Need electrical help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sierrahunter, Jun 30, 2022.
  1. Jun 30, 2022 at 9:12 PM
    Sierrahunter
    Sierrahunter [OP] Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    My camper shell third break light keeps blowing my 10a stop light fuse. The shell third break light is connected to the driver’s side rear break light for power.
    The shell was just installed in November, so the shop wants to install a fusable link to keep from blowing fuses. I don’t understand how that will help. Seems to me that the new fusable link would keep blowing fuses if it’s the correct amperage, which isn’t a solution. Can someone tell me how to fix my problem? thx in advance.
  2. Jun 30, 2022 at 9:28 PM
    SpeySquatch
    2016 TRD OR DCSB
    Maybe install an LED bulb?…
  3. Jun 30, 2022 at 9:29 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Does the light on the shell work? Is the wiring to the light good? Sounds like it’s shorting out the circuit. I highly doubt the camper shell is pulling enough to put the circuit over 10A, I doubled up on brake bulbs and used higher power ones and I still didn’t pop the fuse at all…much more likely you have a short in the shell’s 3rd brake wiring or the light itself.
    Barrydd likes this.
  4. Jun 30, 2022 at 9:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it blow the fuse instantly or randomly?
  5. Jun 30, 2022 at 10:05 PM
    Sierrahunter
    The third brake light is an LED, it does work, and it blows the fuse randomly when the brake is depressed. It took a couple thousand miles for this problem to develop.
    SpeySquatch likes this.
  6. Jun 30, 2022 at 10:10 PM
    BLtheP
    Plano, TX
    I’d say replace the fixture or trace the wiring if you can. Not sure how hidden the wiring is, may need to fish some new wiring up through it. It’s pretty obviously not related to pulling too much draw through the circuit.
  7. Jul 1, 2022 at 12:15 AM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    A few years back, I read a thread here, a user who has a trailer and it has a similar problem. It happen every time the trailer is connected. It turns out that the trailer wiring is short.
    Disconnect the wiring from your camper and test? Check the wiring on the camper for storage.
    Greg-tacoma likes this.
  8. Jul 1, 2022 at 12:38 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    This is your best bet. Use this instead pm @Puppypunter . I got one on my softopper and its awesome .https://www.tacomaworld.com/threads/plug-and-play-brake-light-taps.707529/ . No wire splicing . Plug and play
  9. Jul 1, 2022 at 12:42 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You have a short exposed by vibration. Find it.
    BigWhiteTRD likes this.
