heavy and you only need to lift and few inches max, the bed my girlfriend and i moved no problem.
    rad cradle- im guess the brackets that hold the radiator on the bl needs the radiator to sit lower than the stock location. mine where 4 pieces of flat strap with carriage bolts. it basically just made and extension. i just removed them and mounted the radiator back into stock position
    the previous owner bought all the hardware directly through toyota, it was spendy but made my life so much easier when doing the body lift
  11. Oct 9, 2011 at 9:14 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    You say only the bed uses smaller bolts? So van the cab reuse the same bolts used with the lift than?
  12. Oct 12, 2011 at 11:38 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
