Need Help: 2000 Pre-Runner 2.7L no start diagnose
Discussion in '1st Gen. Tacomas (1995-2004)' started by jsidis, Mar 16, 2017.
  1. Mar 27, 2017 at 4:02 PM
    jsidis
    jsidis [OP] Active Member
    Boulder, CO
    Taco
    six inch lift
    Fuses all checked out and plugs are sparking. It's getting fuel but very clearly not combusting, just a flat crank. Put a charge on the battery b/c voltage was low, but it didn't have any effect. None of the vacuum hoses are broken/leaking, but could be clogged, I guess, they're old. I was able to feel that it was at least pulling some air at the throttle body opening.
    Could EGR or PCV be causing this? What about a stuck valve?
  2. Mar 27, 2017 at 4:07 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Compression test is next. When was the last time you gassed up?
  3. Mar 28, 2017 at 8:01 AM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Compression test it is.
    It's got a quarter-tank. Why do you ask?
  4. Mar 28, 2017 at 8:16 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd lean toward the egr valve, too. I hope you solve the issue, soon and good luck!
    More Information for AIRTEX/WELLS 4F1650
    AIRTEX/WELLS 4F1650[​IMG]
    Point to Zoom
    Includes Gasket
    Airtex/Wells is a recognized leader in engine management technologies, including a broad array of emissions components. This extensive portfolio of products – combined with company engineers’ intense focus on delivering products that fit and perform as well as or better than OE parts – has made Airtex a preferred supplier for professional technicians and do-it-yourselfers.
    Features:
    • Heavier circuit board material with specially formulated silver ink and wider pressure clip
    • Mounting and connector identical to OE
    • Sealant-coated plunger and outer housing
    • 100% tested to ensure OE fit, form and function
    • Gaskets and hardware included where applicable
    • Carbon catching gaskets available for applications with heavy carbon build-up and release issues
    • Ultra-precise flow rates and patterns match OE for minimal carbon buildup
    Benefits:
    • Superior wear and corrosion resistance
    • Precise fit and size for ease of installation
    • Extended life
    Repair tips:
    • Allow engine to cool before attempting replacement to avoid personal injury and fastener damage
    • If trouble code indicates insufficient flow, clean intake manifold passages
    Alternate/OEM Part Number(s): 226602, 2562075050, EGR4010
    AIRTEX/WELLS Warranty Information
    3 years/36,000 miles; Advantech parts- 12 months/12,000 miles
  5. Mar 28, 2017 at 8:34 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    EGR valves are commonly blamed, but rarely fail. Even if it was the issue, I"m pretty sure there would be a CEL, or for sure a stored pending code relating to the EGR system.
    Have you pulled the valve cover, to make sure the chain is still intact?
    cruiserguy and wilcam47 like this.
  6. Mar 28, 2017 at 1:19 PM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    I haven't pulled the valve cover yet - was working my way through the simple stuff. I can't imagine that chain coming "un-tact" in a relatively quiet, not rattling and clacking sort of way. Aside from throwing metal around in the engine, wouldn't it have thrown codes?
    Either way, I'm working my way to that valve cover, trying to rule out simpler, more hopeful things first. Compression test will likely have me in there.
  7. Mar 28, 2017 at 1:53 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    cranshaft position sensor would throw stuff out of whack too.
  8. Mar 29, 2017 at 3:11 PM
    Glamisman
    Glamisman Well-Known Member
    I have only had 1 vehicle exibit these conditions and not start and it was the catalytic convertor... it was so plugged that the exhaust couldnt escape. I daignosed this by taking out 1 plug and leaving it out and starting the vehicle... she started and ran, poorly, but enough to prove the diasnosis.
  9. Apr 5, 2017 at 8:53 AM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Time is getting the best of me on this one, so I've decided to have the Taco towed in and have a mechanic diagnose the issue. From there, I'll determine whether its something worth fixing myself, paying them to fix, or .... part ways with it.
    My question is this: What type of mechanic is my best bet to get a no BS diagnosis and repair estimate? Toyota dealer, foreign specialty, a "chain/corporate" shop? There's also a local shop that covers a gamut of makes/models, including Toyo/Lexus with good reviews.
    I've never employed a mechanic without having a specific repair. Ball-park, what price range am I looking at for a diagnosis, estimate?
