need bolt sizes
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Jun 26, 2011.
  1. Jun 26, 2011 at 3:33 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    Im getting ready to put my lift on. I have purchased camburg ucas, toytec coils, bilsteing 5100 front shocks, 5150 rear shocks and all pro 3" leaf packs (not the expedition) i thought it would be a good idea to have bolt sizes for the ucas and for the new leafs going on in case one or more break (very apt to happen) does anyone have the bolt sizes? also, is there anything else i need for my lift?
  2. Jun 26, 2011 at 6:38 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Anybody?
  3. Jun 26, 2011 at 10:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Sorry guy, can't help with the bolt sizes.
    As for what else you might need. Definately want to use new u-bolts. I'd also recommend having a new set of poly bushings for the leaf spring fronts. You'll likely destroy the originals getting them out. Wheelers is a good source for both of these items.
    Those camburg UCAs look awesome. I am considering those. Look forward to hearing about how they work out.
  4. Jun 27, 2011 at 12:29 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    the all pro leafs i ordered came with new poly bushings, did you reuse the stock bolts that go through the eye of the leafs or did you buy new ones?
  5. Jun 27, 2011 at 8:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I did not reuse the stock ones. I could have because mine came apart relatively easily. But I've seen many examples where that bolt had to be cut off to get the old spring off.
    Knowing that I ordered the poly bushing kit from wheelers that included a greasable type replacement bolt.
  6. Jun 28, 2011 at 5:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Yea. Be prepared to cut out the old bolt. The metal spacer in the middle of the old rubber bushing likes to seize onto the bolt. Beating it out usually won't work.
    Measure the old one and get a new grade 8 bolt of the same size or slightly longer.
  7. Jun 28, 2011 at 1:44 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine all came apart relatively easily when installing my shackles...I just hit the bolt until I could get a pry bar on the head end and it slid right out.
  8. Jun 28, 2011 at 5:20 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    His has six years on yours!
  9. Jun 29, 2011 at 1:21 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    haha yeah thats my worry, for example when i was taking my sway bar off, every bolt broke off:eek:
  10. Jun 29, 2011 at 1:23 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Not sure on sizes but new eyebolts and u bolts are definitely a good idea. I had to cut my front eye bolts off...
  11. Jun 29, 2011 at 1:27 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    and you just went down to a hardware store and replaced them with new grade 8 bolts?
  12. Jun 29, 2011 at 1:32 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    i have to cut off my leaf bolts i tried Ace but they didn't have the right size so I bought them from the dealer they were about 6 bucks each.
  13. Jun 29, 2011 at 3:04 PM
    MowTaco
    Kansas
    True. Plus the 5 lugger doesn't see much wheeling
    Plenty of salt though....
  14. Jun 29, 2011 at 4:22 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    thanks man, thats probably the route im gonna have to go, and as for the ucas, the bolts for them would be found at the dealer as well huh?
  15. Jun 29, 2011 at 9:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I thought the camburgs came with new bolts. Did you get yours used? You may be able to re-use the stock ones... :notsure:
  16. Jun 30, 2011 at 1:56 AM
    SPOTSONTROUT
    SPOTSONTROUT Well-Known Member
    ROB
    SOUTHERN ONTARIO CANADA
    03 TRD Stolen
    OME 882,DAKAR LEAF PAC WITH ADDA LEAF,285 TOYO OPEN COUNTRY MT,RACELINE RENAGADES,DECK PLATE MOD, MANUAL HUB CONVERSION
    I just did my leaf packs ,ended up having to buy the new eye bolts from the dealer . They are M14x1.5 x 100 long grade 8. Try getting them somwhere else te dealer was expensive. I used a sawsall to cut mine off make sure you have lots extra blades.
  17. Jun 30, 2011 at 9:15 AM
    kmok
    Kyle
    Columbus, Ohio
    Yep that's exactly what I did
