Need an amp
Discussion in 'Audio & Video' started by awoit, Mar 7, 2008.
  1. Mar 7, 2008 at 11:05 AM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    I need an amp for my JL audio 10inch W3V3 2OHMS... dont know much about what type of amp i need. pretty sure it needs to be 300 watts? but i dont know what brand or the channel stuff, advice would be nice =]
  2. Mar 7, 2008 at 11:35 AM
    PatheticJoe
    PatheticJoe Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
    The issue with that speaker is the 2 ohm voicecoil. If it was 4 ohm or higher any of a few 100 amps would work but since its 2 ohm your pretty limited. Basically you need a mono amp thats 2 ohm stable. Jl audio makes a 250/1 thats pretty good but a bit pricey, Hifonics makes several that fit the bill and Ebay typically has good deals on these. However my best recomendation is Rockford Fosgate. Their mono amps are really good for the money and look nice as well. I looked it up on Ebay and you can get one for only $150 brand new that will do 300W at 2 ohms (it ends it 20 mins though). Let us know what you pick up and how it sounds.
  3. Mar 7, 2008 at 11:36 AM
    utixrunner
    utixrunner I <3 Boost
    Florida
    2007 SWB X-Runner
    TRD S/C, DT Long Tube Headers, Jardine Catback, TRD Intake, Trd Short shifter, TTC Dual Traction Bars, Sway bar bushing kit, c2c lowering kit, lots of other little things
    jl audio 250/1 but ya they are on the expensive side
  4. Mar 7, 2008 at 12:10 PM
    08beachtoy
    08beachtoy Well-Known Member
    Maryland
    08' reg cab 4x4 2.7ltr 5 spd
    Sony cd player /ipod , small amp, bed mat from Dee Zee , A.R.E. custom cap with yakima racks, weather gaurd floor mats , oem fog lights ,oem DRL mod, class III hitch ,custom bed mounted power inverter, tinted windows 5 % all around, oem hood protector /bugshield , avs door visors ,wet okole seat covers , Train air horn
    call crutchfield 1-800-555-8211 those guys are awesome and yes the rockford fosgate amps are awesome I have one in my civic it thumps two 10s' like its nothing
  5. Mar 13, 2008 at 6:59 PM
    bob857
    bob857 Member
    08 Tacoma 2.7 5spd
    I know this is an older post but... How about Profile's California series AP700M mono subwoofer amp?
    • mono subwoofer amplifier
    • 220 watts RMS x 1 at 4 ohms (350 watts RMS x 1 at 2 ohms)
    • MOSFET power supply
    • remote-mount level control with 16-foot cable included
    • selectable bass boost (0-12 dB) at 45 Hz
    • variable low-pass filter (50-250 Hz, 12 dB/octave)
    • subsonic filter (20-50 Hz, 12 dB/octave)
    • preamp- and speaker-level inputs
    • preamp outputs
    • fuse rating: 20A x 2
    • 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
    • 11-5/16"W x 2-1/16"H x 10-1/4"D
    • warranty: 3 years
    Buy it from an Amazon Associate for about $95 (inc. S&H) or from Crutchfield $130.