  10. Apr 5, 2017 at 9:11 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Exactly. Check spark first. If none (which I bet there won't be if you smell fuel and the plugs are wet) then I'd be leaning crankshaft position sensor or similar. This is the device that tells the computer that the engine is spinning and to start the spark and fuel process. There's probably also an ignition fuse that you should check.
  11. Apr 5, 2017 at 9:12 AM
    rzgkane
    Foreign specialty. The dealer will jack you for every penny they feel they can get from you and you'll pay absolute top dollar for parts.
  12. Apr 5, 2017 at 9:55 AM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Just FYI on this one, and a general overview of my own diagnostic work:
    Fuel pump and injectors are confirmed good, and spark was present on all 4 cylinders.
    I pulled the crankshaft position sensor and tested it with a multimeter. The continuity was a little below spec, but there was continuity. I reasoned (maybe mistakenly) that this might cause rough start/idle/delay, it wouldn't likely be the cause of a sudden no-start. Truck was running fine prior to "no-start". Could I be wrong about Crank Sensor...?
    Compression was good across No. 1-3 cylinders. The No. 4 cylinder compression was outright bad. Per factory repair manual, a few drops of oil did not improve compression, pointing to a possible valve issue.
    I also drained a half-quart of oil, and it's clean, no water/coolant present, no metal shavings, etc.
    I also noticed a crack in the exhaust manifold. It's an old truck, so that didn't surprise me much. Obviously, that's something that needs repair, but I concluded it isn't likely the cause of a sudden no-start; more likely its a byproduct of the bigger issue (again, my reasoning here could be mistaken).
    Other stuff I did along the way: Cleaned MAF sensor, vacuum hoses are old, but unbroken and not clogged. OBDII showed no codes in memory and that sensors were "green-lighted" - I don't know why or how. New plugs, new high-tension cords.
  13. Apr 5, 2017 at 12:55 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Theres a crank and cam sensor I believe. Have you checked cam sensor? possible water in gas? What was the compression?
  14. Apr 5, 2017 at 1:13 PM
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Hrmm ... I didn't check camshaft position sensor. Is it inside the coils? The FSM for 2RZ and 3RZ says its inside the "distributor" but the 3RZ-FE doesn't have a classic distributor, rather 2 ignition coils.
    What would have caused water in gasoline? I can't see how that would happen in normal course of engine usage.
  15. Apr 5, 2017 at 1:18 PM
    #35
    SunSetPrez
    SunSetPrez Well-Known Member
    Orange County
    Good luck with this. I'm interested to see what it ends up being.
  16. Apr 5, 2017 at 1:37 PM
    #36
    mechanicjon
    Jon
    Scottsdale Arizona
    oK YOU HAVE THE 2RZ. As far as water in gas either from gas station or also condensation. That's why I asked when did you fill up last.
  17. Apr 5, 2017 at 3:02 PM
    #37
    jsidis
    Boulder, CO
    Taco
    six inch lift
    It's a 3RZ-FE A/T (2WD, 2000 PRE-RUNNER), but the FSM is for RZ series. Pre-Runner has 3RZ and A/T.
    Probably not water in gas (though not outside realm of possibility). That wouldn't account for compression loss on Cylinder 4.
  18. Apr 5, 2017 at 4:16 PM
    #38
    mechanicjon
    Jon
    Scottsdale Arizona
    Whats the compression? Cam sensor is in head by intake manifold. I'll find some info or a pic
  19. Apr 5, 2017 at 4:31 PM
    #39
    mechanicjon
    Jon
    Scottsdale Arizona
    The 2003 FSM covers the dist. less ignition.
    jsidis[OP] likes this.
  20. Apr 19, 2017 at 9:32 AM
    #40
    jsidis
    Boulder, CO
    Taco
    six inch lift
    Just an update in case anyone was waiting patiently to learn the issue. The mechanic found a cracked injector o-ring, causing fuel to leak, which may explain fuel smell. Not sure how I didn't catch that, unless it was on the 4 cylinder, where I can't see.
    He said the cylinders were flooded out pretty bad, so he pulled plugs and cleaned them out, added a little oil for the rings and, he says, it starts right up. Said he left it overnight, and it fired up no problem this morning. All cheap fixes. I'd rather not have to pay for labor that simple, but I had my shot and couldn;t get it running. I'll shut up and pay up.
    We'll see how it fares over the next week or so, but hopefully I won't be back to this thread. Thanks everyone for the suggestions.
    mechanicjon, wilcam47 and cruiserguy like this.
