Need feedback on a welding outfit
Discussion in 'Product Reviews' started by LizellaFella, Jun 27, 2012.
  1. Jun 27, 2012 at 3:21 PM
    LizellaFella
    LizellaFella [OP] Well-Known Member
    Eddie
    Reno Nevada
    2016 Tacoma SR5 4x4
    Hopefullly someone here has bought this outfit, knows someone who has, or even a Northern Tools employee who might have knowledge of returns and customer complaints.
    I'm looking at the two listed items for light welding projects around the house. Item numbers are 25494 and 20462 at the northern tools website.
    http://www.northerntool.com/shop/too...isSearch=25494
    I believe the stick welder will be fine, but my question is regarding the tig attachment. The description states, "steel and stainless".
    I question if I can I use this torch attachment for aluminum. Any feedback would be greatly appreciated.
    FWIW, I know its a cheap setup, but for the amount of welding I'll do, I can't see the higher priced wire feed jobs.
    TIA
    LF
  2. Jul 19, 2012 at 6:48 PM
    Dirty Jersey
    Dirty Jersey Rich
    Rich
    South Jersey
    2012 Access Cab - White
    Wet Okole Seat Covers, Debadged, Custom Fit Bed Mat, Cargo Net for Long Bed, All Weather OEM Floor Mats, MX Grillcraft Grill, Bully Tailgate Lock, Mini Mag Center Console Mod, SockMonkey 3rd Brakelight Cover, Lots of Love
    I order to use it for aluminum you have to reverse the polarities, use an inert gas rig and buy the right stinger
  3. Jul 19, 2012 at 6:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya... The Tig option is nice. Generally, a 20-90a stick unit isn't worth a crap.
    I've got a Clark 95e and I haven't touched it since I got my wirefeed.
    For 120v units, fluxcore wirefeed is the only thing hot enough to work... and no stainless or aluminum with that.
    But... I've never done Tig, so beyond the polarity issue, and the fact that you must have the proper shielding gas, I have no idea about the amperage needed for general Tig work... but I do know that aluminum takes a LOT more heat than steel because it is such a good thermal conductor.
  4. Jul 19, 2012 at 7:01 PM
    medic2230
    Murph
    Bama! Roll Tide
    You need more amps (About double) to do aluminum and I believe high frequency. That is a Tig for steel not aluminum. There is more to aluminum than reversing the polarity. It's also a DC machine you weld aluminum with AC.
    This would be the lowest end machine that would do aluminum. From what I have heard from people that tig aluminum this is at the lower end of amperage on the machines top end. It only has a 20% duty cycle at 180 amps. You will want to use straight argon for aluminum.
    http://www.northerntool.com/shop/tools/product_200520339_200520339
