Need cee led light for my 15 tacoma
Discussion in 'Lighting' started by acpracing, Feb 6, 2017.
  1. Feb 6, 2017 at 10:54 AM
    acpracing
    acpracing [OP] Member
    Looking for a set of headlight and fog Cree led light what's a good brand and where can I buy them
  2. Feb 6, 2017 at 10:55 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Feb 6, 2017 at 10:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Are you talking about replacement bulbs?
  4. Feb 6, 2017 at 10:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  5. Feb 6, 2017 at 10:58 AM
    acpracing
    Yes just want to change my st could bulbs with cee led bulbs
  6. Feb 6, 2017 at 10:59 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Not recommended but I let @crashnburn80 better tell you.
    crashnburn80 likes this.
  7. Feb 6, 2017 at 11:00 AM
    acpracing
    I seen a lot of guys do it why would that not be a good idea ?
  8. Feb 6, 2017 at 11:50 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What are you actually trying to achieve? The look of whiter light? Greater light output? The longer life of LEDs? Why Cree?
    Be wary of aftermarket lights that claim to have 'authentic' Cree LEDs, knock-off garbage is abundant online. The problem with LEDs is the stock halogen reflectors are not designed to work with them as the optics are different. Read more and see examples here:
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
    You can do a projector retrofit to solve the glare issues associated with running aftermarket LEDs, and then have a wider variety of LED sources to chose from. If you want a drop in LED replacement to your stock halogen reflectors, Philips is the only maker I am aware of that claims to have replicated stock cut offs and beam pattern for the H4 (though not perfect). You can see my comparison here:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-vs-philips-led-headlights.460313/
    As for fogs, you will need to completely replace the fog housing to run LEDs. You cannot drop in an LED into the fog light reflector without having a compromised beam pattern and emitting glare everywhere (as shown in the first link). TRS sells the leading fog LED replacement which replaces the housing with one designed for LED use:
    https://www.theretrofitsource.com/complete-housings/fog-lights/toyota-oval-morimoto-xb-led.html
    A lot of people make uniformed decisions based on whatever is trendy without doing enough research. You will see many posts where someone is posting a picture facing the front of their truck showing how bright their new LED bulbs are compared to stock, where the LED is emitting glare to the camera washing out that portion of the photo, and they think this is because it is brighter when in fact it is because they have lost beam control. I have an example in the first link I posted.
    Too Stroked and ChadsPride like this.
  9. Feb 6, 2017 at 4:40 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I'll answer that question with several eBay bulb suppliers - but only if you're willing to totally ruin the quality (pattern longevity, glare, etc.) of your OEM lighting.
