Need brake controller help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew3625897, Jun 11, 2019.
  1. Jun 11, 2019 at 6:24 PM
    andrew3625897
    andrew3625897 [OP] New Member
    2010 Tacoma Trd with tow package. I have been trying to figure out the wiring harness for a brake controller.
    From my research it looked like I needed the Tekonsha 3040-p harness but it does not fit the only port I found that is free.
    Is this the right place to plug into for brake controller?
  2. Jun 11, 2019 at 6:33 PM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    In my 2010 it was this one. There should be a pigtail that comes with the truck that you can wire to work. That's what I did. I wired it to a 4-pin trailer plug, then wired the controller to the opposite side of the 4-pin plug. That way I could always change the controller if I needed to.
  3. Jun 11, 2019 at 6:35 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    It comes in the glovebox
  4. Jun 12, 2019 at 12:47 AM
    andrew3625897
    This is what Iv been looking for but cannot find it. I don’t think what I’m holding is what I need and Im stumped.
  5. Jun 12, 2019 at 1:47 AM
    caribe makaira
    Caribbean, Puerto Rico
  6. Jun 12, 2019 at 4:15 AM
    pmstoy10
    hudson valley, ny
    Keep digging. It's in there. It took me a while to find the first time
    jproffer likes this.
  7. Jun 12, 2019 at 4:51 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Mine was WAYYYY up there on the back side of the wiring loom. Had to cut some of the tape loose to find it. That was the hardest part. It is up and behind the big wire bundle on the drivers side up above the brake.
  8. Jan 18, 2021 at 12:25 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It’s a bitch to get to. It took me hours to find. It was buried in tape inside and on the back of the big bundle of wire by the ebrake pedal under the dash.
    Berniebikes and Walldiver7 like this.
