Need Car Audio Wiring Expert
Discussion in 'Audio & Video' started by THXEY, Jun 24, 2012.
  1. Jun 24, 2012 at 3:05 PM
    THXEY
    THXEY [OP] Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    So I have a 12" kicker L5 dual voice coil. About 6 months back a buddy of mine required it to 1 ohm. It's worked fine up until now, any song I play that has a good kick to it just shuts off my amp powering my sub, essentially making my sub useless. I was tonna to to him to fix it but he lives a solid 45 minutes away. So before I go to him I figured Id ask here. So how do I.... Un-rewire my sub, to turn it back to factory condition? I want to give it a shot because it took my friend all of like 5 minutes to rewire it.
    Thanks guys
  2. Jun 24, 2012 at 3:10 PM
    LEGITacoma
    LEGITacoma Well-Known Member
    Louisiana
    99 Tacoma Prerunner
    Rockford Fosgate T0 in a Ported Box, Hifonics 1000.1, Pioneer AVIC Z-120BT Headunit w/ Rearview Camera
    That's strange that it would just stop working like that. Your amp wasn't overheating? All the fuses are good? You didn't fry your wiring? If your box has a plastic terminal cup check that. I melted one of them suckers on my last box. Other than that you have a to wire it just like the first picture on the right on this page.http://www.kicker.com/dvc_wiring
  3. Jun 24, 2012 at 3:18 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
  4. Jun 24, 2012 at 3:19 PM
    cosgrc
    cosgrc Well-Known Member
    Madison, AL
    2012 MGM DCSB TRD Sport 4x4
    OME Lift, 887, Dakars
    If your amp isn't 1 ohm stable it will shut it off....
    Assuming your sub is 2ohm DVC, it sounds like your sub is wired in parallel (positive from one voice coil to the positive of the other, then the negative from one wired to the other negative. Then from one of the voice coils it should go out to the terminals on your box. You need to run your sub in series to gain 4 ohm. Take the POSITIVE from one voice coil and put it to the NEGATIVE of the other voice coil. Now take the POSITIVE from the terminal where the negative is already jumpered to the other voice coil and then the NEGATIVE where it is jumpered to the positive on the other voice coil and run those to the box termianl. If you have a DMM, validate the impedance is 4ohm.
    https://www.icmag.com/ic/picture.php?albumid=7678&pictureid=133877
  5. Jun 24, 2012 at 3:20 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    You need Proforce in here....Paging proforce!
  6. Jun 24, 2012 at 3:27 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    SoCal - Fontana
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Please list exact model of sub and amp. Is your amp 1 or 2 channel?? And please take you sub out of the box and check if it has 1 set of.wires connecting to it or 2
    We need to know how many voice coils are on your sub and how many ch your amp is. With that we can get it rewired easily. You can pm me if you want. But seems like most people that responded are on the right track.
  7. Jun 24, 2012 at 3:34 PM
    THXEY
    Jacob
    San Diego
    2013 Subaru WRX
    My amp is an alpine 500 watt mono block, my sub is a DVC 4ohm kicker l5
    Cosgrc was right, the postive terminal was on the postive and the negative was on the negative. So I switched it around, now should I be all good?
  8. Jun 24, 2012 at 3:40 PM
    cosgrc
    Madison, AL
    If its 4ohm DVC, then it should only be 2ohm parallel and 8ohm if you went series? Not sure how you got 1ohm. If the amp is mono, only use 1 channel, don't attempt to bridge the amp.
  9. Jun 24, 2012 at 3:47 PM
    THXEY
    Jacob
    San Diego
    2013 Subaru WRX
    So I have the positive wire to the negative terminal and vice versa
    The thing that doesn't look factory is the wire going from the terminal im pointing at, to the terminal on the other side of the magnet
  10. Jun 24, 2012 at 3:50 PM
    THXEY
    Jacob
    San Diego
    2013 Subaru WRX
    That's way past my knowledge I haven't touched the amp.
  11. Jun 24, 2012 at 3:58 PM
    DevL
    DevL Well-Known Member
    Its beyond anyone because its not part of this reality. You cannot bridge a one channel amp. Bridging is taking a 2 channel amp and turining it into a one channel amp by connecting the positive of one channel to the negative of the other.
  12. Jun 24, 2012 at 4:02 PM
    DevL
    Had to edit cause i thought you had 2 subs. If you are at 1 ohm your coils are 2 ohms each coil. Youll go to 4 ohns by rewiring.
  13. Jun 24, 2012 at 4:02 PM
    ProForce
    Anthony
    SoCal - Fontana
    These are you ONLY two options... not sure how you got 1ohm.
    OR
    Only thing I can think of is your amp has only 1 channel, but has 2 blocks on it so you can connect more than 1 speaker to it without splicing... your buddy may have thought it was a 2ch and wired you subs to 2ohms, then "bridged" your amp which would produce a little less than 1ohm but technically that's not possible with a mono block amp. It just appears that way. If your putting that amp into protection mode with only 2 ohms then either your gains are way to high and its clipping or overheating, or your amp is messed up inside, or 1 or more of the coils on your sub are blown which lowers the impedance (ohms) and therefore dropping your amp below 1ohm
  14. Jun 24, 2012 at 4:14 PM
    ProForce
    Anthony
    SoCal - Fontana
    You need a DMM or digital multi meter and you need to completely disconnect all wires from your sub and measure your voice coils impedance to see if they are still at 4ohms. If not, its blown, causing a short circuit at high voltage and therefore putting the amp into protection.
  15. Jun 24, 2012 at 4:48 PM
    THXEY
    Jacob
    San Diego
    2013 Subaru WRX
    Ok well I ran som diagnostics and tests and my sub is fine, I have back to 4 ohms but my amp is fried. So I was looking at the kicker DX 1000.1
  16. Jun 24, 2012 at 5:09 PM
    THXEY
    Jacob
    San Diego
    2013 Subaru WRX
    I'm actually going to pick up a kenwood eXcelon x1200m tomorrow for 160
  17. Jun 24, 2012 at 5:11 PM
    ProForce
    Anthony
    SoCal - Fontana
    How did you determine that the amp is fried??
  18. Jun 24, 2012 at 5:25 PM
    THXEY
    Jacob
    San Diego
    2013 Subaru WRX
    My buddy is an installer, I took it to him and he tested it
