Need aftermarket block heater for V6 4L Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lawrence72, Jan 21, 2015.
  1. Jan 21, 2015 at 8:42 AM
    Lawrence72
    Lawrence72 [OP] New Member
    Lawrence
    Toronto
    2006 Tacoma V6 4L
    Hi, I have a 2006 Tacoma V6 4L Double Cab. I am heading up north and need a block heater installed. Toyota doesn't make the part anymore. Can someone tell me what aftermarket part I should order. I am in the Greater Toronto Area. Thank you! Lawrence 72
  2. Jan 21, 2015 at 11:14 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Are you saying a Toyota dealer can't install a block heater for you in TO for a 2006?
    I thought all Canadian vehicles just came with them.
  3. Jan 21, 2015 at 11:22 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    I used this on my 5.0L, worked great for the 10 years and 215,000 miles I owned the truck. It's very simple. It just heats the oil pan itself. If this induces moisture I don't know but I had success w it.
    https://www.wolverineheater.com/category-s/1477.htm
  4. Jan 21, 2015 at 11:51 AM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    i say BS to that.Your in toronto go to another dealer.They were just too lazy to order you one.
  5. Jan 21, 2015 at 5:31 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I grew up a few miles from the Candian border and always used the circulating coolant haters. Seemed to keep the oil warm enough and helped keep the windhield free of ice. Dont know how well one would work on a vehicle made after 1969 though.
  6. Jan 21, 2015 at 5:36 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I just (last November) installed part number PU140-00902 in my 4.0L V6. Ordered it from the dealer in Windsor.
  7. Jan 21, 2015 at 6:49 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
  8. Jan 22, 2015 at 5:09 AM
    Mizzouborn
    Mizzouborn Well-Known Member
    Tampa, FL
    06 Tacoma PreRunner
    Thorley Headers Dual Exhaust Flowmaster 40s Bilstein Shocks/Struts K&N Air Filter
    I'm not sure you really need a block heater. I was in Alaska for 3 yrs and prior to going I had one installed in my car's engine (it was a V6 also) but never really needed it. I DID get a battery "warmer" (it wraps around your battery and plugs in) and that worked great.
  9. Jan 22, 2015 at 6:23 AM
    Pigpen
    Dan
    Northwest Montana
    The nice thing about the block heater is that your oil warms faster upon startup. Cold oil going into a warm block...
    The part you need is still made. Check other sources. Install is pretty easy, there are a couple helpful threads on this.
    Do you need it? No. It does make cold starts easier on your engine, battery and starter. You decide.
