Need Advice on Lift
Discussion in 'Suspension' started by DSully72, Oct 7, 2011.
  1. Oct 7, 2011 at 10:22 PM
    DSully72
    DSully72 [OP] 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    Looking at getting a 3" procomp or fabtech spacer lift for the front with some aal's in the back. Basically I just need pros and cons. Thanks tw! :D
  2. Oct 7, 2011 at 10:40 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i can only speak on 3" revtek and AAL lift, it was a ok lift when i had it, it rode stiff in the front and couldn't really tell what the rear felt like. I do some off roading and the spacer adds more load to the spring making it stiffer= rough ride. if your a mall crawler and don't take it off road its great for looks but if you do offroad and you want a soft/better ride get a suspension lift, re: toytec, kings, fox's for the front and the back i think a AAL would be just fine.
  3. Oct 7, 2011 at 10:43 PM
    Banff2007Tacoma
    Banff2007Tacoma Well-Known Member
    Dave
    Alberta
    2007 Tacoma Black Sand Pearl TRD Offroad.
    GPS Navigation System, Old Man Emu complete lift with Dakar springs. Light Racing UCA's. BFG AT tires, KMC Enduro rims, Allpro E-locker guard. ARB Portable Air Compressor CKMP12. Backflip Tonneau Cover. Wet Okole seat covers.
    I am by no means an expert on lifts but after reading a bunch of threads on here the spacer lifts are not a good idea especially if you are doing any kind of off roading even mild off roading. However if thats what you want by all means go and get it but I think there are better options out there for a little bit more money.
    Here is a link to another thread about spacer lifts that might help your decision. Also hopefully others who are way more experienced then I can chime in and give you some solid advice.
    http://www.tacomaworld.com/forum/suspension/175699-type-spacer-better.html
    Good luck with what you choose and looking forward to your build.:cheers:
