Need guidance on what wheel spec I need for My lift and bigger tires.
Discussion in 'Wheels & Tires' started by TODEOTA, Jul 11, 2012.
  1. Jul 11, 2012 at 11:07 AM
    TODEOTA
    TODEOTA [OP] Well-Known Member
    Jake
    Lewiston, ME
    2000 SR5 4x4 extra cab
    Horn upgrade, 2.5" Rough Country lift going in soon
    I just bought the Rough Country Tacoma 2.5" lift as seem in the link below:
    http://www.roughcountry.com/toyota_95-04_tacoma_2.html
    In the description, it states:
    "32x11.50 tires will fit with wheels with a greater
    offset than factory and/or wheel spacers."
    It's doesn't say what wheel spec they recommend. I have no clue what the Stock 15" specs are. I want to go with a 32x11.5x15 Hankook MT with cragar steel wheels.
    The wheel I have been thinking about is:
    Bolt pattern: 6-5.5
    Offset: -13mm
    Rear spacing: 4"
    Perhaps someone out there knows if this would fit or not, maybe even has this lift with this size tire. Any help is appreciated.
  2. Jul 11, 2012 at 11:17 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    The specs you listed for the wheels should work with the tire size.
  3. Jul 11, 2012 at 11:21 AM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    That is actually a contradictory statement. Wheel spacers work to effectively decrease the offset.
    With that said, I think you should be OK with the specs of the wheels you want to install. Normally an 8" wide wheel with a 0mm offset (4.5" back spacing) is what I use on the '97-04 Tacoma with a 2.5" - 3" lift, but -13mm offset / 4" back spacing should be just fine with 32x11x.5x15 tires.
  4. Jul 11, 2012 at 11:29 AM
    TODEOTA
    Jake
    Lewiston, ME
    Yeah, I caught that too. Figured they worded it wrong.
    These would stick out ridiculously too far, now would they? I can get bushwackers flares if they are out a couple more inches than usual, but I don't want anything more than that.
  5. Jul 11, 2012 at 4:01 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Our fitment guide shows a -13 will fit your vehicle. It will be at the edge.
    Let us know if we can help.
  6. Jul 11, 2012 at 4:35 PM
    TODEOTA
    Jake
    Lewiston, ME
    Okay, sounds good. Thanks guys!
