Need an engine for my 2008
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Az08Taco, Nov 3, 2018.
  1. Nov 6, 2018 at 5:47 PM
    broke_down
    broke_down highly opinionated with little experience
    2010 Green Tacoma Extended Cab
    Time for an LS swap? Or a V8 from a tundra?
  2. Nov 7, 2018 at 9:38 PM
    tcjacado
    tcjacado Well-Known Member
    How did it go today?
  3. Nov 7, 2018 at 9:52 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I hope that rebuilt motor comes with a good warranty....otherwise, you might be in the hole on expenses. I'm not spending your money but I would think twice about rebuilding and reselling.
  4. Nov 7, 2018 at 10:14 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Gasket kit, bearings, crank, water pump, incidentals, valve job, and incidentals, to rebuild, if your friend does the work for free your looking at close to $2000.
    I'd part it out.
    Heads, valve covers, timing cover, injectors, fuel rail, water pump, coils, intake, fan and clutch, etc... Probably make more profit.
  5. Nov 12, 2018 at 10:29 AM
    Az08Taco
    Az08Taco [OP] Member
    08 Tacoma 4dr 4x4
    Ok so we made it home to Phoenix. Took up 14 hours to do a 9 hour drive! Of course that includes 2.5 hours sitting on the side of the freeway waiting for aaa towing. Battery was toast. Pretty sure the alternator is going to shit. Driving down the road at 65mph, about 2 hours into the drive, the battery light comes on. Then the ABS, and e brake lights come on. I pulled over to check things, and then tried to start it. Yeah the battery won't st the truck. It read 12.2 on my multimeter, but when my wife went to start it, it dropped down to 3.2. So called AAA roadside for a battery. Guess what? The service provider in that area doesn't do battery installation or delivery. I had to be towed to an autozone. Installed a new battery, and had the guy test the charging system and the starter. All good to go. Passed with flying colors. 3.5 hours later, the battery light comes on again. Then it goes off for a little bit, then on again. My wife and i play the game we ended up calling, "how long will the battery light stay on this time?!" Well got back to Fountain Hills, 20 minutes from home, and the lights are going dim, battery light has been on for like 4 hours, and it's done. ABS and e brake light are on, speedo is at zero mph, because not enough power to run it. No more power in the system. I pulled over, called an uber to take me to a local autozone. Get a new battery, uber back to the truck, and put it in the truck and drive the last 20 minutes home.
    End of my nightmare............... or is it?
    Nope!!!!! I have to get a new alternator!!!!!
    PzTank, jboudreaux1965 and tcjacado like this.
  6. Nov 12, 2018 at 10:35 AM
    Muddinfun
    Muddinfun Well-Known Member
    Soooooooo, you blew up the motor, had a used motor put in and after that you had charging system problems? Do you know if they used your old alternator, or the one with the used engine? Or maybe they didn't tighten the nut holding the wire on the alternator.
  7. Nov 12, 2018 at 10:40 AM
    tcjacado
    At least your home.:thumbsup:
    eherlihy and Az08Taco[OP] like this.
  8. Nov 12, 2018 at 10:59 AM
    Az08Taco
    08 Tacoma 4dr 4x4
    Yeah we used my old alternator. Eveything is tight on the alternator.
  9. Nov 12, 2018 at 11:44 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I vote something is loose somewhere. A ground maybe but you are fine then you loose charging.
  10. Nov 12, 2018 at 12:24 PM
    Az08Taco
    08 Tacoma 4dr 4x4
    I did find the main ground wire in the ecm box was loose. I've tightened it down now.
    ovrlndkull[QUOTED] and tcjacado like this.
  11. Nov 12, 2018 at 12:36 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Now see if you are still having charging issues before replacing the alternator. I would bet you are fine now. Grounds are just as important as power wires and many times overlooked.
  12. Nov 12, 2018 at 12:39 PM
    Az08Taco
    08 Tacoma 4dr 4x4
    That's the plan.
    tcjacado likes this.
  13. Nov 12, 2018 at 8:11 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Glad you guys made it home safe and sound bro, that's what matters. :)
    Az08Taco[QUOTED][OP] likes this.
  14. Nov 12, 2018 at 8:27 PM
    Az08Taco
    08 Tacoma 4dr 4x4
    Thanks. Drove it around today, and didn't have any issues at all. Hoping it stays that way. Lol
  15. Nov 12, 2018 at 8:38 PM
    #35
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Since it was installed at a dealership, I'd check your engine oil level, on jobs like that, dealerships tend to over fill. Over filling can kill a 1GR-FE just as quick as under fill. Also, since it's an LKQ engine, sometime in the near future, sooner than later I'd drain the oil, check for debris with a flashlight and a magnet, and pull the lower oil pan (it's easy) and check it for any debris. LKQ has some serious FINE print as far as warranty.
    Just suggestions :)
  16. Nov 12, 2018 at 8:46 PM
    #36
    Az08Taco
    08 Tacoma 4dr 4x4
    I installed the engine with the help of 2 others, not a dealership. I'll be changing the oil this weekend, and will be doing exactly as you said
  17. Nov 12, 2018 at 9:38 PM
    #37
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    On top of your game, bro! My bad, just suggestions, just in case :)
    Az08Taco[OP] likes this.
  18. Nov 13, 2018 at 5:13 PM
    #38
    Az08Taco
    08 Tacoma 4dr 4x4
    UPDATE:
    Tightened down the ecm ground cable, and amazingly no more charging issues. Truck is running great!!
  19. Nov 20, 2018 at 8:12 AM
    #39
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    How much over filling of the oil will kill the 1GR?
  20. Nov 20, 2018 at 8:54 PM
    #40
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Once the oil level is high enough to where the crank makes contact with the oil. I'd stay under 1/2" over on the dipstick for sure.
    A good example, take a bottle of oil, cooking oil, whatever. Shake it up a whole lot. See the bubbles? That's called aeration, the oil gets super saturated and thinned out with tiny air bubbles, the oil loses it lubrication properties and also lowers oil pressure. That will kill any engine, 1GR-FE is very sensitive to oil pressure and also uses oil pressure for chain tensioners.
