Need an in dash tach
Discussion in '4 Cylinder' started by tacolibre9, Jun 2, 2014.
  1. Jun 2, 2014 at 3:27 PM
    tacolibre9 [OP] Member
    May 30, 2014
    Thousand Oaks, CA
    '04 taquito
    3" fabtech Lift, K&N intake, Powertraxx lock right locker
    Hello fellow toyota enthusiasts. I'm here so I thought I'd start, my first post with a question. I have an '04 regular cab 2.4L taquito with a manual 5 speed that I'm in the process of making a daily driver/ desert toy. I know I will be push my little 4 banger hard but I don't want to push it to the blowing point. Right now I have no tachometer I shift by sound and feel, while I'm good at that on the streets I worry when I'm desert running i might be shifting closer to the red line than I should. So before I throw LT on it and hit Huckfest I want to put in a tach, but I want to avoid mounting one on my dash. Does anyone know of a different model or year of toyota that has a tach in the oem gauges that will fit in the 1st gen dash? or possibly a company that makes an aftermarket version?
    Thank you for the help and for reading my longwinded post haha
  2. Aug 6, 2014 at 5:52 PM
    2 wheel drive
    2 wheel drive Member
    Aug 6, 2014
    Marietta, GA
    2001 Tacoma regular cab
    Autometer tach, spray in bedliner, sliding rear window, Sirius satellite radio
    I installed an Autometer "mini tach" (#2891) in 2004 in my '01 Taco. The #2306 appears to be similar. Removed the ash tray, used the ash tray light feed for tach backlight. Bolted the tach to the underside of the ashtray mount-probably with a homemade bracket (can't specifically remember). Use the either the cig lighter or one of the aux power plugs for power. I think they are both ignition switched. Pin 9 on the OBD II connector is a tach terminal for the '01. Soldered a pin to the tach feed, held my breath and plugged it in. Then painted a witness strip on the terminal so that I can disconnect it for the smog test and easily reconnect it. I angled it up so that with a downward glance you can easily see it. Looks nice.
    You will need to research the wiring diagrams to verify that this will work on your '04.
