**NEED HELP** 1ST GEN
Discussion in '1st Gen. Tacomas (1995-2004)' started by Silveryota01, Apr 29, 2017.
  1. Apr 29, 2017 at 5:16 PM
    Silveryota01
    Silveryota01 [OP] Well-Known Member
    Logan
    Conway SC
    2020 Silver Sky Metallic TRD 4x4 OR
    Ok so I have an 01 Tacoma with the 3.4 (5vzfe) and I'm getting a cel with a code that says P0306 which is a cylinder 6 missfire. So far I've replace plugs, plug wires, coilpacks, injector, and plenum gaskets. It's all buttoned back up correctly and every thing was torqued to specs but it is still sputtering and the motor shakes really bad when I give it gas. Any one else ran across this issue before? Really driving me crazy
    Jcyr likes this.
  2. Apr 29, 2017 at 5:23 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Could be timing belt? Or maybe not enough fuel? Was there anything that caused this or did it start after a certain thing got replaced or broke??? Or did it just randomly happen 1k miles after most recent matinince?
  3. Apr 29, 2017 at 5:28 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Start with compression test. Dry and wet.
  4. Apr 29, 2017 at 5:30 PM
    tony2018
    tony2018 Well-Known Member
    compression test, combustion test next, and finally when was the last time you clean your injectors or done an ignition tune up?
  5. Apr 29, 2017 at 5:59 PM
    Silveryota01
    Logan
    Conway SC
    I did a tune up about a year ago the same time the timeing belt and water pump was replaced. I did recently have a new cat installed when I redid my exhaust. With new denso sensors. Checked and everything seems to be good no lose bolts or anything. And is there an easy way to check compression or do I need a shop?
    Jcyr likes this.
  6. Apr 29, 2017 at 6:01 PM
    Jcyr
    Jack
    North east
    Super easy if you have the tools it just goes in the spark plug hole. Auto zone might have one for you to rent for the day or go to a local harbor freight
  7. Apr 29, 2017 at 6:07 PM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    Go to orileys you can borrow one, very simple, take out plug and this is important ! Take all coils off plugs, crank for about 5-7 seconds since you won't beable to see when the needle stops gaining pressure just crank for that long to insure you get proper readings, at 280k my truck was 125 psi when I had my old t100
    Jcyr and Silveryota01[OP] like this.
  8. Apr 29, 2017 at 6:10 PM
    Silveryota01
    Logan
    Conway SC
    Mine just rolled 214 and never gave me an issue. Went to leave for work and half way there started sputtering and lost a lot of power. But thank you very much brother I'll definitely try and get the stuff first thing tomorrow. I'm hopeing it's nothing serious.
    Jcyr likes this.
  9. Apr 29, 2017 at 6:19 PM
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    Well, honestly you can check the injector right now to, put your finger on the injector and see if you can feel it tick out your finger on the others try and really feel it if you can obiously tell then go get a thing of marvel oil and fill your tank with that and goood gas!! Give it some good driving and if it don't help in 25 minutes of 80mph it probably won't help just go buy some injectors and google how to do it, shops are overrated
    Silveryota01[OP] likes this.
  10. Apr 29, 2017 at 7:16 PM
    Silveryota01
    Logan
    Conway SC
    Injector was replaced still have the same issue it was easy just time consuming bc it was under the lower plenum. I'll definitely try the marvel tho
  11. Apr 29, 2017 at 7:51 PM
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    Dude if you've replaced all that and still can't get it to fire I think your rings in that cylinder are bad, what else would cause that :confused: you should check that psi and get back to us !
  12. Apr 30, 2017 at 6:15 AM
    Silveryota01
    Logan
    Conway SC
    Will be trying a few more things today hopefully I can pinpoint the issue
